Dear Mr. Steve
Glad to know astar_sp already use ecludian.
I used astar_sp for the function from the start.
Is there possibility i can see the script ecludian? i tried to find, but the script is in library.(am i right ?) or there is a documentation about it?
Boost Graph code, If i found some heuristic, i’ll try to write it.
Thanks for the anwer,
Dear Mr. Sanak
Thanks for answer, nice tutorial. Thank you so much
This mailing list is really great, i hope everyone who ‘new’ used pgrouting know about it. Really help. Thankyou.
Thanks & Regards,
Robi
Dari: “pgrouting-dev-request@lists.osgeo.org” pgrouting-dev-request@lists.osgeo.org
Kepada: pgrouting-dev@lists.osgeo.org
Dikirim: Selasa, 10 Juli 2012 19:21
Judul: pgrouting-dev Digest, Vol 25, Issue 13
Send pgrouting-dev mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
or, via email, send a message with subject or body ‘help’ to
You can reach the person managing the list at
pgrouting-dev-owner@lists.osgeo.org
When replying, please edit your Subject line so it is more specific
than “Re: Contents of pgrouting-dev digest…”
Today’s Topics:
- Ask how to use : Euclidean distance heuristic in A* in
pgrouting (Haruhi Suzumiya) - Re: Ask how to use : Euclidean distance heuristic in A* in
pgrouting (Stephen Woodbridge) - Re: Ask how to use : Euclidean distance heuristic in A* in
pgrouting (Sanak) - duplicate function names in core (Mario Basa)
pgrouting (Steve Horn)
Message: 1
Date: Tue, 10 Jul 2012 09:24:53 +0800 (SGT)
From: Haruhi Suzumiya <haruhi.suzumiyachan@yahoo.com>
To: “pgrouting-dev@lists.osgeo.org” <pgrouting-dev@lists.osgeo.org>
Subject: [pgrouting-dev] Ask how to use : Euclidean distance heuristic
in A* in pgrouting
Message-ID:
<1341883493.85457.YahooMailNeo@web190103.mail.sg3.yahoo.com>
Content-Type: text/plain; charset=“iso-8859-1”
Good morning,
Dear mr/mrs,
I’m robi, my username is haruhi. I’m newbie in pgrouting.?
I want to try use euclidean distance heuristic in A* in pgrouting, may u
give me tutorial how to change the heuristic and recompile it?
Fyi, I’m use windows 7, postgre 1.8.4, pgRouting-1.02_pg-8.3.3
Thankyou and regards,
Robi
An HTML attachment was scrubbed…
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20120710/f5ae9295/attachment-0001.html>
Message: 2
Date: Mon, 09 Jul 2012 23:27:22 -0400
To: pgrouting-dev@lists.osgeo.org
Subject: Re: [pgrouting-dev] Ask how to use : Euclidean distance
Message-ID: <4FFBA11A.7000100@swoodbridge.com>
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
On 7/9/2012 9:24 PM, Haruhi Suzumiya wrote:
Good morning,
Dear mr/mrs,
Hi Robi,
The pgRouting package already supports A* and by definition it uses a
euclidean distance heuristic. See the function shortest_path_astar(),
there also may be some wrapper function with names like astar_sp_*
The wrapper function are just higher level convenience function.
There are a couple of tutorials around that probably have good examples
of how to use the functions.
If you want to change the heuristic, then you will need to look at the
Boost Graph code that is used to implement it. We don’t have any
documentation on the implementation, but there are a lot of docs on
Boost Graph and you can get help from that list.
What I would do is write a wrapper for the Boost Graph code and reads a
text file to input the graph, sets up the structures to pass the data to
algorithm to run it and then prints out the results. You can do all this
outside of the database which greatly simplifies debugging your changes.
When you have it working the way you want, then it should be a clean
drop in replacement for the existing code or you can clone the existing
code and rename it for the new algorithm.
