I seem to have a memory issue in some code I am writing for c/c++ pg-route project. From the way that the code is behaving I seem to have a memory heap/corruption problem. Is there an easy way of using something like the electric fence or other memory checker on a pg route module or does the entire postgres database need to be recompiled?
Dave.
recompiled?
No need to recompile, check out
But if you're not afraid of recompiling, consider also this one:
http://wiki.postgresql.org/wiki/Valgrind
--strk;
recompiled?No need to recompile, check out
http://blog.cleverelephant.ca/2008/08/valgrinding-postgis.htmlBut if you're not afraid of recompiling, consider also this one:
Thanks Sandro, got it sorted.
--strk;
pgrouting-dev mailing list
pgrouting-dev@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
