I just tried building the pgRouting 2.1 manual in PDF format.
Building the html version went off without a hitch, but I ran into some
stumbling blocks with PDF, but was able to overcome them.
I'm wondering if this is just an issue with my setup or some undocumented
issue?
I was building on Windows using MikTex (for pdf2latex conversion).
To overcome the build issues I was having, I had to edit the generated
build/doc/latex/en/pgRoutingDocumentation.tex
Adding line:
\usepackage{underscore}
Right after the
\usepackage{multirow}
After that I got an out of buffer size error -- which I discovered has to do
with file names, so I edited the .tex
renaming images after_node_net.png and before_node_net.png to
and replacing the names in the pgRoutingDocumentation.tex
Do other people have these issues or is it just me?
Regina
