I have tried to access this site several times
I get a timeout event reports
Is there a problem?
Dave.
Is there a problem?
Dave.
On 7/28/2013 4:20 AM, Dave Potts wrote:
Is there a problem?
A/C died and I've had to power down some servers to manage the heat. I just powered it back up but is will probably get shut back down. I'll copy the doc to another server and post a new link. It is likely that I'll take all the servers down to blow the dust out of them at some point today. We have had a heat-wave and the A/C server is backup and the earliest I can get them in here is Tuesday.
-Steve
Is there a problem?
I've also placed a copy temporarily at:
http://imaptools.com:8080/pgr2-doc/src/trsp/doc/index.html
Daniel - What is the process to update the main gh-pages?
-Steve
On Sun, Jul 28, 2013 at 10:52 PM, Stephen Woodbridge <
Is there a problem?
the earliest I can get them in here is Tuesday.I've also placed a copy temporarily at:
http://imaptools.com:8080/**pgr2-doc/src/trsp/doc/index.**html<http://imaptools.com:8080/pgr2-doc/src/trsp/doc/index.html>Daniel - What is the process to update the main gh-pages?
It's very easy and documented in the Readme of gh-pages branch itself:
https://github.com/pgrouting/pgrouting/tree/gh-pages
(maybe too perfect place to not be able to find it
In general every HTML that gets pushed to gh-pages branch will become
available in http://docs.pgrouting.org
So the only thing you have to do manually is to replace the "dev" directory
with the "build/html" directory and commit and push.
(It's a bit more complicated if you want to add a new item to the
index.html page, such as rc1, beta, etc.)
.gitignore in the gh-branch should be configured correct to not publish the
build directory for example.
I don't know there is a way to run this automatically. Maybe it could be
done from the Travis build script.
Daniel
woodbri@swoodbridge.com> wrote:On 7/28/2013 9:11 AM, Stephen Woodbridge wrote:
Is there a problem?
(maybe too perfect place to not be able to find itIn general every HTML that gets pushed to gh-pages branch will become
directory with the "build/html" directory and commit and push.
index.html page, such as rc1, beta, etc.).gitignore in the gh-branch should be configured correct to not publish
the build directory for example.
I forgot that with PDF and MAN a few more steps are required as you also
have to copy the new versions into the "dev" directory.
Daniel
Georepublic UG & Georepublic Japan
eMail: daniel.kastl@georepublic.de
Web: http://georepublic.de
<mailto:daniel@georepublic.de>> wrote:On Sun, Jul 28, 2013 at 10:52 PM, Stephen Woodbridge
<woodbri@swoodbridge.com <mailto:woodbri@swoodbridge.com>> wrote:On 7/28/2013 9:11 AM, Stephen Woodbridge wrote:
Is there a problem?
the heat. I
down. I'll
likely that
at some
backup and
http://imaptools.com:8080/__pgr2-doc/src/trsp/doc/index.__html
become available in http://docs.pgrouting.org
publish the build directory for example.
could be done from the Travis build script.I forgot that with PDF and MAN a few more steps are required as you also
I have added a script tools/publish-doc that will automate this and make it easier for me to do this. Basically took you description gtom the gh-pages readme. So now you(I) can do:
tools/doit
tools/publish.sh
New docs have been pushed. My servers will probably get shut down sometime soon as the heat is rising.
-Steve
On Mon, Jul 29, 2013 at 1:36 AM, Stephen Woodbridge <woodbri@swoodbridge.com
<mailto:daniel@georepublic.de>**> wrote:On Sun, Jul 28, 2013 at 10:52 PM, Stephen Woodbridge
<woodbri@swoodbridge.com <mailto:woodbri@swoodbridge.**com<woodbri@swoodbridge.com>>>
Is there a problem?
the heat. I
down. I'll
likely that
at some
backup and
http://imaptools.com:8080/__**pgr2-doc/src/trsp/doc/index.__**
html <http://imaptools.com:8080/__pgr2-doc/src/trsp/doc/index.__html>Daniel - What is the process to update the main gh-pages?
https://github.com/pgrouting/**pgrouting/tree/gh-pages<https://github.com/pgrouting/pgrouting/tree/gh-pages>
have to copy the new versions into the "dev" directory.I have added a script tools/publish-doc that will automate this and make
gh-pages readme. So now you(I) can do:tools/doit
tools/publish.shNew docs have been pushed. My servers will probably get shut down sometime
We can probably add this to the Travis script, too.
I just don't want to run it for each test, because the documentation will
not change.
Daniel
