All algorithm should have tests as part of the new 2.0 release branch. While the current tests are pretty trivial, I would hope over time that we add to the existing tests to improve on out test coverage. One of the reasons that shooting star got so broken was because we did not have any tests to verify that changes made to it did not break it.
Where the test.conf file identifies what what data files to load and what test to run and it the control file that the test-runner.pl script looks for.
*.data - sql ascii dump or sql statements to create data tables needed for any of the given tests.
*.test - a sql query that the results of will be diff'd against a corresponding *.rest file. Any differences are reported as test failures.
I would expect all new code to have tests installed in the future.
What were you referring to by a 'test grid'?
Hi Dave ,
Can I suggest that a 'test grid' be created for this project and be made
part of pgroute package.
In that way, when somebody is having a problem, they can be asked to run
a problem basied on the 'test gird' and it can be discovered very
quickly if there is problem with the pgroute package or something else.
Can you be a bit more elaborate about this??
Sorry for replying late.
Mukul
On Tue, Apr 16, 2013 at 9:00 PM, Stephen Woodbridge
<woodbri@swoodbridge.com <mailto:woodbri@swoodbridge.com>> wrote:
On 4/15/2013 6:36 AM, Mukul priya wrote:
Hi Steve ,
Just to clear things i would prefer item 2 (
partitioning
graph and then routing ) over item1 ( multi point routing ) .Its
kind of
exciting and challenging too. what are your thoughts regarding
this??
I am fine with this preference. I think it is more important that
whatever you work on will be exciting and keep you interested
through out the course of the project.
I went through the mail archive of previous years
and it was
quite useful . For now i am trying to get familiar with the
development
framework whenever i get time using this link
(https://github.com/pgRouting/__pgrouting/wiki/Developer---__Getting-Started
<https://github.com/pgRouting/pgrouting/wiki/Developer---Getting-Started>\).
Once i am done with my semester by 23rd of this month i will
speed up
significantly.
Meanwhile feedbacks and suggestions are welcome.
As you have time learning the development environment and github are
critical so you can focus on your project and not the infrastructure.
You should also look over:
https://github.com/pgRouting/__pgrouting/wiki/2.0-__Development-Guidelines-and-__Standards
<https://github.com/pgRouting/pgrouting/wiki/2.0-Development-Guidelines-and-Standards>
-Steve
Thanks
Mukul
On Sun, Apr 14, 2013 at 7:11 PM, Mukul priya
<mukul2047@gmail.com <mailto:mukul2047@gmail.com>
<mailto:mukul2047@gmail.com>> wrote:
Thanks for the reply Steve , clarifies all the issues that
i raised
, Proposed data structures cover what we need , quad tree
should
work too , I am right now looking into the last part which
describes the method of appending our graph with new cells
, seems
fine and very much implementable , will post something in
case some
new ideas strike me .
Thanks.
On Sun, Apr 14, 2013 at 10:59 AM, Stephen Woodbridge
<mailto:woodbri@swoodbridge.__com
<mailto:woodbri@swoodbridge.com>>> wrote:
On 4/13/2013 11:12 PM, Mukul priya wrote:
Thanks Steve for clearly mentioning the two proposals.
For Item 1 , upgrading all the algorithms will
certainly
require a lot
of work and since i will be having my summer vacation i
don't have any
issue with it :).
For item 2 , i am looking into the idea that you have
proposed , It is
very much doable , there are however some concerns
of mine like
- how do we decide what should be the grid size .
this can
vary for
suburban area and urban area based on netwrok density.
This might be done with a quad tree approach. You start
with a
square and some condition like maximum number of node.
If you
exceed that number you quarter it into 4 squares and
divide the
point into each of them.
- how do we classify the nodes lying on the
junction of two
or more
grids . should it be assigned to all the grids??
A node can only lie in one square or the edge boundary of a
square it does not matter which one it is put in. Edges
need to
be flagged if the cross a square boundary.
- how do we decide the grid that needs to be loaded
in the
memory ,
connectivity with the previous grid seems legit
here but i
guess we need
to discuss some corner cases too.
We could probably do something like
typedef struct pair {
int a;
int b;
} PAIR;
typedef struct edge_type {
int node_a;
int node_b;
PAIR *squares; // NULL if it does not cross square edge
float cost;
float rcost;
} EDGE;
Where PAIR can be assign the gridcell for the a and b ends.
If we number the grid cells by their quadtree numbers like:
| 1 | 2 |
| 3 | 4 |
So you start, with the above for your coverage area. So all
nodes would fall into cells 1-4. If you had to split cell 1
above, then those 4 new cells would be number 11, 12,
13, 14 and
the remaining unsplit cells would still be 2, 3, 4. If
you had
to further split cell 14, then the new cells would be
numbered
141, 142, 143, 144. So each time a cell gets
subdivided, it gets
another digit added.
