A solution of course is to escape the single quotes in the WITH queries, and then embed in the pgr_alphaShape as below. Hope this helps someone:
SELECT pgr_alphaShape('
WITH DD AS (
SELECT seq, id1 AS node, cost
FROM pgr_drivingDistance(
''SELECT id, source, target, cost FROM edge_table'',
7, 1.5, false, false
dd_points AS(
SELECT id, x, y
FROM vertex_table w, DD d
WHERE w.id <http://w.id> = d.node
SELECT * FROM dd_points
Best,
Steve
On 06/21/2013 04:39 PM, Stephen Mather wrote:
Ahem, sent before I was done:
WITH DD AS (
'SELECT id, source, target, cost FROM edge_table',
dd_points AS(
SELECT id, x, y
SELECT pgr_alphaShape('SELECT * FROM dd_points');
doesn't work...
ERROR: relation "dd_points" does not exist
I understand why this doesn't work, but I'm not sure how to work around.
Ok so it get's interesting trying to use embed one function within another, for example calculating driving distance and wrapping with alpha shape.
This is as far as I've gotten:
On 06/21/2013 04:07 PM, Stephen Mather wrote:
Hi All,
Having a great time with 2.0-develop. Question on pgr_drivingDistance. I added geometry to the test dataset and wrote the following query to return all points within driving distance:
WITH DD AS (
SELECT ST_AsText(the_geom)
A) Am I correct in my usage of this?
B) Am I correct in assuming there is no way (at this time) to return subsets of lines, similar to TSP?
Best,
Steve
pgrouting-dev mailing list
pgrouting-dev@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
