OK, when you make your distance matrix, the values in it are based on the cost function that you use to generate it.
So for example it you have two columns in your edge table, like cost_distance and cost_time, then when you create your distance matrix and select the edges using cost_time as cost, then your distance matrix is based on time. The units are whatever you use in the columns. Likewise if you build your matrix with cost_distance as cost then your distance matrix is based on the cost_distance values in whatever units you used for that column.
TSP ONLY orders the nodes, if you need the routes between the nodes then those have to be computed again based on the ordered nodes.
I say "again", because we computed them internally when we computed the distance matrix. But these were not cached anywhere, so they will have to be computed again after the TSP has ordered the nodes.
I have been side tracked, looking into whether or not I can integrate a local OSRM instance into pgrouting because if you don't need the dynamic graph definition, ie: you can live with a static graph definition, then OSRM would allow for some significant performance gains in computing distance matrices and routes.
I have also looked at some additional wrapping of the TSP and routing with an eye toward caching the routes generated in dmatrix creation for later use to generate the routes.
So the bottom line is you are needing the stuff I am developing. I need it also, but it takes time to design and code stuff, especially while putting out other fires. And all the code (whatever that might turn out to be) is not there yet.
I guess I'm missing something but after reading everything thoroughly
I'm not getting there...
Helder Alves
+351912384076
On Sun, Nov 10, 2013 at 2:40 PM, Stephen Woodbridge
<woodbri@swoodbridge.com <mailto:woodbri@swoodbridge.com>> wrote:
Hello Helder,
Did you notice that I checked in a new version of
pgr_vidstodmatrix() with a different signature that is 3x faster.
Also the function you are using below will likely go away as it was
just a quick prototype so you should move your code to the new function.
Thank you for giving them a try.
-Steve
On 11/5/2013 7:53 PM, Helder Alves wrote:
It's working! Thanks!
Helder Alves
+351912384076 <tel:%2B351912384076>
On Mon, Nov 4, 2013 at 6:42 PM, Stephen Woodbridge
<mailto:woodbri@swoodbridge.__com
<mailto:woodbri@swoodbridge.com>>> wrote:
You ways table does not have a column named "id" for now
you might
have to set up a view like:
create view v_ways as select your_id_col as id, source,
target, cost
from ways;
then try your query replacing 'ways' with 'v_ways'
-Steve
On 11/4/2013 11:31 AM, Helder Alves wrote:
Hi Steve,
select dmatrix::float8
from pgr_vidstodmatrix(
pgr_pointstovids(
pgr_texttopoints('-7.50501,40.____26310;-7.48864,40.17530;-7.____49901,40.13950;-7.57596,40.____12350;-7.61591,40.13230;-7.____61935,40.13230;-7.67235,40.____13580;-7.67087,40.13660;-7.____66510,40.13860;-7.74559,40.____15640;-7.74588,40.15730;-7.____74746,40.15690;-7.74922,40.____15540;-7.74926,40.15310;-7.____73537,40.14230;-7.63556,40.____18920;-7.64849,40.22630;-7.____62354,40.25680;-7.62425,40.____26280;-7.62223,40.25830;-7.____62179,40.25680;-7.62116,40.____25580;-7.64803,40.22390;-7.____63916,40.20560;-7.63664,40.____20250;-7.63767,40.19970;-7.____63623,40.20000;-7.56974,40.____26710;-7.49104,40.26500;-7.____50473,40.26320',
4326),
'ways'),
4326),
'ways')
While running the query above, I got the error below.
column "id" does not exist
LINE 1: select id, source, target, cost from ways
where
the_geom && ...
QUERY: select id, source, target, cost from ways
where
the_geom &&
'____0103000020E6100000010000000500______00002E34D769A4651FC05EBA490C02______0344402E34D769A4651FC0492EFF21______FD2E444076ABE7A4F78D1DC0492EFF______21FD2E444076ABE7A4F78D1DC05EBA______490C020344402E34D769A4651FC05E____BA490C02034440'::geometry
CONTEXT: PL/pgSQL function
pgr_vidstodmatrix(integer,____geometry,text,double
precision) line
57 at FOR over EXECUTE statement
I guess it's some kind of bug, which is something it
may happen
when we
are testing something from the develop branch!
Can you help me with this?
Thanks!
