I am using dijkstra_sp function on my table names roads
my table has the geometry column named geometry
When I execute this sql
SELECT the_geom FROM dijkstra_sp(‘roads’);
I am getting this error
ERROR: column “geometry” does not exist
Position: 47
but if I change my table roads geometry column to the_geom it works.
Is there anyway to do routing on table which has different geometry column other than the_geom
Rashad
SELECT the_geom FROM dijkstra_sp('roads');
ERROR: column "geometry" does not exist
Position: 47
Look at the plpgsql wrapper functions. You can probably just copy the one you need to something like my_dijkstra_sp and make changes as appropriate to your needs. I have done this many times. If you column name changes a lot, you could pass in the name of your geometry column and have the wrapper script change the queries to use that, like my_dijkstra_sp('roads', 'geometry').
-Steve
