Daniel,
I'm not a cmake expert in fact I hardly know anything about it, but looking at the file I would assume that if you want to redefine it in cmake then you would replace the existing line with something like:
IF (NOT SQL_INSTALL_PATH)
SET(SQL_INSTALL_PATH /usr/share/pgrouting)
ENDIF(NOT SQL_INSTALL_PATH)
And then when you run want to override it you do something like:
SQL_INSTALL_PATH=/opt/emap/pgrouting cmake
or maybe
cmake SQL_INSTALL_PATH=/opt/emap/pgrouting
-Steve W
On 12/1/2010 9:36 PM, Daniel Kastl wrote:
This is an interesting question.
Actually (at least I) haven't thought about this yet.
I know that at least SQL install path is defined in line 67 in the file:
https://github.com/pgRouting/pgrouting/blob/v1.05/CMakeLists.txt#L67
(I actually just changed it to /usr/share/pgrouting recently in the
development branch, because "postlbs" was an idea in the beginning of
pgRouting we won't follow anymore)
I suppose that there should be a way to configure customs paths with
CMAKE, but without reading more about it I don't know how. SQL path
might be hard-coded though. If someone knows what could be done and
knows better, please let me know.
Daniel
2010/12/1 Emre Ersin <emree@mobiliz.com.tr <mailto:emree@mobiliz.com.tr>>
I am trying to compile all the mapserver stuff in a custom directory
/opt/emap. Everything built fine except pgrouting.
How can I define postgresql, cgal, boost directories during cmake
process?
I was hoping that they were defined in CMakeLists.txt but it seems I
am missing something...
/opt/src/pgrouting-1.05# cmake
-DBoost_INCLUDE_DIR=/opt/src/boost_1_45_0 -DWITH_DD=ON
-DCGAL_INCLUDE_DIR=/opt/emap -DCGAL_LIBRARIES=/opt/emap
-DPOSTGRESQL_INCLUDE_DIR=/opt/emap -DPOSTGRESQL_LIBRARIES=/opt/emap
-DSQL_INSTALL_PATH=/opt/emap .
-- The C compiler identification is GNU
-- The CXX compiler identification is GNU
-- Check for working C compiler: /usr/bin/gcc
-- Check for working C compiler: /usr/bin/gcc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
Boost headers were found here: /opt/src/boost_1_45_0
Output directory for libraries is set to /opt/emap/lib/postgresql
-- Found PGROUTING_CORE core: /opt/src/pgrouting-1.05/core/src
Installation directory for libraries is set to
/opt/emap/lib/postgresql and for SQL files is set to /usr/share/postlbs
-- Configuring done
WARNING: Target "routing_dd" requests linking to directory
"/opt/emap". Targets may link only to libraries. CMake is dropping
the item.
-- Generating done
-- Build files have been written to: /opt/src/pgrouting-1.05
Emre ERSİN
pgrouting-dev mailing list
pgrouting-dev@lists.osgeo.org <mailto:pgrouting-dev@lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
Georepublic UG & Georepublic Japan
eMail: daniel.kastl@georepublic.de <mailto:daniel.kastl@georepublic.de>
Web: http://georepublic.de/>