Helder Alves
+351912384076 <tel:%2B351912384076> <tel:%2B351912384076>
On Wed, Oct 9, 2013 at 5:26 PM, Stephen Woodbridge
<mailto:woodbri@swoodbridge.__com <mailto:woodbri@swoodbridge.com>>
<mailto:woodbri@swoodbridge.>____com
<mailto:woodbri@swoodbridge.com>>>> wrote:
Another common problem is orienting the returned
edges so
they match
up end to end. For example:
select st_astext(the_geom) from
pgr_tsptrsp(pgr_texttopoints('______2,0;2,1;3,1;2,2;4,1;4,2;2,__3;__3,__2',
0), 'edge_table', true, true) a, edge_table b where
a.id2=b.id <http://b.id> <http://b.id>
<http://b.id>;
"LINESTRING(2 1,2 2)"
"LINESTRING(2 2,3 2)"
"LINESTRING(3 2,4 2)"
"LINESTRING(4 1,4 2)" -- needs to be flipped
"LINESTRING(3 1,4 1)" -- needs to be flipped
"LINESTRING(2 1,3 1)" -- needs to be flipped
"LINESTRING(2 2,2 3)"
"LINESTRING(2 2,2 3)" -- needs to be flipped
"LINESTRING(2 1,2 2)" -- needs to be flipped
"LINESTRING(2 0,2 1)" -- needs to be flipped
So I wrote a new function pgr_flipedges(ga
geometry) that
can be
used like this:
select st_astext(e) from (
select
unnest(pgr_flipedges(array_______agg(the_geom))) as e
from
edge_table b
where a.id2=b.id <http://b.id> <http://b.id>
<http://b.id>
) as foo;
"LINESTRING(4 2,4 1)"
"LINESTRING(4 1,3 1)"
"LINESTRING(3 1,2 1)"
"LINESTRING(2 3,2 2)"
"LINESTRING(2 2,2 1)"
"LINESTRING(2 1,2 0)"
Notice how all the edges have been flipped to return a
continuous
path from start to end of each adjacent segment in
the path.
-Steve
All the mentioned code will eventually get checked
into
pgrouting
2.1 development branch once it is stable and I
have test
cases and
docs written for it.
-Steve
On 10/9/2013 10:29 AM, Stephen Woodbridge wrote:
I have been playing with some tools to allow
me to
integrate TSP
optimization into a web application. I thought
I would
share
what I have
come up with for comments. One of the things I
did was
to try
and break
down the process into reusable modular
functions. For
example
there are
two functions to compute the distance matrix
based on
either
Euclidean
or kdijkstra distances. One could add other
functions
to compute
them
based on other algorithms. Also each function
does one
conversion so it
is simple to understand and easy to test or
replace
with another
function that does the transformation in a
different
way. Then
the final
function glues all the pieces together to get
the final
result.
Goal:
take a string or points like "x,y;x,y;x,y;..." and
compute the TSP
solution to order the points based on either
Euclidean
distance or
network distances, then compute the route
through the
network
and return
the route geometry.
Solution in progress:
1. text to point geometry *
pgr_texttopoints(pnts text, srid integer
DEFAULT(4326))
2. points to vertex ids *
pgr_pointtoedgenode(edges text, pnt
geometry, tol
float8)
pgr_pointstovids(pnts geometry, edges
text, tol
float8
DEFAULT(0.01))
3. points to edge ids **
4. points to [edge id, pct] **
5. points to Euclidean distance matrix *
pgr_points2dmatrix(pnts geometry, OUT
dmatrix double
precision,
OUT ids integer)
6. vertex ids to kdijkstra distance matrix *
pgr_vidstodmatrix(IN vids integer, IN pnts
geometry, IN
edges
text, tol float8 DEFAULT(0.1), OUT dmatrix double
precision,
OUT ids
integer)
7. distance matrix to TSP to ordered list ***
select * from pgr_tsp(
(select dmatrix::float8
pgr_pointstovids(
pgr_texttopoints('2,0;2,1;3,1;______2,2;4,1;4,2;2,3;3,2',
0),
'edge_table'),
pgr_texttopoints('2,0;2,1;3,1;______2,2;4,1;4,2;2,3;3,2', 0),
'edge_table')
1
8. reorder vids based on ordered list *
9. compute trsp for pairs of vids in ordered
list *,!
pgr_trsp(sql text, vids integer,
directed boolean,
has_reverse_cost boolean, turn_restrict_sql text
DEFAULT NULL::text)
pgr_tsptrsp(pnts geometry, edges text,
directed
boolean,
has_reverse_cost boolean, tol float8 DEFAULT(0.1),
turn_restrict_sql
text DEFAULT NULL::text)
select * from
0),
'edge_table', true, true);
10. output results **
NOTES:
* - done
** - not done
*** - already part of 2.0
! - computing a route through via points can be
optimized in the
C/C++
code for better performance, but I currently just
prototyped
this up in
plpgsql
Thoughts,
-Steve
_____________________________________________________
pgrouting-dev mailing list
pgrouting-dev@lists.osgeo.org <mailto:pgrouting-dev@lists.osgeo.org>
<mailto:pgrouting-dev@lists.__osgeo.org
<mailto:pgrouting-dev@lists.osgeo.org>>
<mailto:pgrouting-dev@lists.>____osgeo.org <http://osgeo.org>
<mailto:pgrouting-dev@lists.osgeo.org>>>
http://lists.osgeo.org/______mailman/listinfo/pgrouting-dev
<http://lists.osgeo.org/____mailman/listinfo/pgrouting-dev>
<http://lists.osgeo.org/__mailman/listinfo/pgrouting-dev>\_\_>
<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>\_\_>\_\_>
