Hi Everyone ,
I have been implementing Capacitated vehicle routing problem with time windows as my gsoc project under pgrouting . The most important task is the optimization part(tabu search here) for which by far i have implemented 3 different moves to avoid local minima but still the solution is not very close to the benchmark test results( http://web.cba.neu.edu/~msolomon/problems.htm ).
For understanding purpose , i am explaining the structure of the solution a bit .Lets say the solution is called a collection of tours . Each tour is a collection of orders served by a vehicle .
The three different moves are :
- Remove an order from one tour and insert into another tour
What i do here is iterate over each of the tours, choose an order remove it from one of the tours and insert it into another , update the final solution if it is better than the previous best solution then we swap the best solution with this solution and mark the move as tabu move .
This move is a better version of the previous one , but here what i do is find the closest pair of orders in randomnly selected two tours and try to club them together and then again carry on with the same process as above .
In this move , instead of removing what i do is swap orders between any two tours and then have a look at the solution.
My optimizer keeps obtaining a local minima every now and then and i think the way the moves switch from one another is the trick here . so i am trying to figure out the best way in which the moves will switch among each other once the optimizer attains a local minima .
Currently i have not integrated my code with pgrouting and i have been testing only using the c++ code that i have . I am parsing the data for now and using it for my solver . I will intergrate it soon so that everyone can test it or use it . The code clean up is also required for now . Howver you can have a look at the code and solution of certain benchmark test cases here .
https://github.com/pgRouting/pgrouting/tree/gsoc-cvrptw/src/cvrptw/tester
Feel free to suggest anything .
Thanks and regards ,
Mukul