This is the challenge of design good algorithms, if we have
millions of edges and node, we need to be efficient
memory wise
with our data structures but still be fast. In the
database, you
need to think about where the data is coming from (ie:
tables
using queries) and when it gets moved into memory. You
can't
think just C code or database code, you have to use both.
The idea being that we want to prepare our data in
tables, then
issue queries from C to get the new edges we need to append
cell(s) to our graph. So I'm thinking that we have a
recursive
plpgsql procedure that splits the nodes into the
appropriate
quadtree cells based on some rules. So for example we
have a
vertices_tmp table that we use to assign node numbers
to nodes,
we could add a cell column like this:
CREATE TABLE vertices_tmp
id serial NOT NULL,
cell bigint,
the_geom geometry,
and after we run the quadtree analysis each node is
assigned a
cell number. The edge table has node_a and node_b
assigned to it
also.
If we want all edges related to cell 114 then we can do
a query
like:
select b.*
from vertices_tmp a, edges b
where a.cell=114 and (a.id <http://a.id>
<http://a.id>=b.node_a or a.id <http://a.id>
<http://a.id>=b.node.b);
Thoughts?
-Steve
Thanks.
On Sat, Apr 13, 2013 at 6:20 AM, Stephen Woodbridge
<mailto:woodbri@swoodbridge.__com <mailto:woodbri@swoodbridge.com>>
<mailto:woodbri@swoodbridge.>____com
<mailto:woodbri@swoodbridge.com>>>> wrote:
On 4/11/2013 3:24 PM, Mukul priya wrote:
Hi Steve and Daniel,
You suggested extending the present
algorithms such
that its
input can take more points and not only
the source and
destination . i
think this can be implemented and i will
soon come
up with
implementation details( kind of more
technical ) .
Can you be a liitle bit more
elaborate about
partioning data
into spatial chunks or even suggest some
readings .
I can then
come up
with some better ideas about implementing it.
This is just me thinking out loud
Lets say we construct a grid of one degree
squares, you can
visualize it by drawing a grid over your map.
Then you can associate all the nodes with the
grid they
fall in. We
might also need to associate edges to the
grids also
and an edge the
crosses over a grid boundary might need to be
associated with two
grids. This could be done with some simple
relational
tables like:
node_id|grid_id or edge_d|grid_id
So my idea would be to do the routing like this:
1. get the start node or edge
2. build the graph based on loading the items
in the
related grid
3. mark the boundary nodes (we might want to
do this
when we grid them)
4. run the algorithm until we find the target
node or
hit a boundary
node
5. on hitting a boundary:
a. we check if the connected grid is loaded and
continue if it is
b. or we extent the graph with the new grid
6. continue with the routing
We might want to be able to dynamically change
the size
of the grid
cell based on the number of items in it. This
would
give us better
performance when transitioning from rural
areas into
urban areas
where there is a greater density of road segments.
Think of a
quadtree where we split it based on number of
entities.
Daniel , i took a look at the
oracle link
that you
provided but
there was no details about how it has been
implemented , it was more
about how one can use it. May be a bit
more search
and luck might
take me to its implementation document .
Right, it is useful if you look at the
documentation
and ask why did
they do it that way and what does it imply
about how it
works behind
the scenes.
The other thing that you
mentioned was
about contraction
Hierarchy . Still the nodes have to be ordered
based on some
criteria or
according to their importance . We can
use natural
hierarchy
present in
the network for doing that .
This is not related to what you proposed. It is an
algorithm that
does a lot of precompuation, that is LOTS in
capitals,
but it can
get results in milliseconds for cross country
routes.
i will be really grateful if
anyone can
correct me
in case if
my thought process in not on the right
lane and
sorry for the
late reply
as my academic session is in progress too
.Meanwhile i am
trying to
get fluent with git ,cmake and other tools.
So read over our wiki:
https://github.com/pgRouting/______pgrouting/wiki
<https://github.com/pgRouting/____pgrouting/wiki>
<https://github.com/pgRouting/__pgrouting/wiki>>
<https://github.com/pgRouting/pgrouting/wiki>>>
The way I see it at the moment there are two
unrelated
proposals on
the table (I'm leaving out the contraction
hierarchy):
1. multi point routing
2. partition JIT graph building while routing
Item 1 is fairly trivial technically, I think,
but if
you were to
upgrade all the algorithms to do this it would
be a lot
of work and
a useful contribution to pgrouting.
Item 2 is more of a design and code a new
algorithm and
you would
probably want to focus on using astar or trsp
algorithm
to do this
with. This one is more technically challenging
and has
more unknowns
in it but I think it should be doable.
