You can do this with a modified version of the driving distance code that allows you to extract the solved Dijkstra tree so you can extract all the needed routes from the start node to all the other "cities".
The other potential performance boost would be to write a solver where you pass it the graph edges and a list of start and end nodes. Then you can build the graph once and solve it for each pair of start, stop nodes. This would eliminate the multiple graph builds assuming that are all in the same graph region to start with. I would return results like:
Solving 86 shortest_paths:
Dijkstra (pgRouting shortest_path()): 27328 milliseconds
TRSP (pgRouting turn_restrict_shortest_path()): 22405 milliseconds
So it is somewhat faster, but I'm not getting the boost I was hoping for.
As far as I know, both of the heuristic based algorithms are broken in
pgRouting (shooting star has the one-way bug, and a-star has a memory
management issue).
A-Star will completely hose PostgreSQL if I run A-Star in combination
with any other pgRouting function in the same process ID (procpid from
pg_stat_activity).
Here is an output of PostgreSQL log when I run a-star:
terminate called after throwing an instance of 'std::bad_alloc'
what(): std::bad_alloc
LOG: server process (PID 23497) was terminated by signal 6: Aborted
LOG: terminating any other active server processes
WARNING: terminating connection because of crash of another server process
DETAIL: The postmaster has commanded this server process to roll back
the current transaction and exit, because another server process exited
abnormally and possibly corrupted shared memory.
HINT: In a moment you should be able to reconnect to the database and
repeat your command.
LOG: all server processes terminated; reinitializing
LOG: database system was interrupted; last known up at 2012-06-12
10:57:51 EDT
LOG: database system was not properly shut down; automatic recovery in
progress
LOG: redo starts at E2/94CC82B0
LOG: record with zero length at E2/94CF7F90
LOG: redo done at E2/94CF7F40
LOG: database system is ready to accept connections
LOG: autovacuum launcher started
On Tue, Jun 12, 2012 at 10:33 AM, Stephen Woodbridge
<woodbri@swoodbridge.com <mailto:woodbri@swoodbridge.com>> wrote:
On 6/12/2012 9:17 AM, Steve Horn wrote:
Was not able to find these libraries via package manager, but I
did get
pgRouting and dependencies installed manually.
The "cannot find -lgmp" referred to a dependency of CGAL that
needed to
be installed ( http://gmplib.org/manual/ Installing-GMP.html#
Installing-GMP
<http://gmplib.org/manual/Installing-GMP.html#Installing-GMP> )
Also of note is that CGAL needs a specific version of the Boost
libraries to work (1.41).
After successful pgRouting make/make install then I ran the
driving_distance function to test and got this:
“Error while loading shared libraries:
libboost_thread.so.1.41.0: cannot
open shared object file: No such file or directory"
Used the information in this blog to correct that error:
http://somethingididnotknow. wordpress.com/2012/02/17/fix-
the-error-while-loading- shared-libraries-libboost_
thread-so-1-48-0-cannot-open- shared-object-file-no-such-
file-or-directory-error/
<http://somethingididnotknow.wordpress.com/2012/02/17/fix-the-error-while-loading-shared-libraries-libboost_thread-so-1-48-0-cannot-open-shared-object-file-no-such-file-or-directory-error/>
Hope this helps someone in the future.
Steve: Haven't done a deep dive into the TRSP functionality -but
I am
impressed at the surface. Does it use an A Star algorithm at the
core?
I'm afraid I have not looked in detail at the exact algorithm but I
believe it uses a combination of Dijkstra that is node based and
then uses, edge based exploration to navigate around the turn
restrictions.
A Star requires a heuristic so you pass the end points of the edges
which we do not pass in TRSP, so we are not doing that. That might
be an interesting future enhancement that could speed TRSP up even
faster. My rough timing tests showed that performance was a little
slower than Dijkstra without any restrictions, but about 5x faster
than our broken Shooting Star.
