Hi All,
Is (for the moment) OSM2pgrouting a zombie project, or has there been work to port this for 2.0? I’m using OSM2po at the moment, but thought I’d check in on status of free as in freedom alternatives.
Best,
Steve
Hi All,
Best,
Steve
On Tue, Jun 11, 2013 at 11:11 AM, Stephen Mather
<mather.stephen@gmail.com>wrote:
Hi All,
to port this for 2.0? I'm using OSM2po at the moment, but thought I'd
check in on status of free as in freedom alternatives.Thanks,
Best,
Steve
Hi Steve,
osm2pgrouting needs some work, because
1. Not compatible with PostGIS 2.0 and the new pgRouting 2.0
2. Cannot handle the new OSM bigint ID's
It was some years ago written by Daniel Wendt and then hosted together with
pgRouting and like this found its way to Github.
There is not much activity except some modifications over the years. But it
has so far worked and just recently we have the issues as described before.
Currently pgRouting has priority. If someone wants to fix the issues with
osm2pgrouting, then that's very welcome.
There is a good alternative to process OSM data, named "osm2po". But it's
not released under Open Source license, if that's OK for you.
Daniel
Georepublic UG & Georepublic Japan
eMail: daniel.kastl@georepublic.de
Web: http://georepublic.de
Hi Daniel,
I noticed the bigint issue-- I suppose this only became a problem a few months back... .
Re: 2.0, any sense of what API changes would affect osm2pgrouting? I might poke under the hood to procrastinate from other work... .
Best,
Steve
On 06/10/2013 11:01 PM, Daniel Kastl wrote:
On Tue, Jun 11, 2013 at 11:11 AM, Stephen Mather <mather.stephen@gmail.com <mailto:mather.stephen@gmail.com>> wrote:
Hi All,
been work to port this for 2.0? I'm using OSM2po at the moment,
but thought I'd check in on status of free as in freedom alternatives.Thanks,
Best,
SteveHi Steve,
2. Cannot handle the new OSM bigint ID'sIt was some years ago written by Daniel Wendt and then hosted together with pgRouting and like this found its way to Github.
There is not much activity except some modifications over the years. But it has so far worked and just recently we have the issues as described before.Currently pgRouting has priority. If someone wants to fix the issues with osm2pgrouting, then that's very welcome.
There is a good alternative to process OSM data, named "osm2po". But it's not released under Open Source license, if that's OK for you.Daniel
eMail: daniel.kastl@georepublic.de <mailto:daniel.kastl@georepublic.de>
Web: http://georepublic.de/>_______________________________________________
pgrouting-dev mailing list
pgrouting-dev@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
On Tue, Jun 11, 2013 at 12:10 PM, Stephen Mather
<stephen@smathermather.com>wrote:
Hi Daniel,
months back... .
There is an issue for this:
https://github.com/pgRouting/osm2pgrouting/issues/16
It should only affect function names, mainly pgr_createTopology:
I think this file:
https://github.com/pgRouting/osm2pgrouting/blob/master/src/Export2DB.cpp
Daniel
Best,
> wrote:Hi All,
work to port this for 2.0? I'm using OSM2po at the moment, but thought I'd
Best,
SteveHi Steve,
Web: http://georepublic.de_______________________________________________
pgrouting-dev mailing listpgrouting-dev@lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/pgrouting-dev_______________________________________________
Daniel,
I'm not sure all of the pgrouting code supports bigint, in fact, I'm pretty sure most of it does not. We would need to change all id variables to be declared "long int" in the C code and
We should probably open a ticket for this and assign it to 2.1.
-Steve
<stephen@smathermather.com <mailto:stephen@smathermather.com>> wrote:Hi Daniel,
few months back... .There is an issue for this:
https://github.com/pgRouting/osm2pgrouting/issues/16Re: 2.0, any sense of what API changes would affect osm2pgrouting?
I might poke under the hood to procrastinate from other work... .It should only affect function names, mainly pgr_createTopology:
I think this file:
https://github.com/pgRouting/osm2pgrouting/blob/master/src/Export2DB.cppDaniel
Best,
<mather.stephen@gmail.com <mailto:mather.stephen@gmail.com>> wrote:Hi All,
there been work to port this for 2.0? I'm using OSM2po at the
moment, but thought I'd check in on status of free as in
Best,
SteveHi Steve,
pgrouting-dev@lists.osgeo.org <mailto:pgrouting-dev@lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/pgrouting-dev--
On Tue, Jun 11, 2013 at 1:13 PM, Stephen Woodbridge <woodbri@swoodbridge.com
wrote:
Daniel,
to be declared "long int" in the C code andWe should probably open a ticket for this and assign it to 2.1.
Hi Steve,
I think the problem is not so much pgRouting as parsing OSM data, and the
current implementation cannot handle 32bit ID's.
There is lot of OSM data we don't want to use and which gets filtered by
osm2pgrouting (ie. POI's polygons, etc), but in OSM it has an ID.
