Here’s a dependency not listed-- git itself is a dependency… . I know this is a silly thing to point out, but it is possible on github to download a zip of the file without installing git. Should git be added as a dependency?
Best,
Steve
Best,
Steve
On Sat, May 11, 2013 at 12:59 AM, Stephen Mather
<mather.stephen@gmail.com>wrote:
Here's a dependency not listed-- git itself is a dependency... . I know
a dependency?
I added a Cmake module to get some Git parameters, if available.
It should check if it's not a Git repository, though I didn't think about
it could fail if Git is not installed at all.
Thanks for the comment, because I didn't think about it at all.
I thought the Git module would be smart enough, but of course this
shouldn't become a build dependency.
Will take a look.
Daniel
Best,
Steve_______________________________________________
pgrouting-dev mailing list
pgrouting-dev@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
Georepublic UG & Georepublic Japan
eMail: daniel.kastl@georepublic.de
Web: http://georepublic.de
Cool. Thanks Daniel. I figure I’m the first person to try to install it without git… :). It was a fresh install though.
Best,
Steve
On Sat, May 11, 2013 at 12:59 AM, Stephen Mather <mather.stephen@gmail.com> wrote:
It should check if it’s not a Git repository, though I didn’t think about it could fail if Git is not installed at all.
Thanks for the comment, because I didn’t think about it at all.
I thought the Git module would be smart enough, but of course this shouldn’t become a build dependency.
Will take a look.
Daniel
Best,
Steve
On Sat, May 11, 2013 at 11:22 AM, Stephen Mather
Cool. Thanks Daniel. I figure I'm the first person to try to install it
without git... :). It was a fresh install though.Best,
Steve
Hi Steve,
When you meant "Git is a dependency", did you refer to the cmake output
like this?
-- The C compiler identification is GNU 4.7.2
-- The CXX compiler identification is GNU 4.7.2
-- Could NOT find Git (missing: GIT_EXECUTABLE)
This indicates, that Git isn't installed, but it doesn't prevent you from
compiling.
So it's not really a dependency, but if Git is there and the source is a
Git repository, then (as for now) it will place the version hash in the
documentation for example (in case you build the documentation)
Or do you get errors when trying to compile?
Daniel
mather.stephen@gmail.com> wrote:Here's a dependency not listed-- git itself is a dependency... . I know
a dependency?I added a Cmake module to get some Git parameters, if available.
Thanks for the comment, because I didn't think about it at all.I thought the Git module would be smart enough, but of course this
Will take a look.Daniel
Best,
http://lists.osgeo.org/mailman/listinfo/pgrouting-dev--
Web: http://georepublic.de_______________________________________________
http://lists.osgeo.org/mailman/listinfo/pgrouting-dev_______________________________________________
I definitely got errors, but I’m wondering if I got the warning, and the errors right after for other unrelated reasons. I’ll see if I can roll back to a state where I can replicate, but it will be Tuesday or Wednesday of next week before I can do that.
Best,
Steve
On Fri, May 10, 2013 at 10:35 PM, Daniel Kastl <daniel@georepublic.de> wrote:
On Sat, May 11, 2013 at 11:22 AM, Stephen Mather <mather.stephen@gmail.com> wrote:
Best,
Steve
Hi Steve,
When you meant “Git is a dependency”, did you refer to the cmake output like this?
– The C compiler identification is GNU 4.7.2
– The CXX compiler identification is GNU 4.7.2
– Could NOT find Git (missing: GIT_EXECUTABLE)
This indicates, that Git isn’t installed, but it doesn’t prevent you from compiling.
So it’s not really a dependency, but if Git is there and the source is a Git repository, then (as for now) it will place the version hash in the documentation for example (in case you build the documentation)
Daniel
Will take a look.
Daniel
Best,
Steve
On Sat, May 11, 2013 at 11:38 AM, Stephen Mather
I definitely got errors, but I'm wondering if I got the warning, and the
errors right after for other unrelated reasons. I'll see if I can roll
If you have a chance to post the errors, that would be nice.
I just uninstalled Git for testing, because I have no other environment
here without Git installed
Then I downloaded
https://github.com/pgRouting/pgrouting/archive/sew-devel-2_0.zip
And to compile I run:
cd pgrouting-sew-devel-2_0/
cmake -H. -Bbuild -DWITH_DD=ON
cd build && make && cd ..
... without errors.
Maybe something else is missing.
But again thanks for pointing out that you can also download the source
from Github as ZIP file.
Daniel
Best,
SteveOn Fri, May 10, 2013 at 10:35 PM, Daniel Kastl <daniel@georepublic.de>wrote:
mather.stephen@gmail.com> wrote:Cool. Thanks Daniel. I figure I'm the first person to try to install
it without git... :). It was a fresh install though.Best,
SteveHi Steve,
like this?-- The C compiler identification is GNU 4.7.2
...This indicates, that Git isn't installed, but it doesn't prevent you from
compiling.
documentation for example (in case you build the documentation)Or do you get errors when trying to compile?
Daniel
Best,
<mather.stephen@gmail.com <mailto:mather.stephen@gmail.com>> wrote:Cool. Thanks Daniel. I figure I'm the first person to try to
install it without git... :). It was a fresh install though.Best,
SteveHi Steve,
We should make this message clearer something like:
-- Could NOT find GIT -- ok to continue without it.
-Steve W
from compiling.
Daniel
<mailto:daniel@georepublic.de>> wrote:On Sat, May 11, 2013 at 12:59 AM, Stephen Mather
<mather.stephen@gmail.com <mailto:mather.stephen@gmail.com>> wrote:Here's a dependency not listed-- git itself is a
dependency... . I know this is a silly thing to point out,
without installing git. Should git be added as a dependency?I added a Cmake module to get some Git parameters, if available.
this shouldn't become a build dependency.
Best,
<mailto:pgrouting-dev@lists.osgeo.org>
<mailto:daniel.kastl@georepublic.de>
Web: http://georepublic.de/>_______________________________________________
pgrouting-dev@lists.osgeo.org <mailto:pgrouting-dev@lists.osgeo.org>
eMail: daniel.kastl@georepublic.de <mailto:daniel.kastl@georepublic.de>
-- Could NOT find Git (missing: GIT_EXECUTABLE)We should make this message clearer something like:
Do you know how to change this?
I think it's something from Cmake's "find_package" and I can't see where to
change the output message:
http://cmake.org/cmake/help/v2.8.8/cmake.html#command:find_package
Daniel
to change the output message:
Set the "find_package" status message to "QUIET" and added custom status
messages afterwards.
Daniel
