I am using r.clump on a quite large file.
I get the error below.
1-band clumping with threshold 0
Pass 1 of 2…
Current region rows: 220000, cols: 240000
ERROR: G_realloc: unable to allocate 18446744065119617024 bytes of memory at raster/r.clump/clump.c:633
Is there any way to use an option to enable some disk swap memory (similar to similar to the one on r.watershed)?
I tried to use g.gisenv set=“MEMORYMB=6000but I am not sure it made a difference. Would it help to set an higher value for MEMORYMB?
thanks
Laura
