Hello everyone,
Is the manual (pdf document) available at GitHub? There a few things I would like to correct. Regards,
Luís
Hello everyone,
Luís
Hi Luís,
Thanks a lot for your offer!
Yes, everything is available on Github, so you could just fork the repository and then submit a pull request with your changes.
There are several sources:
If you want to change something on the website: https://github.com/pgrouting/website
If you want to change the documentation (http://docs.pgrouting.org/), then the relevant source files are within the pgRouting repository:
https://github.com/pgRouting/pgrouting
See also: https://github.com/pgRouting/pgrouting/wiki#documentation
If you have more questions, feel free to ask.
Daniel
On Thu, Apr 3, 2014 at 4:13 PM, Luís de Sousa <luis.a.de.sousa@gmail.com> wrote:
Hello everyone,
Luís
pgrouting-dev mailing list
pgrouting-dev@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
Georepublic UG & Georepublic Japan
eMail: daniel.kastl@georepublic.de
Web: http://georepublic.info
