All,
Here are some related links that might be of interest:
http://stackoverflow.com/questions/43655284/boost-graph-library-turn-restrictions-or-turn-penalties
http://lekv.de/pub/lv-turns-2008.pdf
My post to the Boost graph list from 2011:
https://lists.boost.org/boost-users/2011/11/71549.php
Some ideas that might be useful if you have not already seen them.
-Steve
On 5/17/2017 3:46 PM, Vicky Vergara wrote:
Hello Anthony,
I must tell you that Vidhan's project involves only the TRSP version one to one.
He researched some algorithms, but we haven't discussed in detail what his final approach will be.
We are currently on the getting to know the code standard stage.Any comments are welcome,
You can find our conversations in
https://gitter.im/pgRouting/pgroutingPlease feel free to read our history of conversations and ask or comment.
Vicky
On Wed, May 17, 2017 at 1:59 PM, Stephen Woodbridge <woodbri@swoodbridge.com <mailto:woodbri@swoodbridge.com>> wrote:
Hello Anthony,
Thank you for reaching out to me. I have CC'd
Vicky Vergara - Lead developer and release manager on pgRouting
Vidhan Jain - GSoC Student working on TRSP rewriteI think that collaborating with them in this effort will be most
fruitful.It has been a while since I have really wrapped my head around this
problem and you seem to have gotten farther into the design and
planning for this than I did. You raise some interesting problems.In addition to the problems you pose, had you thought about how you
would what to prevent an illegal turn rather than just add a cost to it?Also for complex intersections/restrictions you need to be able to
specify a sequence of multiple edges to define a restriction (if
your working with nodes then an ordered list of nodes preceding the
current node under evaluation).Vicky, Vidhan, any thoughts on how you might proceed working with
Anthony? I'm thinking that sharing ideas and discussing the issues
and concerns would be a good starting point, but I'll leave this up
to the three of you to sort out what works best with Vicky having
the final say as release manager.Best regards,
-SteveOn 5/17/2017 2:10 PM, A Tasca wrote:
Hello Stephen,
I am looking at adding turn costs to the one-to-many dijkstra
implementation in pgRouting 2.4.1. I found that you created a
discussion on this topic
(https://github.com/pgRouting/pgrouting/issues/610
<https://github.com/pgRouting/pgrouting/issues/610>
<https://github.com/pgRouting/pgrouting/issues/610>>\) and wanted
to share my ideas with you, and possibly get some feedback. If I
am successful, I plan to commit the code to pgRouting for anyone
to use.My original plan was to:
1) Create a turn restriction table, similar to pgr_trsp, that
contains, a pair of edges, and a cost for going from one of
those edges to the other.2) Pass this turn restriction table, a reference to the
predecessor map, and a reference to the weight map into a boost
dijkstra visitor.3) Every time the visitor examines an edge, it looks at the
predecessor map to figure out which edge it got to the current
vertex from. It will then look at the turn restriction table and
see if there is an added cost for going from the edge it came
from to the edge it is examining. If there is, it will update
the weight map and add the appropriate weight to the edge that
it is examining.I was able to implement this and it did exactly what I planned.
The problem is, my plan does not solve the turn restriction
shortest path problem. It adds costs to edges based on turns
that it makes, given the predecessor of the current vertex, but
it does not check to see if a different possible predecessor to
the current vertex would have been a better choice, given the
turn restrictions.I am now thinking about how to do this (ie. check to see if a
different possible predecessor to the current vertex would lead
to a lower cost path to the next vertex, given the turn
restrictions). In my mind, this would look like:1) For each incoming edge of the current vertex, add the weight
of that edge (gotten from the weight map) to the distance of the
other vertex that this edge connects to (gotten from the
distance map), apply the appropriate turn cost for this edge and
the edge that connects the current vertex to the vertex we want
to go to.2) Determine the lowest cost possible path
3) Update the predecessor map and replace the predecessor of the
current vertex with the vertex that we found to be in the lowest
cost possible path4) Update the distance map and replace the distance of the
current vertex with the new distance, based on the new predecessorThe problem is, I still don't think that this approach will
solve the turn restriction shortest path for every possible
graph. If one of the incoming edges to the current vertex has
not yet been examined, then we will not know the distance of the
vertex that it is connected to.If you are still reading, please let me know if you have any
input on whether or not this approach is completely insane,
whether or not you have any input on how to make this work, or
any other input you think might be useful for someone who wants
to get a one-to-many trsp algorithm that is comparable in
run-time to boost dijkstra.In this stackoverflow post:
http://stackoverflow.com/questions/32116289/how-turn-restrictions-in-k-shortest-paths-algorithm-in-pgrouting
<http://stackoverflow.com/questions/32116289/how-turn-restrictions-in-k-shortest-paths-algorithm-in-pgrouting>
, you said that one should just write a wrapper that calls
pgr_trsp for each target, but I am working with around 100->500
targets, a 200,000 edge map, and run-time is critical.Thanks for reading and thank you for helping make some great
open source software,Anthony
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus--
Georepublic UG (haftungsbeschränkt)
Salzmannstraße 44,
81739 München, GermanyVicky Vergara
Operations ResearcheMail: vicky@georepublic.de <http://georepublic.de>
Web:https://georepublic.infoTel: +49 (089) 4161 7698-1
Fax: +49 (089) 4161 7698-9Commercial register: Amtsgericht München, HRB 181428
CEO: Daniel Kastl
