I’m using pgrouting 8.3 version. and i found an website that show me how to routing using pgrouting and postgis.
that a good information for me to do my work.
but, when i follow the SQL file script, and insert data to Road table. I don’t clearly know about each fields in Road table.
can you show me the definition of each field and the meaning of it.
for example :
Fields ---- meaning
id – get the id of each point.
source – …smth…
target – …
cost – …
reverse_cost — …
sens ----- …
x1 ----- …
y1------ …
x2 ------…
y2 ------ …
edge_id ----- …
the_geom ------…
thanks.
Mr. Vietbv
Do your best , the rest will come*.*
See here: http://www.pgrouting.org/docs/1.x/astar.html
2011/6/3 viet bui <buiviet9488@gmail.com>
for example :
Fields ---- meaning
source – …smth…
target – …
cost – …
reverse_cost — …
sens ----- …
x1 ----- …
y1------ …
x2 ------…
y2 ------ …
edge_id ----- …
the_geom ------…
thanks.
Mr. Vietbv
pgrouting-dev mailing list
pgrouting-dev@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
Georepublic UG & Georepublic Japan
eMail: daniel.kastl@georepublic.de
Web: http://georepublic.de
