Sounds like you have a good handle on all the pieces to this problem.
What do you need to get started ![:slight_smile: :slight_smile:](/images/emoji/twitter/slight_smile.png?v=12)
When (v^2 log n) > n^2 we can use Warshall algo. Extracting paths will
be complicated task.
I think some thought needs to go into:
1. what are the results? just a V^2 table of costs?
2. can we extract the paths? In pgRouting, this has some
additional
implications beyond is it physically possible to extract
paths from
the algorithm.
a. typically queries do not store results, they only
return sets
b. extracting paths, implies computing assembling a graph,
computing the results and holding the results for additional
queries
against them to extract paths.
c. while this is potentially possible using temp tables,
we do not
currently do that
I did not properly understand point b above.
OK, I will try to explain. Typically the process of running a
pgRouting query follows something along this pseudo code:
1. select a subset of all node that we think will be enough to solve
our problem. This is done via a bounding box of the start and end
nodes inw question and expanded somewhat in case the route wanders
out of the bounding box.
2. these nodes and the edges connected to them are built into a
boost graph
3. the boost graph is solved
4. the results are return to the SQL caller as a set of database
records.
5. the boost graph is destroyed
So basically one input, one process, one output. Nothing is saved.
If on the other hand we had a process like:
1. build graph
2. solve graph
3. return matrix of distances
4. hold onto graph because these might be addition requests the need
the matrix
5. request path A-B from graph
6. request path D-H from graph
7. request ...
8. we are done with the graph so destroy it
Which is my assumption that we would need to do to extract paths,
then we do not have a paradigm for this in SQL.
Now we may not need to do that, but I was assuming that there was
information in the graph that was easy to extract about the paths
that gave the distance returned in the distance matrix.
Hey.. Again, during step 3 above, if we build the path matrix along
with the distance matrix for Warshall Algo, we can use that to extract
all paths, we will not need any more queries to database. We also need
not hold on to the graph! And the overall time is still O(n^3) ![:slight_smile: :slight_smile:](/images/emoji/twitter/slight_smile.png?v=12)
I am not sure if the boost implementation of Warshall returns a path
matrix,
http://www.boost.org/doc/libs/1_45_0/libs/graph/doc/floyd_warshall_shortest.html
says that it will just return the distance matrix.
In theory, we can simultaneously create a n^2 path matrix along
with the
distance matrix and use that to extract paths. Pseudo code is
present
here:
http://en.wikipedia.org/wiki/Floyd–Warshall_algorithm. So,
if we want to build the path matrix, we need to code Warshall from
scratch, using maybe boost data structures.
I guess this is up to the use cases for this and maybe we should ask
others to chime in based on their needs.
I think this really depends on the number of nodes that a user needs
to work with. If you assume asymmetric directed graph, the you need
to compute n^2 distances. for small say n<20 that is 400 routes and
if at 1 sec per route it takes 6.67 minutes; n=100 it takes about
2.78 hours.
I guess assuming 1 sec per route is too slow for modern processors! If
you are including the database query latency, then again Path Matrix
will make sure we need to query database only once, so the rest of the
work should be fast.
My use case would be to feed the results into TSP solver to order
the nodes, then to extract the routes between the ordered nodes. I
have used simulated annealing to solve TSP very fast.
http://imaptools.com/cgi-bin/tsp.cgi
Copy and paste the cities into the text area and compute the TSP.
This demo application geocodes all the cities and comput the
straight line distance between them and then solves the TSP problem.
It would really be grate to compute the network paths before solving
the TSP.
I know pgRouting has a TSP solver, but it requires the CGAL package
I think which is hard to find and build on many systems.
Nice Application! I am not sure what is complexity of your algorithm.
But if you want to compute actual paths before feeding the algo, I guess
the number of nodes in the path will increase by a big factor which will
slow down APSP significantly. (You may just consider Highways to get
around this, could discuss this on a separate topic!)
If we have vertex ids of whole graph, the path matrix is
sufficient to
extract all paths (extracting one path will take O(n) time), and
I think
there is no need for additional queries to database.
I saw the path extraction code in the wiki page , but I need to go
back over it in more detail.
Best regards,
-Steve W
Please correct me if I am missing something.
Anyway, these are some things to start a discussion and
provoke some
thoughts. I do not want to grow the scope of this project to the
point that it is problematic, so we should focus on what can
be done
and plan for future additions if they are needed.
I look forward to working with you. Thank you for your
interest in
pgRouting.
Best regards,
-Steve W
pgrouting-dev mailing list
pgrouting-dev@lists.osgeo.org
<mailto:pgrouting-dev@lists.osgeo.org>
<mailto:pgrouting-dev@lists.osgeo.org>>
http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
-Jay Mahadeokar
pgrouting-dev@lists.osgeo.org <mailto:pgrouting-dev@lists.osgeo.org>
-Jay Mahadeokar