It makes no sense to use original OSM ID's, but it's good to keep them as a
reference.
OSM network data also needs to be noded, so it's anyhow necessary to create
own ID's and I doubt we need bigint for that ... at least not for the near
future, I hope
Daniel
-Steve
<stephen@smathermather.com <mailto:stephen@smathermather.**com<stephen@smathermather.com>>>
wrote:Hi Daniel,
https://github.com/pgRouting/**osm2pgrouting/issues/16<https://github.com/pgRouting/osm2pgrouting/issues/16>Re: 2.0, any sense of what API changes would affect osm2pgrouting?
I think this file:
https://github.com/pgRouting/**osm2pgrouting/blob/master/src/**
Export2DB.cpp<https://github.com/pgRouting/osm2pgrouting/blob/master/src/Export2DB.cpp>Daniel
Best,
<mather.stephen@gmail.com <mailto:mather.stephen@gmail.**com<mather.stephen@gmail.com>>>
wrote:Hi All,
Best,
SteveHi Steve,
you.Daniel
<mailto:daniel.kastl@**georepublic.de <daniel.kastl@georepublic.de>>
Web: http://georepublic.de/>______________________________**_________________
pgrouting-dev@lists.osgeo.org <mailto:pgrouting-dev@lists.**
osgeo.org <pgrouting-dev@lists.osgeo.org>>
http://lists.osgeo.org/**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>______________________________**_________________
pgrouting-dev@lists.osgeo.org <mailto:pgrouting-dev@lists.**osgeo.org<pgrouting-dev@lists.osgeo.org>
eMail: daniel.kastl@georepublic.de <mailto:daniel.kastl@**georepublic.de<daniel.kastl@georepublic.de>
Hi Steve,
Today I have created a new “develop” branch [1] for osm2pgrouting, merged some pull requests, fixed conflicts and did some small changes.
If nothing went wrong, then the “develop” branch should now support 32bit ID’s and pgRouting 2.0 function names.
[1] https://github.com/pgRouting/osm2pgrouting/tree/develop
I just made one simple test with Bangladesh data and got 2 suspicious messages:
Classes table created
Adding tag types and classes to database…
ERROR: duplicate key value violates unique constraint “classes_pkey”
DETAIL: Key (id)=(100) already exists.
CONTEXT: COPY classes, line 28: “100 1 unclassified 1 50”
There is a new PRIMARY KEY added for the “id” attribute, so it will just fail to insert the same class id twice.
Not sure why this happens, but it seems no big issue. Before there was no unique constraint at all.
And in the end it reported
NOTICE: 0 out of 27919 edges processed
NOTICE: 10000 out of 27919 edges processed
NOTICE: 20000 out of 27919 edges processed
Create Topology failed:
On Tue, Jun 11, 2013 at 12:10 PM, Stephen Mather <stephen@smathermather.com> wrote:
Hi Daniel,
I noticed the bigint issue-- I suppose this only became a problem a few months back… .
Re: 2.0, any sense of what API changes would affect osm2pgrouting? I might poke under the hood to procrastinate from other work… .
Best,
_______________________________________________ pgrouting-dev mailing list [pgrouting-dev@lists.osgeo.org](mailto:pgrouting-dev@lists.osgeo.org) [http://lists.osgeo.org/mailman/listinfo/pgrouting-dev](http://lists.osgeo.org/mailman/listinfo/pgrouting-dev)
On Tue, Jun 11, 2013 at 11:11 AM, Stephen Mather <mather.stephen@gmail.com> wrote:
Hi All,
Best,
Steve
Hi Steve,
Currently pgRouting has priority. If someone wants to fix the issues with osm2pgrouting, then that’s very welcome.
There is a good alternative to process OSM data, named “osm2po”. But it’s not released under Open Source license, if that’s OK for you.
Daniel
Wos, I wasn't expecting a response so soone. I'll give your new version a test.
Best,
Steve
Hi All,
Best,
SteveHi Steve,
Cool. I got the same errors re: topology and unique contraints, so we'll see how it goes under actual use.
Best,
Steve
Hi Steve,
Today I have created a new "develop" branch [1] for osm2pgrouting, merged
If nothing went wrong, then the "develop" branch should now support 32bit
ID's and pgRouting 2.0 function names.
[1]https://github.com/pgRouting/osm2pgrouting/tree/develop
Adding tag types and classes to database...
ERROR: duplicate key value violates unique constraint "classes_pkey"
CONTEXT: COPY classes, line 28: "100 1 unclassified 1 50"
There is a new PRIMARY KEY added for the "id" attribute, so it will just
size of streets: 13123
size of splitted ways : 27919
But the network table actually looked OK, so maybe it's just the error
message that is wrong.
I need to look at this some time later.
If you have a time to test and make sure that it works with 32bit ID's,
that would be great.
Daniel
Best,
Hi All,
Best,
SteveHi Steve,
