I have not done this myself, so you might have to wait for Anton. But you might check out:
I believe that you need to runt postgresql in single user mode to start with. Beyond that I think a quick look at the postgresql docs should indicate how to run this in gdb so you can catch the error.
Hi Stephen,
Thanks for the quick reply.
I did as you said, and now I can see the function when I do \df.
Now, Im getting following msg:
server closed the connection unexpectedly
This probably means the server terminated abnormally
before or while processing the request.
The connection to the server was lost. Attempting reset: Failed.
How can I print the errors/ stack traces that are going on in
background? (I am sorry if this is too naive, but I am doing this kind
of debugging for the first time) Any online documentation/manuals in
this regard would really help.
On Mon, Dec 20, 2010 at 3:12 AM, Stephen Woodbridge
<woodbri@swoodbridge.com <mailto:woodbri@swoodbridge.com>> wrote:
Hi Jay,
It sounds like you have the correct approach as outlined. I think
the only step that you missed is that you have to load you wrapper
function into the database.
psql mydatabase
CREATE OR REPLACE FUNCTION all_pairs_shortest_path(sql text, directed
boolean, has_reverse_cost boolean)
RETURNS SETOF apsp_result
AS '$libdir/librouting'
LANGUAGE 'C' IMMUTABLE STRICT;
-- now run your query
The wrappers get loaded because they are in the sql files like:
> -- Up-to-date: /usr/share/postlbs/routing_core_wrappers.sql
You could create a new file like:
routing_extra_wrappers.sql or
routing_apsp_wrappers.sql
And have cmake install them, or manually install them like above.
If you areadly did that and you can see you function in the list of
functions in psql like:
\df+ all_pairs_shortest_path
Then try adding a cast TEXT as shown below:
SELECT * from all_pairs_shortest_path(
'SELECT gid as id,source::integer,target::integer,
length::double precision as cost from ways'::TEXT,
false,false);
-Steve
On 12/19/2010 3:54 PM, Jay Mahadeokar wrote:
*I am currently trying to implement apsp as follows: *
directed
Now, I think my boost_apsp() function is working for small input
data,
and I want to test if the overall query is working. I have coded
apsp.c
accordingly.
I have modified /core/cMakeLists.txt so as to just build apsp and
dijkstra for now:
"ADD_LIBRARY(routing SHARED dijkstra.c apsp.c boost_wrapper.cpp
apsp_boost_wrapper.cpp)"
Here is the output after I run "cmake -DWITH_DD=ON", and then
"make":
jay@jay-HP-Compaq-6720s:~/Desktop/pgRouting/pgRouting-pgrouting-7b07040$
make
[ 50%] Built target routing_dd
Scanning dependencies of target routing
[ 62%] Building C object core/src/CMakeFiles/routing.dir/apsp.o
Linking CXX shared library ../../lib/librouting.so
[100%] Built target routing
sudo make install
[sudo] password for jay:
Install the project...
-- Install configuration: ""
-- Installing: /usr/lib/postgresql/8.4/lib/librouting.so
-- Installing: /usr/share/postlbs/routing_core.sql
-- Up-to-date: /usr/share/postlbs/routing_topology.sql
-- Up-to-date: /usr/share/postlbs/matching.sql
-- Installing: /usr/lib/postgresql/8.4/lib/librouting_dd.so
-- Installing: /usr/share/postlbs/routing_dd.sql
-- Installing: /usr/share/postlbs/routing_dd_wrappers.sql
I think there were no compilation errors while compiling apsp files.
Now, when i log into postgres and query for shortest_path() on
pgrouting-workshop database, I get the correct results.
*But, query on all_pairs_shortest_path() gives this: *SELECT * from
all_pairs_shortest_path('SELECT gid as
id,source::integer,target::integer,length::double precision as
cost from
ways',false,false);
ERROR: function all_pairs_shortest_path(unknown, boolean,
boolean) does
not exist
LINE 1: SELECT * from all_pairs_shortest_path('SELECT gid as
id,sour...
HINT: No function matches the given name and argument types.
You might
need to add explicit type casts.
I tried restarting the postgres server too.
*Questions:*
1. For testing the new function, am I following correct approach?
2. I will try to learn some git commands and upload my source
code in
the repository that I have forked here:
https://github.com/jay-mahadeokar/pgrouting, I guess it would be
easier
for you guys to provide help and see what is actually going on
that way,
right?
