I discussed this with Roni and my approach is probably reasonable but there are a lot of details and corner cases that need to be dealt with. So I will probably leave these changes to Roni as he has a beter handle on it than I do. He is hoping to have some time this summer to work on this.
So I checked in his code fixes and enhancements into the develop branch. The enhancements only have the C++ code in GraphDefinition.{cpp,h} but this has not be exposed to the SQl yet because I think we should do this as part of making a clean consistent interface. You can see I started to work this out in the discussion below. But didn't get much further than that.
Hi Steve and all!
Do you have any advance on this matter? ![:slight_smile: :slight_smile:](/images/emoji/twitter/slight_smile.png?v=12)
Thanks!
Helder Alves
On Apr 14, 2014 4:05 PM, "Stephen Woodbridge" <woodbri@swoodbridge.com
<mailto:woodbri@swoodbridge.com>> wrote:
On 4/13/2014 3:08 PM, Ashraf Hossain wrote:
Dear Steve,
I am out of town in village, I will come back to you soon with
my thoughts.
Hi Roni,
No problem, enjoy your time being mostly disconnected from the net ![:slight_smile: :slight_smile:](/images/emoji/twitter/slight_smile.png?v=12)
Looking at GraphDefinition.cpp, I'm thinking that a small
refactoring might make it easier to deal with multi_dijkstra using
edges versus nodes. Something along the lines of:
vector<int> GraphDefinition::__makeVirtualNodes(vector<int>
edge_ids, vector<double> edge_parts);
This could take a list of edges and position on the edges and create
a vector of virtual nodes and add then to the graph and return
vector of the new virtual node ids. Then in multi_dijkstra you can
loop through these as the start and end nodes. If we only have one
start and end then the existing code could be change to work with
this vector.
And it would be easy to change or clone multi_dijkstra to add
options for one_to_many and many_to_many loops.
We could also eliminate the existing edge to edge version of
my_dijkstra or trivialize it to call multi_dijkstra where we pass it
just a vector of the start and end points. This would remove
redundant code and simplify testing and verification of the existing
code.
Any thoughts on this when you have a chance to look over the code.
I'm not sure what the best way to do this in GraphDefinition. It
looks like we have a few places where we check
if(is<Start|End>Virtual) when evaluating restrictions because this
gets a little trickier. If the node is a via point in the middle of
a restriction, then we will continue on that edge as if there is no
virtual node there, but if it is the first or last point in overall
route we will treat it like the start or end case as we do now. In
the case of one_to_many and many_to_many, the start and end points
would get treated as they are now also.
I'm thinking that with these changes, we could potentially also
replace pgr_dijkstra and pgr_kdijkstra with the trsp code so we have
one common code base for
pgr_dijkstra() - pgr_trsp() point_to_point
pgr_kdijkstra() - pgr_trsp() one_to_many
pgr_makeDistanceMatrix() - pgr_trsp() many_to_many
We would be able to support turn restrictions or not with all these
functions.
One question I have about trsp is when I do a dijkstra solution in
Boost, I solve the whole graph so in the kdijkstra case
(one_to_many) I make one solution of the graph and I can extract
paths to the "many" end nodes in the graph rather than doing
multiple solves like A-B, A-C, A-D, ...? Can we do the same (extract
multiple end points) in trsp? If so then many_to_many becomes (N *
one_to_many).
Hope this all makes some sense.
-Steve
Regards
Roni
On Sun, Apr 13, 2014 at 6:28 AM, Stephen Woodbridge
<woodbri@swoodbridge.com <mailto:woodbri@swoodbridge.com>
<mailto:woodbri@swoodbridge.__com
<mailto:woodbri@swoodbridge.com>>> wrote:
Hi Roni,
I hope you and your family are doing well.
I am well but have been very busy. I'm between some
contracts at the
moment and I am looking at the TRSP improvements you did
quite a
ways back to add the reverse cost and routing from nodes
A-B-C-...
Looking at multi_dijkstra it seems that I should be able to
mimic
that code based on how you clean up after each route A-B to
restart
for B-C and create a similar function that computes one to many
destinations, A-B, A-C, A-D, etc.
What do you think?
So for integrating this code, I probably need to implement
a family
of additional functions like:
Existing functions:
pgr_trsp(text, integer, integer, boolean, boolean)
-- node to node
pgr_trsp(text, integer, integer, boolean, boolean, text)
-- node to node with restrictions
pgr_trsp(text, integer, double precision, integer, double
precision,
boolean, boolean)
-- edge to edge
precision,
-- edge to edge with restrictions
pgr_trsp(text, integer, boolean, boolean, text)
-- array of nodes **this gets changed to use new code (1)**
pgr_trsp(text, integer, float8, boolean, boolean, text)
-- array of edges **this gets changed to use new code (2)**
(1) should plug directly into your code. I currently do
this in C by
calling your old code multiple times, but it will be more
efficient
to change this to call multi_dijkstra because we only build the
graph once.
(2) I currently do this in C by making multiple calls to
your old
code. The multi_dijkstra only accepts nodes, not edges, so
I'll look
at making a version that can be called by edges. Unless you
want to
do that ![:slight_smile: :slight_smile:](/images/emoji/twitter/slight_smile.png?v=12)
Then I think I would like to add a new argument to (1) and
(2) above
"boolean onetomany" and if it is true then we compute A-B,
A-C, A-D,
... and if it is false it will compute A-B-C-...
I'll have to think about how to return the results, but
that should
not be too hard.
TODO:
1. create function to support multi_dijkstra with edges
2. create new function onetomany_dijkstra for nodes
3. create new function onetomany_dijkstra for edges
4. update C code wrappers to support the above
5. develop test cases
6. write the documentation
7. check it in
Ok that is a bunch of work! Maybe I'll start with just
getting (1)
done so it calls your new code, and write a test case for
that. Then
tackle the rest.
Thoughts?
-Steve
_________________________________________________
pgrouting-dev mailing list
pgrouting-dev@lists.osgeo.org <mailto:pgrouting-dev@lists.osgeo.org>
http://lists.osgeo.org/__mailman/listinfo/pgrouting-dev
<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
