Hi Jay,
On 9/17/2011 2:02 PM, Jay Mahadeokar wrote:
On Sat, Sep 17, 2011 at 11:20 PM, Daniel Kastl <daniel@georepublic.de
<mailto:daniel@georepublic.de>> wrote:
Hi list,
On Friday at FOSS4G in Denver I discussed with Steve about TSP, and
I want to share a bit of what we came up with:
* According to Steve there is a way to solve TSP without GA
(Genetic Algorithm), and that way we could get rid off GAUL
dependency and make it a "core" function.
I believe TSP is a NP Complete problem. So a polynomial time solution
does not exist. Steve, can you elaborate what heuristic might be used
besides GA?
This is a great question. You are correct the TSP is a NP Complete problem, but this is more an academic issue than a real world issue. For most use cases, I think a potential user would rather have an optimized solution in "web" time than an optimum solution in days, years, or life times depending on the number of points.
I did some research a few years ago into alternate faster solution and have an implementation of Simulated Annealing TSP:
http://www.google.com/#q=synthetic+annealing+TSP
This does a good job but it will give different results for the same input matrix if you change the row order. What I like about this solution is that it can handle a large number of points (10's-100's) very quickly and give reasonable results.
It also looks like there are a few algorithms with code on the link above that might be candidates. At any rate, I have code that I used here:
http://imaptools.com/cgi-bin/tsp.cgi
For a fast demo just copy and past the list of cities into the textbox and click solve. This little demo works by, computing the lat-lon for a city in the US, and then populating the distance matrix with the straight line distance between the points, and passing that to the TSP solver.
The code I'm using for this demo is based on code I found in 2001-2002 and at the time I was pretty careful about picking up code that was in the public domain only. That said, I'm not sure what the licensing is or if we can even still contact the original authors. The is not that large or complex that we could not re-implement a clean version directly into pgRouting to remove the dependency on GAUL library.
Simulated Annealing is a very cool algorithm that has MANY uses beyond just doing TSP.
+1 and getting ride of GAUL and CGAL dependencies.
-Steve
* Instead of calculation of a distance matrix within the TSP
function, the distance matrix could be passed as a "SELECT".
Then the user could decide the way distances should be
calculated. And APSP would be a nice way to calculate a distance
matrix for example.
+1 for use of APSP!
Any other ideas how to improve the current implementation of TSP?
Do you have some other use cases with specific requirements?
Daniel
Georepublic UG & Georepublic Japan
eMail: daniel.kastl@georepublic.de <mailto:daniel.kastl@georepublic.de>
Web: http://georepublic.de/>
pgrouting-dev mailing list
pgrouting-dev@lists.osgeo.org <mailto:pgrouting-dev@lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
-Jay Mahadeokar
