Hi Anton,
I'm looking at boost_drivedist.cpp with the idea of clone it to also return the predecessor with each record output, but I have not worked in C++ before. So I think I have the idea but want to bounce it off you first.
vertex_descriptor source_vertex = vertex( source_vertex_id, graph );
std::vector<vertex_descriptor> predecessors(num_vertices(graph));
std::vector<float8> distances(num_vertices(graph));
dijkstra_shortest_paths(graph, source_vertex,
predecessor_map(&predecessors[0])
.weight_map(get(&Edge::cost, graph))
.distance_map(&distances[0]));
graph_traits < graph_t >::vertex_iterator vi, vend;
vector<path_element> path_vector; // <<<< ???
int j=0;
for(tie(vi, vend) = vertices(graph); vi != vend; vi++) {
if( (double)distances[*vi] <= rdistance ) {
path_element pe;
graph_traits<graph_t>::vertex_descriptor s;
graph_traits<graph_t>::vertex_descriptor p; // <<<< add this
s = vertex(*vi, graph);
p = vertex(predecessor[*vi], graph); // <<<< add this
pe.vertex_id = graph[s].id;
pe.parent_id = graph[p].id; // <<<< add this
pe.edge_id = graph[s].edge_id;
pe.cost = distances[*vi];
path_vector.push_back( pe );
if( path_vector.size() == 0 ) {
*err_msg = (char *)"No path found";
return 0;
vector<path_element>::iterator itr;
*path = (path_element_t *) malloc( sizeof(path_element_t) *
(path_vector.size() + 1) );
*path_count = path_vector.size();
for(j=0,itr=path_vector.begin();itr != path_vector.end();itr++,j++) {
path_element pe = *itr;
(*path)[j].vertex_id = pe.vertex_id;
(*path)[j].parent_id = pe.parent_id; // <<<< add this
(*path)[j].edge_id = pe.edge_id;
(*path)[j].cost = pe.cost;
return EXIT_SUCCESS;
So in addition to the above 3 lines, I would need to modify core/src/dijkstra.h
typedef struct path_element
int vertex_id;
int parent_id; // <<< add this
int edge_id;
float8 cost;
} path_element_t;
What I'm not sure on is how (or if it is possible) to modify path_element pe to include parent_id item.
And finally in the C wrapper to this function I would need to update parent_id along with vertex_id to uncompress the range shift that was done.
Does this look like it will work? Did I forget anything?
Thoughts?
-Steve
