Yes for just this reason. I often compile in the source tree which leaves artifacts and sometimes play with the code but stuff would never get committed like debug stuff.
Daniel
On Sun, Jul 10, 2011 at 4:07 AM, Stephen Woodbridge
<woodbri@swoodbridge.com <mailto:woodbri@swoodbridge.com>> wrote:
Jay,
Thanks. OK, that is interesting - it checks out the additional branch
woodbri@mappy:~/work/ pgrouting-git/pgrouting$ git branch
* gsoc-tdsp
master
and converts the cwd to that branch. And I can switch the directory
between master and gsoc-tdsp with commands:
git checkout master
git checkout gsoc-tdsp
respectively. So this is close, but it does not look like it is easy
to create two directories one with each branch instantiated in it. I
suppose I could rsync the checked out view into another directory or
clone the repository for each separate instance I want and then
change the instance to the branch.
The rsync method seems to work but is a little awkward. Well if
anyone has any additional ideas, let me know.
-Steve
On 7/9/2011 2:11 PM, Jay Mahadeokar wrote:
Firstly, I am also a newbie in git and I have only learned
commands that
I are utterly essential for me. But I guess this could work.
|git checkout -b gsoc-tdsp origin/gsoc-tdsp
Please refer [1] to be perfectly sure and also other options.
[1] http://progit.org/book/ch3-5. html
<http://progit.org/book/ch3-5.html>
On Sat, Jul 9, 2011 at 11:27 PM, Stephen Woodbridge
<mailto:woodbri@swoodbridge. com
<mailto:woodbri@swoodbridge.com>>> wrote:
I have a git newbie question. I have checked out the git
repository:
woodbri@mappy:~/work/ pgrouting-git/pgrouting$ git branch -r
origin/HEAD
origin/darp
origin/debian
origin/debian-karmic
origin/debian-maverick
origin/debian-natty
origin/devel-2_0
origin/gsoc-multimodal
origin/gsoc-tdsp
origin/master
origin/pristine-tar
origin/snapshot
origin/snapshot-maverick
origin/unittests
origin/upstream
woodbri@mappy:~/work/ pgrouting-git/pgrouting$ git tag -l
debian/1.04-ppa12_lucid1
debian/1.05-1_karmic1
debian/1.05-1_lucid1
debian/1.05-1_maverick1
upstream/1.04
upstream/1.05
v1.05
what I would like to do is create a directory for the
gsoc-multimodal and gsoc-tdsp projects in say ../gsoc-tdsp and
../gsoc-multimodal and I can not figure out how to do this.
~/work/pgrouting-git/pgrouting is currently master
and I would like to create these:
~/work/pgrouting-git/gsoc-tdsp
~/work/pgrouting-git/gsoc- multimodal
I'm sure there has to be a simple way to do this, but I'm
not seeing it.
-Steve
______________________________ _________________
pgrouting-dev mailing list
pgrouting-dev@lists.osgeo.org
<mailto:pgrouting-dev@lists.osgeo.org>
<mailto:pgrouting-dev@lists. osgeo.org
<mailto:pgrouting-dev@lists.osgeo.org>>
http://lists.osgeo.org/ mailman/listinfo/pgrouting-dev
<http://lists.osgeo.org/ mailman/listinfo/pgrouting-dev
<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev> >
-Jay Mahadeokar
