I think I have just submitted changes to the bidirectional dijkstra and astar routines the resolve the server crashes we were seeing. This closes on major outstanding bug against 2.0.
Razequl,
I made two simple changes to your code BiDirDijkstra.cpp and the astar version:
1. in BiDirDijkstra::initall I add:
m_vecNodeVector.reserve(maxNode + 1);
2. in BiDirDijkstra::bidir_dijkstra I move the call to initall(maxNode); to before construct_graph(edges, edge_count, maxNode);
This does two major things:
1. std::vector doubles the size of the array every time it needs to increase its size and then needs to copy the old data to the new area.
2. reserve() pre allocates all the memory we need once, which avoid realloc memory fragmentation and avoids the copy each time it reallocs so this improves performance.
Anytime you know how much space you are going to need you should reserve it up front.
So things look good for now.
-Steve
Hello,
I've just pulled from the develop branch and built fresh and I'm getting a server crash from pgr_bdastar. If I run exactly the same thing using pgr_astar, it works. This is using postgres 9.2.4 and postgis 2.0.3 from Homebrew on Mac 10.8.3
I'm still working on a bulk routing function using bdastar, but just realized that the regular version was crashing without my modifications. I'm happy to try to track this down, but have little knowledge of how to debug within postgresql. Any pointers would be appreciated.
Best,
Alec
On Jun 1, 2013, at 2:13 PM, Stephen Woodbridge <woodbri@swoodbridge.com> wrote:
Razequl,
-Steve
pgrouting-dev mailing list
pgrouting-dev@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
On 6/4/2013 3:53 PM, Alec Gosse wrote:
Hello,
I'm using pg9.2.4 and postgis 2.0.x or 2.1.0beta3dev and I fixed these issues I thought. Evidently not.
appreciated.
OK, start by uncommenting #define DEBUG 1 in both the C and C++ code. Then add more DBG('I got here message\n"). In the C++ code these messages get written to a file '/tmp/sew-debug' and you can do a tail -f on that in another window to see your progress.
This is likely a issue in the C++ code but it may also be something systemic about the way we are integrating code. If you build your own postgresql you might want to rebuild it with --enable-cassert option to configure which will put the database backend into a more rigorous memory check mode.
That is a start, I would be appy to help more if I can.
-Steve
Best, Alec
Razequl,
astar version:
1. in BiDirDijkstra::initall I add: m_vecNodeVector.reserve(maxNode
+ 1);
maxNode);
area.
Thanks, -Steve _______________________________________________
pgrouting-dev mailing list pgrouting-dev@lists.osgeo.org
_______________________________________________ pgrouting-dev mailing
On Wed, Jun 5, 2013 at 5:34 AM, Stephen Woodbridge
Hello,
appreciated.
check mode.
Hi Steve,
I have started a Wiki page to collect that kind of information, because
that's easier to find someday than a years old email thread:
https://github.com/pgRouting/pgrouting/wiki/Developer---How-to-debug
I have copied there a few collected notes.
Daniel
Georepublic UG & Georepublic Japan
eMail: daniel.kastl@georepublic.de
Web: http://georepublic.de
Daniel,
Thanks, I just added some more content to that.
-Steve
Hello,
appreciated.
Hi Steve,
Daniel
eMail: daniel.kastl@georepublic.de <mailto:daniel.kastl@georepublic.de>
Web: http://georepublic.de/>
It would seem that it was simply running out of memory due to giant default vector resize requests. Adding
m_vecEdgeVector.reserve(edge_count);
before the loop calling addEdge(..) in the construct_graph function seems to do the trick. Probably best to do m_vecNodeVector.reserve(maxNode) as well, just for good measure;
I recall seeing something similar to this discussed, but perhaps it was somewhere else in the code.
Alec
On Jun 4, 2013, at 4:34 PM, Stephen Woodbridge <woodbri@swoodbridge.com> wrote:
Hello,
appreciated.
-Steve
Best, Alec
Razequl,
astar version:
+ 1);
maxNode);
area.
Alec,
Yes, that is the change I made also. I thought I merged that into the develop, but maybe a missed some of them.
I will look at this again and make sure that is added in branch "develop" which is the current active development branch.
Thank you,
-Steve
m_vecEdgeVector.reserve(edge_count); before the loop calling
for good measure;
Alec
Hello,
Thanks, -Steve
Best, Alec
Razequl,
the astar version:
maxNode);
to the new area.
Hi Alec,
What branch are you working off of? sew-devel-2_0 or develop?
Because I checked in those fixes 4 days ago:
https://github.com/pgRouting/pgrouting/blob/develop/src/bd_astar/src/BiDirAStar.cpp
Look at line 72
Please make sure you are using branch "develop"
-Steve
Alec
Hello,
appreciated.
-Steve
Best, Alec
Razequl,
astar version:
+ 1);
maxNode);
area.