On Fri, Dec 17, 2010 at 4:48 PM, Daniel Kastl
<daniel@georepublic.de <mailto:daniel@georepublic.de>
<mailto:daniel@georepublic.de>>
wrote:
Hi Jay,
Thank you for giving us some updates!
Anton traveled to freezing cold Siberia yesterday and it
could take
some days for him to defrost
So maybe it will a while until he can answer.
I will try to take a look the next days and see if I can
give some
advice, but probably it's better to hear Anton.
Daniel
*Some Questions:*
Now, I need to code apsp.c which will retrieve the edges
/ nodes
from postgres database and call the above function. The
result
will be returned as apsp_result.
For dijkestra, we have the following query format:
SELECT gid, source, target, cost FROM edge_table
For, apsp will the query format remain same?
Or do we take the vertices(in form of points) as input
separately, in some other format? One application of
this might
be when a user will select a set of points on map and
call apsp
on those points.
On Wed, Dec 8, 2010 at 2:12 PM, Daniel Kastl
wrote:
For now, can we go ahead and implement the above
algo in
pgRouting? I am thinking of a warshall_wrapper class
that would call the above function, and the actuall
warshall apsp would return distances in form of
rows,
each row having three columns:
source, target, distance. (We will have nC2 such
rows
for now..)
As Anton mentioned, this can get confusing
sometimes. Too
many sources and targets, can be the ones of an edge
or of a
route.
Any good idea how define names in an easy to
understand and
clear way is welcome. This is probably going to
become more
of an issue as more pgRouting grows.
@Anton: maybe we should somewhere define a dictionary of
terms we use and what we use them for.
Other thing, I didn't really get your answer how to
prevent
mixing source/target ... was there a "not" missing? It
wasn't clear to me
Some queries:
1. I have not yet tried modifying the pgRouting
source
code, and compiling other files together with the
existing ones. I am completely new to cmake and
will try
and learn how to work with that. From what I have
understood, every new algorithm that we add to
existing
set will have a similar flow and similar files
etc. Is
there any doc which can guide as to what
configuration
changes would be needed for adding a new algo (For
example we would usually add following files:
algo.h,
algo.cpp, algo.sql, algo_boost_wrapper.cpp etc). (I
hope my query is clear)
If I find some time I want to study the CMake
manual, too,
and see if we can make some improvements here and
there. I
think it was also new for Anton at the time of
writing the
files, so if you find some possible improvements,
let me know.
There are no "coding standards" defined yet, which
would be
probably a good idea when more algorithm will be
implemented
in the future.
Same as above, if you have some idea, then you can share
with us. We're open for criticism! Otherwise I
believe it's
sometimes better to have a couple of algorithms
first and
then see what could be "standardized" and define
them based
on our experience.
Btw., if you want to make use of GitHub, then you
can create
an account and fork the pgRouting repository:
https://github.com/pgRouting/pgrouting
It will be then easy to apply your changes.
Anton, where will APSP go? To "core" or to "extras"?
Seeing the number of extensions grow, does this
structure
still work for us?
How do we define what is "core" and what is "extra"?
I think the initial main idea was to provide pgRouting
without Gaul and CGAL dependencies.
2. Are there any sample test cases/scripts,
which were
used to test dijkstras algo (which can be useful
here too)?
I think that pgRouting should have unit tests ... but we
don't have so far, which is not so good
Here is a ticket already:
https://github.com/pgRouting/pgrouting/issues#issue/20
As usual it's a lack of time to work on this.
It's probably better to have some generic testing
data than
just take OSM data from the workshop, Anton.
OSM data won't allow us to test all possible
functionality
some functions provide.
Daniel
Georepublic UG & Georepublic Japan
eMail: daniel.kastl@georepublic.de
<mailto:daniel.kastl@georepublic.de>
<mailto:daniel.kastl@georepublic.de>>
Web: http://georepublic.de/>
pgrouting-dev mailing list
pgrouting-dev@lists.osgeo.org <mailto:pgrouting-dev@lists.osgeo.org>
<mailto:pgrouting-dev@lists.osgeo.org>>
http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
-Jay Mahadeokar
-Jay Mahadeokar
-Jay Mahadeokar
