Thank you all for your guidance. I've submitted a pull request for my changes. As I noted in the text of the request, librouting_tsp and librouting_ksp are being built as static rather than dynamic libraries, so make install fails since they have the extension .a rather than .so. Any thoughts on this would be most appreciated.
The only other trouble I've run across is a very long list of warnings like this while compiling:
/usr/local/src/pgrouting/src/driving_distance/src/drivedist.c:220:34: warning: use of GNU old-style field designator extension [-Wgnu-designator]
edge_columns_t edge_columns = {id: -1, source: -1, target: -1,
How do I go about contributing these edits once I get it all
working?
Best way, is to fork the pgrouting respository, make your changes there and issue a pull request so we can merge your changes.
For sure this would be easiest and best solution.
If there are not too many changes, you could do something like:
git diff > mychanges-diff.txt
And open a ticket and attache the diff file to the ticket.
I think Github doesn't allow to attach files to tickets (just looked for it last week), but an alternative would be to use Gist: https://gist.github.com/
Nevertheless, to fork the repository and then submit a pull request would be better:
https://help.github.com/articles/using-pull-requests
Daniel
-Steve
Best, Alec
On May 8, 2013, at 11:55 AM, Stephen Woodbridge
<woodbri@swoodbridge.com> wrote:
Hi sanak,
I looked at your changes below, and they do not seem to be based on
my branch "sew-devel-2_0". The quick tell is that my source starts
at "src/" and not "core/" as your changes reflect.
For linux I compile, install and test using:
tools/doit (cd build; sudo make install) tools/testrunner.pl
In the C/C++ code you should be able to use:
#ifdef __APPLE__ ... #else ... #endif
and in cmake you can use:
if(APPLE) ... else(APPLE) ... endif(APPLE)
Can you also post what the results of:
echo | g++ -dM -E -
when run on OSX.
No hurray, when you can get to it, this weekend is fine.
Thanks, -Steve
On 5/7/2013 6:05 PM, sanak wrote:
Hi Alec, Stephen,
About 1 month ago, I tried Mac ports build in my private
branch("macports") which is based on "sew-revel-2_0", and
confirmed that it can build with Mac OSX 10.8(Mountain Lion).
https://github.com/sanak/pgrouting4w/commit/7291a7b6be3bd37c9e507048bfe3ba0fcf0c5c6e
Now, I am busy for other task, but, I will check and test it in this
weekend.
2013/5/8 Stephen Woodbridge <woodbri@swoodbridge.com
<mailto:woodbri@swoodbridge.com>>
On 5/7/2013 10:27 AM, Alec Gosse wrote:
Hello all,
I am working on a bicycle routing project and converting from
Open Trip Planner to pgRouting on both OSX and 64bit Ubuntu with
PostgreSQL 9.1+. For me, the sew-revel-2_0 branch will build
under ubuntu 12.10, but not on OSX 10.8 using dependencies
installed through Homebrew.
Homebrew is certainly the best way I've found to install
open-source tools on a mac, so I would like to help get pgRouting
2.0 installable that way. Homebrew tends to use quite current
packages such as boost 1.53, however, but I see in tool/NOTES.txt
that pgRouting requires boost 1.46.1? Since things build on
Ubuntu using boost 1.49, I'm wondering if this still applies?
Well the required version is whatever you can get to work. I
know there are some problems with 1.47, but those might be
specific to that version.
In either case, what's the best way for me to help get things
running under OSX? Should I post errors I can't resolve to the
list, and or is someone already working on this?
Yes, We can try to help if we know what errors you are seeing.
I'm not sure anyone here has OSX so you might need to take some
initiative to figure things out. If you look at the
CMakeLists.txt files that are sprinkled throughout the project
tree, you will see that some of them have blocks like:
if(APPLE) ... endif(APPLE)
maybe we don't have these setup correctly or maybe some are
missing that need to be added. It would be great if you can help
with this.
Thanks, -Steve
Best, Conrad (Alec) Gosse, MUEP Doctoral Candidate: Civil &
Environmental Engineering University of Virginia Charlottesville,
VA
On May 7, 2013, at 1:40 AM, Daniel Kastl <daniel@georepublic.de
<mailto:daniel@georepublic.de>> wrote:
Hi Razequl,
The currently used branch is named "sew-devel-2_0" (we're
planning to rename it to "develop" some time). You find all the
necessary steps to compile explained on the Github readme:
https://github.com/pgrouting/__pgrouting/tree/sew-devel-2_0
<https://github.com/pgrouting/pgrouting/tree/sew-devel-2_0>
If you want to compile with support for "Driving Distance", then
you need to have CGAL libraries as dependency. GAUL dependency
is gone.
Daniel
On Tue, May 7, 2013 at 2:35 PM, Razequl Islam
<ziboncsedu@gmail.com <mailto:ziboncsedu@gmail.com>> wrote: Hi
Steve, I also want to have a look at the possible problem. I am
trying to set up the environment on my machine. I have the
previous version. What do I need to do to get 2.0 working? Should
I set up the environment from the scratch or should an update
will do. Please let me know how I should proceed. I can also do
the debugging once I have the environment in place.
Thanks. - Razequl
On Mon, May 6, 2013 at 11:32 PM, Stephen Woodbridge
<woodbri@swoodbridge.com <mailto:woodbri@swoodbridge.com>> wrote:
Hi Razequl,
I have been trying to integrate your bidirectional shortest path
code. I have merged the code into my pgrouting branch
"sew-devel-2_0", but it is crashing the back-end with a segv.
If you have time and want to look into this that would be great
as I would like to get this code working in 2.0.
I'm not sure if I found a bug in your code or I broke something
when I merged it, or for that matter that I even merged the
correct code
because you sent email indicating that you fixed
stuff. I merged the code from master at
https://github.com/zibon/__pgrouting
<https://github.com/zibon/pgrouting>
I also ran into an issue that when I merged you code into the
code library, that the trsp broke, then take you code out and it
works again. I assume that there is some kind of function name
or global initialization issue. This does not seem to be an issue
for trsp now that the bi-dir code is in a separate library.
This might give you a chance to get your development/test/debug
environment setup and to familiarize yourself with the new
source code layout.
Let me know if you have time and I'll help point the way. If you
are tied up with class work, etc that clearly takes priority.
Thanks, -Steve
_________________________________________________ pgrouting-dev
mailing list pgrouting-dev@lists.osgeo.org
<mailto:pgrouting-dev@lists.osgeo.org>
http://lists.osgeo.org/__mailman/listinfo/pgrouting-dev
<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
-- Georepublic UG & Georepublic Japan eMail:
daniel.kastl@georepublic.de <mailto:daniel.kastl@georepublic.de>
Web: http://georepublic.de
_______________________________________________ pgrouting-dev mailing
pgrouting-dev mailing list
eMail: daniel.kastl@georepublic.de