-Steve W
Message: 3
Date: Tue, 10 Jul 2012 16:20:45 +0900
To: pgRouting developers mailing list <pgrouting-dev@lists.osgeo.org>
Message-ID:
<CALeT7PBPSN9cQ1Qyq0u6fNPdwRY3YoxPytyAc-EUFWass2j65A@mail.gmail.com>
Hi Robi,
I am not familiar with A* heuristic logic,
but if you want to build pgRouting Windows binary,
see following source and docs.
https://github.com/sanak/pgrouting
https://github.com/sanak/pgrouting/blob/mingw/BUILD.mingw
https://github.com/sanak/pgrouting/blob/mingw/BUILD.mingw64
And if you want to skip building dependency libraries,
use following build environment.
http://sdrv.ms/NFCgr2
± Build.zip … for 32bit work folder. (extract to "C:")
± MinGW.zip … for 32bit build environment. (extract to "C:" and run
“C:\MinGW\msys\1.0\msys.bat”)
± Build64.zip … for 64bit work folder. (extract to "C:")
± ming64.zip … for 64bit build environment. (based on PostGIS one.
extract to "C:" and run “C:\ming64\msys\msys.bat”)
2012/7/10 Stephen Woodbridge <woodbri@swoodbridge.com>
Good morning,
Dear mr/mrs,
Fyi, I’m use windows 7, postgre 1.8.4, pgRouting-1.02_pg-8.3.3Hi Robi,
euclidean distance heuristic. See the function shortest_path_astar(), there
also may be some wrapper function with names like astar_sp_*The wrapper function are just higher level convenience function.
There are a couple of tutorials around that probably have good examples of
how to use the functions.If you want to change the heuristic, then you will need to look at the
documentation on the implementation, but there are a lot of docs on Boost
Graph and you can get help from that list.What I would do is write a wrapper for the Boost Graph code and reads a
When you have it working the way you want, then it should be a clean drop
in replacement for the existing code or you can clone the existing code and
rename it for the new algorithm.-Steve W
_____________**
http://lists.osgeo.org/**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20120710/72b00301/attachment-0001.html>
Message: 4
Date: Tue, 10 Jul 2012 17:23:19 +0800
Subject: [pgrouting-dev] duplicate function names in core
Message-ID:
<CAJwAmBPWaLmxBwy2iJMTwG+WvqO=ZqJt4OKWj1tr0SKJunJKwA@mail.gmail.com>
Content-Type: text/plain; charset=UTF-8
Hello,
I am encountering problems placing the drivedist.c and
boost_drivedist.cpp into core (everything compiles, drivedist works
but astar searches dumps core. If I take out drivedist, astar works
like normal.), so I decided to poke around the source. I just found
out that there are so many duplicate functions (i.e.
finish(),text2char(),etc.) and struct names (edge_column,etc.) in each
of the C files.
Since C does not have any namespace functionality nor function
overloading, I don’t have any idea which one will be called whenever
there is a library call. Scary since this will be difficult to debug.
Now that pgRouting is getting source contributions, I think this will
be a good time that we start discussing function naming conventions to
avoid duplicates as well as directory (core and extensions)
structures.
Mario.
Message: 5
Date: Tue, 10 Jul 2012 08:21:20 -0400
Message-ID:
<CAFLkBaW9+mPjHz_tLZ=9owhdFowXjs3ieSLmPQUqqAu4Wix7ag@mail.gmail.com>
Robi,
Since you have the instructions on how to recompile, I can tell you that
the heuristic function can be changed in the file astar_boost_wrapper.cpp
in the core/src directory around line 82. Look for the comment:
//You can choose any heuristical function from below
//return ::max(dx, dy);
//return ::sqrt(dx * dx + dy * dy)/4;
//return 0;
return (::fabs(dx)+::fabs(dy))/2;
On Tue, Jul 10, 2012 at 3:20 AM, Sanak <geosanak@gmail.com> wrote:
Hi Robi,
see following source and docs.https://github.com/sanak/pgrouting
https://github.com/sanak/pgrouting/blob/mingw/BUILD.mingw64And if you want to skip building dependency libraries,
use following build environment.http://sdrv.ms/NFCgr2
extract to "C:" and run “C:\ming64\msys\msys.bat”)Regards,
Good morning,
Dear mr/mrs,
of how to use the functions.If you want to change the heuristic, then you will need to look at the
_____________**
Steve Horn
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20120710/fdd6907d/attachment.html>
End of pgrouting-dev Digest, Vol 25, Issue 13
