I am kind of new in using pgrouting and I would really like your help.
I have imported a road network, called "testNic" (from shapefile) into a PostgreSQL database using QGIS and pgAdmin. Then, I added the necessary columns, source, target and cost, and created the geom_idx. The problem that I am facing is that I cannot create the topology using the query:
I get the following error, and i can't locate where the mistake is.
NOTICE: CREATE TABLE will create implicit sequence "vertices_tmp_id_seq" for serial column "vertices_tmp.id"
CONTEXT: SQL statement "CREATE TABLE vertices_tmp (id serial)"
PL/pgSQL function "assign_vertex_id" line 14 at EXECUTE statement
ERROR: find_srid() - couldnt find the corresponding SRID - is the geometry registered in the GEOMETRY_COLUMNS table? Is there an uppercase/lowercase missmatch?
CONTEXT: PL/pgSQL function "assign_vertex_id" line 20 at assignment
********** Error **********
SQL state: P0001
Context: PL/pgSQL function "assign_vertex_id" line 20 at assignment
As the error says, there seems to be something wrong with your SRID. You should check if the constraint on “the_geom” and the entry in the “geometry_columns” table are OK? Does it have an SRID or is it set -1?
I have imported a road network, called “testNic” (from shapefile) into a PostgreSQL database using QGIS and pgAdmin. Then, I added the necessary columns, source, target and cost, and created the geom_idx. The problem that I am facing is that I cannot create the topology using the query:
I get the following error, and i can’t locate where the mistake is.
NOTICE: CREATE TABLE will create implicit sequence “vertices_tmp_id_seq” for serial column “vertices_tmp.id”
CONTEXT: SQL statement “CREATE TABLE vertices_tmp (id serial)”
PL/pgSQL function “assign_vertex_id” line 14 at EXECUTE statement
CONTEXT: PL/pgSQL function “assign_vertex_id” line 20 at assignment
SQL state: P0001
Context: PL/pgSQL function “assign_vertex_id” line 20 at assignment
SQL state: P0001
SQL state: P0001
Also, when you ran assign_vetrix_id() your tolerance was something like 0.000001 which is appropriate if your data is in degrees, but this Mercator projection is in meters so your tolerance should be something in a range like 5.0 - 0.5, maybe start with 1.0 and see how that works. if you rebuild you table and try different values for tolerance, you can look at the number of unique node numbers. When the number suddenly gets smaller you probably have it too large.
The shapefile which i imported was in google web mercator, so during
the import I set the SRID = 900913. The geom constraint has the same
value too.
How can I do the necessary checks?
With Regards,
Stephanos Charalambous
On 17 Φεβ 2011, at 16:58, Daniel Kastl <daniel@georepublic.de
<mailto:daniel@georepublic.de>> wrote:
Hello Stephanos,
SRID. You should check if the constraint on "the_geom" and the
entry in the "geometry_columns" table are OK? Does it have an SRID
or is it set -1?
your help.
mistake is.
<http://vertices_tmp.id>"
assignment
SQL state: P0001
assignment
I tried the thinks that you have told me.
1. As Daniel suggested, I ran the command: psql gis "C:\Users\User\Desktop\900913.sql" in the psql shell and when I checked the file "spatial_ref_sys.sql", the entry 900913 is in the table.
2. As Stephen suggested, I edited the epsg file in the "proj" folder and added the Spherical Mercator projection entry.
3. I changed the assign_vertex_id command to:
SELECT assign_vertex_id('testNic', 1.0, 'the_geom', 'gid')
4. Restart Computer
THE RESULT: The same error occurs.
Where did I do wrong?
Stephanos
--- Στις Πέμ., 17/02/11, ο/η Stephen Woodbridge <woodbri@swoodbridge.com> έγραψε:
Από: Stephen Woodbridge <woodbri@swoodbridge.com>
Θέμα: Re: [pgrouting-dev] Cannot create topology
Προς: pgrouting-dev@lists.osgeo.org
Ημερομηνία: Πέμπτη, 17 Φεβρουάριος 2011, 20:27
You might also need to add it to:
something like
but this
be something
that works.
tolerance, you can
suddenly gets
-Steve
On 2/17/2011 1:14 PM, Daniel Kastl wrote:
> I think SRID = 900913 is not in the spatial_ref_sys
table, if you're
> using an older version of PostGIS.
> You can take it from here:
> http://trac.openstreetmap.org/browser/applications/utils/export/osm2pgsql/900913.sql
> <http://trac.openstreetmap.org/browser/applications/utils/export/osm2pgsql/900913.sql>Daniel
> 2011/2/18 Stephanos Charalambous <stephanos_ch@yahoo.gr
> <mailto:stephanos_ch@yahoo.gr>>
> Thanks Daniel for the quick
response.
> value too.
checks?
> With Regards,
wrote:
>> Hello Stephanos,
>> entry in the
>> or is it set -1?
>> Daniel
>> 2011/2/17 Stephanos
Charalambous
>> <<mailto:stephanos_ch@yahoo.gr>stephanos_ch@yahoo.gr
>> Hello,
>> I am kind of
>> your help.
>> I have
>> shapefile)
>> Then, I
>> and created
>> I cannot
>> SELECT
assign_vertex_id('testNic', 0.00001, 'the_geom', 'gid');
>> I get the
>> mistake is.
implicit sequence
"vertices_tmp.id
>> PL/pgSQL
>> ERROR:
>> the geometry
>> there an
>> assignment
Error **********
>> ERROR:
>> the geometry
>> there an
>> SQL state:
P0001
>> Context:
>> assignment
>> Any help
would be really appreciated.
>> Regards
>> Stephanos
Charalambous
pgrouting-dev mailing list
<mailto:pgrouting-dev@lists.osgeo.org>pgrouting-dev@lists.osgeo.org
>> <http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
>> Georepublic UG &
Georepublic Japan
>> eMail:
>> <mailto:daniel.kastl@georepublic.de>daniel.kastl@georepublic.de
>> Web: <http://georepublic.de/>http://georepublic.de
list
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl@georepublic.de
> Web: http://georepublic.de/>
As Daniel suggested, I ran the command: psql gis “C:\Users\User\Desktop\900913.sql” in the psql shell and when I checked the file “spatial_ref_sys.sql”, the entry 900913 is in the table.
As Stephen suggested, I edited the epsg file in the “proj” folder and added the Spherical Mercator projection entry.
SELECT assign_vertex_id(‘testNic’, 1.0, ‘the_geom’, ‘gid’)
Restart Computer
That’s not clear to me. Would you be able to use a newer version of PostGIS? I think they contain 900913 projection.
Or you could try to reproject your geometry once to WGS84 and then try again and see if this makes a difference.
something like
but this
be something
that works.
tolerance, you can
suddenly gets
entry in the
or is it set -1?
I am kind of
your help.
I have
shapefile)
Then, I
and created
I cannot
PL/pgSQL
ERROR:
the geometry
there an
assignment
Error **********
ERROR:
the geometry
there an
SQL state:
P0001
Context:
assignment
I also try to build topology on a WGS84 shapefile with no result
This could be a problem with my geometry data?
Hi Stephanos,
I’m sorry to hear that your so much struggling with this.
As this function seems to work for the majority of users, it could be a problem with your data as you said.
Have you tried to look at the workshop? The data there is in WGS84 projection, but there is a data.tar.gz file with sample data with and without topology. You could try it once and compare it with your data.
