Hi Steve and Daniel ,
I have posted my proposal on Melange Gsoc system. Do have a look at it.
Waiting for feedback and suggestions.
Thanks
Mukul
Thanks
Mukul
Can you post a link to your proposal? or the text of it here also. I can never find anything in Melange or I may not have visibility to it yet as I just applied as a mentor.
-Steve
**Country:**India
School and degree: International Institute Of Information Technology-Hyderabad ,
B.Tech + Masters in computer Science And Engineering
Email:mukul2047@gmail.com
Phone:+91 9885991061
OSGeo project(s):pgRouting
Title: A partitioned approach to on demand increment graph assembly for pgRouting.
Describe your idea
1. Introduction
pgRouting has been working towards providing routing functionality on a PostGis/PostgreSql Geo spatial
database. It already has support for shortest path algorithm like astar ,dijkstra , tdsp and trsp .But for a very
large network, routing becomes time consuming. Network partitioning is one such way which can prove to
be helpful in improving the overall time efficiency of routing querries. The main idea here is to first partition
the whole network using a Quad tree approach and when the shortest path is computed these partitions are
loaded on demand. hence , there is an on demand incremental graph generation.
The project aims at designing and implementing a Shortest Path algorithm on an on demand incremental
Graph using a network partitioning approach.
2. Background
Considering the present status where pgRouting has support for shortest path algorithm like astar etc.
Looking at their implementation details we can observe that the graph is configured dynamically for all
of them before computation.My proposal will also be on the same track and for very large networks
where the distance between source and destination can be very large , the response time will be
significantly lesser and memory wise too it will be lot more efficient. Presently they don’t use any partitioning
approach so it will prove to be a good addition to their support for shortest past algorithms.
3. The idea
There are two major components of my idea .
For this part we can use a quad tree approach. Say , we start with a square and a condition like maximum
number of nodes that can reside in a square . if the number of nodes in the square is greater than the max
condition we further quarter it into four squares and allot the nodes appropriately to each of them.All these
squares can be called grids and they all will be addressed uniquely using a grid cell number .Each node
will be assigned a grid cell number based on the grid they are lying inside.
We will have data structures to address edges as they can remain contained in either one grid cell
or span across a number of grid cells.the idea is to first flag such edges and store the grid cell numbers
of the grids that the edge crosses/intersects.
The idea here is to first identify the grid cell initially and then fetch the edges that are associated with
that grid. These are the edges that will get appended to the present graph and the graph will keep growing
dynamically this way. we will have appropriate database tables addressing the above issue such that
we are able to fetch the required edges quickly using a database querry.
The implementation details for the above are :
we will first partition the whole graph using the quad tree approach and each node/vertex will be assigned
a grid cell number so we can have database table for the assigned nodes and edges like :
CREATE TABLE vertex{
id Node_id \ unique for each node.
cell grid_cell_number; \ the grid in which the node lies.
geometry;
CREATE TABLE edge {
int id ;
Int node_a;
int node_b; \ the connecting nodes
// we can have other parameters like traversal cost and return cost.
using the tables we can then fetch the edges form edge table using simple database querry once
we are provided with the grid cell number very easily.
In short the summary of the whole idea is :
Step1: Fetch the start node , get the related Grid cell number.
Step 2: Increment the graph by fetching all the items related to that grid.
Step3 : Check for boundary nodes ( this is done while we are partitioning) or target node .
Step 4: On hitting a boundary node
check if the connected grid is loaded and continue if it is
or we extend the graph with the new grid and continue with the routing;
or On hitting the target Node
stop;
4. Project plan
I will have about 12 weeks to implement the project. The tentative schedule is as follows:
Before 17th June : Get familiar with the development environment of pgRouting and test some demos.
week 1-2: Discuss and Define the various data structures and data table that will be required.Prepare the
Overall implementation architecture.
week 3-4- Discuss and Implement network partitioning using quad tree.
week 5-8 -Start coding for on demand graph generation and routing using Dijkstra. In between Prepare mid-term
report.
week 9 - Integration with pgrouting .
week 10-12- Testing and Bug fixing. Draft Final report and documentation.
5. Future ideas / How can your idea be expanded?
It can be integrated with other shortest path algorithms like astar etc. which pgrouitng provides.For time dependent
shortest path computation, it will greatly reduce the updating cost as we will be updating the cost of only those edges
that are contained in the grid cells that are loaded.
In route nearest neigbour querries can also be implemented using the partitioning approach.Overall we can
expand this approach to various other algorithms.
Explain how your SoC task would benefit the OSGeo member project and more generally the OSGeo Foundation as a whole:
The proposed idea will significantly improve the performance of shortest path finding algorithms.This will have a
positive effect on the user base of pgRouting. For various software paltforms or applications that are using this library ,
the response time will significantly improve.
Please provide details of general computing experience:
I generally use ubuntu ( 12.04) for all my academic purposes and windows 7 for entertainment only. I am familiar with Fedora also.
C++ is the language that i use most ( programming purposes). For implementing various course projects i have used C++ ,python ,Java and matlab.
I have no experience with hardware. The only experience that i had with networking was during my computer network course.
Please provide details of previous GIS experience:
I am a part of “Lab for Spatial Informatics” which is the only lab in India devoted to GIS applications and learning. I am familiar with and have used almost all the open source GIS platforms like Quantum , OpenJump, ILwis,Grass. We have our own rendering platform that was developed by our lab.(LSI viewer)
Please provide details of any previous involvement with GIS programming and other software programming:
I am very much familiar with Gdal/OGR as i used it extensively while implementing an outsourced project of Honeywell
Technology . I have played a lot with ESRI shape files.
