I have added a bit of documentation to “sew-devel-2_0” branch.
And I started using a theme named “Cloud Sphinx Theme” ( http://pythonhosted.org/cloud_sptheme/), because I like it and got tired of the default theme ![:wink: :wink:](/images/emoji/twitter/wink.png?v=12)
To be able to compile with documentation it’s now necessary to install the theme as well (http://pythonhosted.org/cloud_sptheme/install.html), which is easy if Sphinx is installed already.
I updated the Readme accordingly: https://github.com/pgrouting/pgrouting/tree/sew-devel-2_0#compilation
I started adding documentation for
I found it a bit inconvenient to have Dijkstra “core” and “wrapper” functions documented together, so I split it into two pages even if the function name is the same.
I tried to follow the documentation of PostGIS, but this only worked partly.
Daniel
Georepublic UG & Georepublic Japan
eMail: daniel.kastl@georepublic.de
Web: http://georepublic.de
Hi Daniel,
Thanks, this is great!
I'm wondering is we can't just save whatever theme we decide to use in git and reference it from there?
Also I an thinking that we should install out doc when we do make install but I'm not sure where they should get installed to.
We should probably note in the Readme that the built doc tree exists in the build/html/
Lots of good work on your part.
-Steve
On 5/5/2013 11:37 AM, Daniel Kastl wrote:
I have added a bit of documentation to "sew-devel-2_0" branch.
And I started using a theme named "Cloud Sphinx Theme" (
To be able to compile with documentation it's now necessary to install
* Dijkstra
* Return types
For the functions I'm following
https://docs.google.com/spreadsheet/ccc?key=0AiIg1pkkh_MRdGQzOEhyaXlndkN3eHdGNkpyQ0pMZFE&usp=sharing
I found it a bit inconvenient to have Dijkstra "core" and "wrapper"
Daniel
eMail: daniel.kastl@georepublic.de <mailto:daniel.kastl@georepublic.de>
Web: http://georepublic.de/>
pgrouting-dev mailing list
pgrouting-dev@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
