Dear all,
I would like to personalize popup in lizmap depending on a specific field in attribute table.
As example in field1 have a value equal to 1 then in popup I would see the content of field2.
Thanks for your support
Dear all,
Using the tooltip of your layer in QGIS you can add custom expression like this :
[% if( field1=1, field2, 'other content) %]
Then in the lizmap QGIS extension you must specify HTML Popup
I guess you mean “HTML Maptip” ![]()
Just in case, to not get confused with “Lizmap Popup”, which is deprecated.