If you are interested in reading about contraction
hierarchies:
https://www.google.com/#q=______contraction
<https://www.google.com/#q=____contraction>
<https://www.google.com/#q=__contraction>>
<https://www.google.com/#q=contraction>>> hierarchies
-Steve
Thanks .
Mukul
On Thu, Apr 11, 2013 at 6:47 PM, Stephen
Woodbridge
<mailto:woodbri@swoodbridge>.
<mailto:woodbri@swoodbridge>.>______com
<mailto:woodbri@swoodbridge.com>>>>> wrote:
With pgRouting, we do most things
dynamically,
here is the
basic flow:
1. Given a collection of input,
points, nodes,
or edges
map these to nodes or edges depending on
algorithm.
2. Select the edges we need to build
the graph
3. build the graph and solve it
4. return the results
All our algorithms today only take
start and
end points.
They could
be extended to take points. Each
"point" (I
use "point" as
a generic
term because it might be a lat/lon,
node id,
edge id and
offset,
etc) would need to be mapped to the
appropriate input need
for any
given algorithm.
So for node based algorithms like
Dijkstra,and
astar it
would get
resolved to a node. For TRSP it would get
mapped to the
nearest edge
and offset along that edge. Postgis
has lots
of handy tools for
doing this.
-Steve
On 4/10/2013 10:50 PM, Mukul priya wrote:
Thanks for the reply steve . i have
already cloned the
github
repository
and looking into various aspects
of it .
For IRNN querry implementation i
think it
is a good
idea to sub
divide
the whole route and generate n+1
routes
separately ,
say from S
to F1 ,
F1-F2 ,..... F(n-1)-Fn , Fn to D . i
wanted to know if
we have
that kind
of a data where each and every
facility is
mentioned on
the map as a
point (node ) . even if it is not
directly
connected to
the road
network
we can basically treat it a
pseudo node
and then call
the router
. The
other thing about optimization
yes we can
do that using
spatial
range
querries suppose there are several
instances of the same
facility that a
user wants to access then we can use
spatial range
querries to
locate
that facility which is the nearest.
On Thu, Apr 11, 2013 at 1:42 AM,
Stephen
Woodbridge
<mailto:woodbri@swoodbridge>>.
<mailto:woodbri@swoodbridge>>.>________com
<mailto:woodbri@swoodbridge.com>>>>>> wrote:
On 4/10/2013 3:23 PM, Mukul
priya wrote:
Hi ,
Hi Mukul,
Thank you for your interest
in pgRouting.
I am a
B.tech
fourth year
student at
IIIT-Hyderabad
pursuing a degree in
computer
science and
engineering
and i will
be soon
pursuing a Masters
Degree in the
field of Spatial
Informatics
and the
research topic that i
have been
working on is *"In
route nearest
neighbour querries".*
Last year
i worked
on a project
that was
funded by
Honeywell technology
solutions
and it gave me
a lot of
insight about
open source programming and
industrial work
culture.
I was introduced to
pgrouting by
*Prof. Venkatesh
Raghavan* who
visited
our college last summer.
i have
also used
pgrouting for
implementing one
of my Honors project.
i have gone through the
updated
ideas page and
i am
listing out
a topic
that i feel i can
contribute to.
*Idea *
Network Partitioning
A very simple method
using which
it can be
done is :
* *Existence of a natural
Hierarchy*
Generally road
networks are
organized such
that there
is some
natural hierarchy for
example if
we look at
the road
network of
USA we
observe that there are
national
highways which
connect
multiple
large
regions , inter state roads
connect places
within these
regions
, multi
lane roads connect city
areas and
then there
are small
roads to
connect
individual houses.
so what we
can do is
first rank these
classes that
constitute the road
network and
then use the
highest
level roads to
divide the road network into
large regions
enclosed by
these
roads. each
of the divided regions can
further be divided
again
using next lower
level road.
so suppose
we have a
road network
which n
classes of
different roads then we can
create a tree of
depth n-1
where the
root of
the tree will represent the
entire road
network and
children of
the the
root node will represent
the area
formed by
partitioning the
root using
the level 1 ( highest )
edges and
so on . the
nodes
will basically
represent a smaller part
of the
road network.
The idea
seems to
be very naive
right now
but if
anyone can
give some feedback
whether it is
achievable or
not or
may be suggest
some modifications.
Yes this is the basics of
how this
could work.
Because we
build our
graphs dynamically for each
route
request, we can do
something like
this today. Typically you
have to
feed the route
request
and SQL
query that provides the
edges needed
to build the
graph and
this can
be simply the bounding box
of the
start and end
point of
the route
expanded slightly to allow
the route
move outside that
bounds by a
little if needed. A case in
point are
start and
end points
that form
a vertical of horizontal line.