Roni, If you have a chance it would be good if you could provide a
little more background information on how TRSP solves.
-Steve W
Thanks for your efforts on this!
On Mon, Jun 11, 2012 at 8:26 PM, Stephen Woodbridge
<mailto:woodbri@swoodbridge. com
<mailto:woodbri@swoodbridge.com>>> wrote:
On 6/11/2012 7:58 PM, Steve Horn wrote:
Trying to manually build and install the gmp dependency for
cgal..but
I'm curious how you can install it through yum. The
searches you
provided do not turn up anything.
You probably need to google "centos cgal" and then add an
appropriate repository to yum. I forget the exact way to do
that.
I'm more familiar with apt get and adding repositories.
Does yum
work
similarly? Just curious and trying to learn. Thanks!
Yes, yum is the CentOS equivalent to apt-get. They both work in
similar ways. There were some good yum howto or tutorials that I
learned from when I needed to use it that I found via google.
-Steve
On Monday, June 11, 2012, Stephen Woodbridge wrote:
On 6/11/2012 3:41 PM, Steve Horn wrote:
Hello again
Trying to build and install the trsp branch on
my CentOS
linux box.
(Using
https://github.com/pgRouting/ pgrouting/wiki/Developer---
Getting-Started
<https://github.com/pgRouting/ pgrouting/wiki/Developer---
Getting-Started
Getting-Started
<https://github.com/pgRouting/pgrouting/wiki/Developer---Getting-Started>>>
as
a baseline)
Here is where I'm at:
# git clone https://github.com/pgRouting/
pgrouting.git
<https://github.com/pgRouting/ pgrouting.git
<https://github.com/pgRouting/pgrouting.git>>>
# cd pgrouting
//Hack around installing GAUL
# cmake -DWITH_TSP=ON -DWITH_DD=ON .
-- POSTGRESQL_EXECUTABLE is
POSTGRESQL_EXECUTABLE-NOTFOUND
-- Found PostgreSQL: /usr/include/postgresql/
include/server,
/usr/pgsql-9.1/lib/libpq.so
Boost headers were found here: /usr/include
Output directory for libraries is set to
/usr/pgsql-9.1/lib
Installation directory for libraries is set to
/usr/pgsql-9.1/lib and
for SQL files is set to /usr/share/pgrouting
/usr/pgsql-9.1/lib
-- Configuring done
-- Generating done
-- Build files have been written to:
/home/shorn/pgrouting
# make
Linking CXX shared library
../../../lib/librouting_tsp.so
*/usr/bin/ld: cannot find -lgmp //THIS APPEARS
TO BE
THE PROBLEM?*
collect2: ld returned 1 exit status
make[2]: *** [lib/librouting_tsp.so] Error 1
make[1]: *** [extra/tsp/src/CMakeFiles/
routing_tsp.dir/all] Error 2
make: *** [all] Error 2
Can anyone help me understand the error "Cannot
find -lgmp"?
For TSP you need to instal GUAL and for DD you need
the CGAL
libraries.
Try:
yum search libcgal
yum search cgal
You probably need the dev package also.
After you:
cd pgrouting
git checkout trsp ## switch to trsp branch
git pull
cmake -DWITH_TRSP=ON -DWITH_TSP=ON -DWITH_DD=ON .
-Steve
______________________________ _________________
pgrouting-dev mailing list
pgrouting-dev@lists.osgeo.org
<mailto:pgrouting-dev@lists.osgeo.org>
<mailto:pgrouting-dev@lists. osgeo.org
<mailto:pgrouting-dev@lists.osgeo.org>>
http://lists.osgeo.org/ mailman/listinfo/pgrouting-dev
<http://lists.osgeo.org/ mailman/listinfo/pgrouting-dev
<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev> > >
Steve Horn
Steve Horn
pgrouting-dev@lists.osgeo.org <mailto:pgrouting-dev@lists.osgeo.org>
Steve Horn
