On 2/19/2012 7:20 PM, Steve Horn wrote:
Steve,
I've been working with the driving_distance function in pgRouting, and
as far as I can tell it is one contour at a time.
Yeah, digging through the code that was my conclusion also.
A possible way to improve the function is to make the result set a
little more useful. If I was able to follow a path from the centerpoint
to the extent of the contour via a tree structure I would be able to
create one contour for a maximum radius, then on the client derive
countours for less time.
I have done some work on this for some projects that I have worked on, but it is all outside pgRouting and the database. I have a modified drivingdistance function somewhere that does the following.
The tuple returned could be something like:
vertex_id, parent_vertex_id, cost
I used this when I was trying to develop a map matching algorithm. For driving distance I give it a max cutoff and a slice then get all the points for the max cutoff and compute all the contours at once. If you take the x,y of the node and z=cost, you can build a 3D triangulated surface and slice it into multiple contours.
Another improvement to the function would be to return an extra edge
past the max cost (or make that an option). I think currently the
algorithm will not return any edges that put the total cost past the
input cost parameter. My thought is I could take the extra edge and then
interpolate the point on the line that meets my cost exactly (or, even
better - have the algorithm compute this).
Agreed, I did this in my version of the code. If I get some time or a contract to support it, I want to clean up what I have done outside of pgRouting and move it into pgRouting.
The problem is the coding up cool little algorithms is the 10% of the work that is fun and it takes 90% more effort to clean up the code, check it in, write documentation, etc.
We really need to get a developer that is interested in pulling together a release and helping to build out our testing and release tools.
-Steve
On Sun, Feb 19, 2012 at 3:01 PM, Stephen Woodbridge
<woodbri@swoodbridge.com <mailto:woodbri@swoodbridge.com>> wrote:
Since I wrote my own driving distance code years ago and have been
happy with it, I have just now looked into how the pgRouting code works.
Does this code return multiple contours in a single request? How?
It looks like this code can only return a single contour for a
single request. This means if I want say contours for 5, 10, 15
minutes that I have to make 3 requests which means fetching the
data, building the graph and creating the contours all have to be
processed 3 times. It seem that it would make more sense to setup
the problem once and compute all the contours at once and return 3
results.
Thoughts?
-Steve
______________________________ _________________
pgrouting-dev mailing list
pgrouting-dev@lists.osgeo.org <mailto:pgrouting-dev@lists.osgeo.org>
http://lists.osgeo.org/ mailman/listinfo/pgrouting-dev
<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
Steve Horn
http://www.stevehorn.cc
steve@stevehorn.cc
http://twitter.com/stevehorn
740-503-2300