So for the natural
hierarchy, you can
for a SQL
query like:
select * from edges where
st_dwithin(the_geom,
start_pnt,
radius)
union
end_pnt, radius)
union
select * from edges
where
st_expand(st_makeline(start___________pnt,
end_pnt), pct)
and road_class < 4;
So this gets all edges
regardless of
class at the
start and
end and
then gets all the major
roads and
highways between the
start and end
points. We can dynamically
select the
edges that
we want
when we
build the graph.
Regardless of how you
implement the
routing, the
problem is all
about the data. If you have
a road
segment the is
misqualified, you
might end up with a network
that is
broken between
start
and end.
This can alsoo happen if
ramps are
not coded
correctly.
One of the challenges we
have today
is that we
have to be
able to
construct the whole graph in
memory
before we can
start
routing.
This is ok for small areas
but it is
a problem if
you want to
generate a route between say
Miami,
Florida and
Seattle,
Washington.
An interesting problem would
be the
ability to
partition
the data in
spatial chucks and only load
them as
the solver
needed them.
If you think about your
edges sorted
into say 1
degree grid
partitions,
then you load the partition
for the
start point
and start
routing
using A* search, when you
frontier
get to an edge
of the
grid you
are in, then you load the
adjacent
grid and
continue, if
you bump
into another grid boundary
that is
not loaded yet, you
load, if it
is already loaded you continue.
Anyway food for
thought!
In route
nearest
neighbour
querries(
IRNN) which
handle
querries like computation of
shortest path ,
provided
that the user
wants to visit
facilities F1 , F2
,.....FN
while he/she
drives
or walks
from source to
destination. Network
partitioning can
optimize these
computations too as the
search
space reduces
significantly once
we have
the partitions. Handling
such
querries have
not been
implemented
yet. It
will be very helpful if
we can
have some
discussion
about whether
implementing it is
feasible or not.
What is we just added via
support to
routing? Then
we could do
something like say generate
a route:
Start, F1,
F2, ... Fn, End
This would allow us to build
a graph
one time and
then generate
multiple sub-routes with in the
graph. Today if
you want to
do that
you have to generate n+1
routes and
build the
graph n+1
times. We
could also do some preliminary
optimization of the via
points based
on Euclidean distance using
something
like TSP before
calling the
router.
It would
be great
if someone
could give
a general
idea
how to go about
learning more
about the areas
mentioned with
respect
to the organization's
projects.Specially
suggest those
ideas
which the
developers think are
achievable
for now . I
will also
be grateful if
somebody can guide me
regarding
the development
framework of
pgrouting
so that i get familiar
with the whole
framework in the
coming days.
I would clone the github
repository
and look at branch
sew-devel-2_0
this is our new tree
structure and it
has code,
doc, and
test all
organized in a nice way that
makes it
easy to multiple
contributors
work with the tree.
Ask questions, There is a
tutorial
floating around
and lots of
people that are will to help.
-Steve
Thank you .
Mukul Priya
Lab for spatial Informatics
IIIT-Hyderabad
_________________________________________________________
pgrouting-dev mailing list
pgrouting-dev@lists.osgeo.org <mailto:pgrouting-dev@lists.osgeo.org>
<mailto:pgrouting-dev@lists.__osgeo.org
<mailto:pgrouting-dev@lists.osgeo.org>>
<mailto:pgrouting-dev@lists.>____osgeo.org <http://osgeo.org>
<mailto:pgrouting-dev@lists.osgeo.org>>>
<mailto:pgrouting-dev@lists>.
<mailto:pgrouting-dev@lists>.>______osgeo.org <http://osgeo.org>
<http://osgeo.org>
<mailto:pgrouting-dev@lists.osgeo.org>>>>
<mailto:pgrouting-dev@lists>>.
<mailto:pgrouting-dev@lists>>.>________osgeo.org <http://osgeo.org>
<http://osgeo.org> <http://osgeo.org>
<http://osgeo.org>
<mailto:pgrouting-dev@lists.osgeo.org>>>>>
http://lists.osgeo.org/__________mailman/listinfo/pgrouting-__dev <http://lists.osgeo.org/________mailman/listinfo/pgrouting-dev>
<http://lists.osgeo.org/______mailman/listinfo/pgrouting-dev>\_\_>
<http://lists.osgeo.org/____mailman/listinfo/pgrouting-dev>\_\_>\_\_>
<http://lists.osgeo.org/__mailman/listinfo/pgrouting-dev>\_\_>\_\_>\_\_>
<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>\_\_>\_\_>\_\_>\_\_>
<http://osgeo.org>
<http://osgeo.org>
<http://osgeo.org>
<http://osgeo.org>