Please tell us why you are interested in GIS and open source software:
I was very impressed with google earth when it was launched way back in 2004.GIS platforms like quantum and Openjump were introduced to me when i was in my second year and then i joined Lab for spatial informatics that is in our college based on my interest in this area.
open source platforms provide an opportunity to learn . The best part is you can always create or develop something that you are interested in and there are people who will always be there to help you if you are stuck.
Please tell us why you are interested in working for OSGeo and the software project you have selected:
It will be huge learning experience since i have been using platforms like Qgis , Gdal ,PostGis etc which come under Osgeo
I chose pgrouting because the algorithms that they have implemented are related to my masters topic and it will be great if i get an insight about how these were implemented on a much larger scale.
Please tell us why you are interested in your specific coding project:
Implementing routing algorithms for real world networks is actually very challenging.its a challenge to come up with good approaches so that the computation cost and response time is both reduced.
Would your application contribute to your ongoing studies/degree? If so, how?
I am pursuing my Masters and my topic is closely related to my proposal . If the results are impressive , i might get a publication in this area.
Please explain how you intend to continue being an active member of your project and/or OSGeo AFTER the summer is over:
I was always interested in open source programming but never knew where to start . GSOC provides an opportunity for beginners like me to take a dive in the area open source programming. i have other ideas like implementing IRNN ( In route nearest neighbour querries) which can be implemented within pgRouting.I have other intentions like working for bigger projects like Quantum Gis or Grass.I will be contributing to the community forum and will always try to improve things.
Do you understand this is a serious commitment, equivalent to a full-time paid summer internship or summer job?
Yes, I understand that this is a serious commitment and will try to give my best and work in a professional manner.
Do you have any known time conflicts during the official coding period? (June 17 to Sept. 27)
No .
On Thu, Apr 25, 2013 at 12:47 AM, Stephen Woodbridge <woodbri@swoodbridge.com> wrote:
Waiting for feedback and suggestions.Can you post a link to your proposal? or the text of it here also. I can never find anything in Melange or I may not have visibility to it yet as I just applied as a mentor.
-Steve
pgrouting-dev mailing list
pgrouting-dev@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
Hi Mukul,
This is a good write up. It largely mirrors out discussion. One thing that needs to change in this is that dijkstra should be replaced with astar.
Are you familiar with how these are different?
http://theory.stanford.edu/~amitp/GameProgramming/AStarComparison.html
Do you see why? and specifically why it matter for this project?
-Steve
On 4/24/2013 9:10 PM, Mukul priya wrote:
***Name*:Mukul Priya
*Country:*India
*School and degree*: International Institute Of Information
Technology-Hyderabad ,B.Tech + Masters in computer Science And
Engineering*Email*:mukul2047@gmail.com <mailto:mukul2047@gmail.com>
*Phone*:+91 9885991061
*OSGeo project(s*):pgRouting
*Title:* A partitioned approach to on demand increment graph assembly
for pgRouting.*Describe your idea*
*1. Introduction*pgRouting has been working towards providing routing
functionality on a PostGis/PostgreSql Geo spatialdatabase. It already has support for shortest path algorithm like
astar ,dijkstra , tdsp and trsp .But for a verylarge network, routing becomes time consuming. Network partitioning
is one such way which can prove tobe helpful in improving the overall time efficiency of routing
querries. The main idea here is to first partitionthe whole network using a Quad tree approach and when the shortest
path is computed these partitions areloaded on demand. hence , there is an on demand incremental graph
generation.The project aims at designing and implementing a Shortest Path
algorithm on an on demand incrementalGraph using a network partitioning approach.
*2. Background*
shortest path algorithm like astar etc.Looking at their implementation details we can observe that the graph
is configured dynamically for allof them before computation.My proposal will also be on the same track
and for very large networkswhere the distance between source and destination can be very large ,
the response time will besignificantly lesser and memory wise too it will be lot more
efficient. Presently they don't use any partitioningapproach so it will prove to be a good addition to their support for
shortest past algorithms.*3. The idea*
*Network Partitioning*
with a square and a condition like maximumnumber of nodes that can reside in a square . if the number of
nodes in the square is greater than the maxcondition we further quarter it into four squares and allot the
nodes appropriately to each of them.All thesesquares can be called grids and they all will be addressed
uniquely using a grid cell number .Each nodewill be assigned a grid cell number based on the grid they are
lying inside.We will have data structures to address edges as they can
remain contained in either one grid cellor span across a number of grid cells.the idea is to first flag
such edges and store the grid cell numbersof the grids that the edge crosses/intersects.
*On demand graph generation and Routing.*
initially and then fetch the edges that are associated withthat grid. These are the edges that will get appended to the
present graph and the graph will keep growingdynamically this way. we will have appropriate database tables
addressing the above issue such thatwe are able to fetch the required edges quickly using a
database querry.The implementation details for the above are :
approach and each node/vertex will be assigneda grid cell number so we can have database table for the
assigned nodes and edges like :CREATE TABLE vertex{
id Node_id \\ unique for each
node.cell grid_cell_number; \\ the grid in which the
node lies.geometry;
CREATE TABLE edge {
int id ;
Int node_a;
int node_b; \\ the connecting nodes
cost.}
using simple database querry oncewe are provided with the grid cell number very easily.
partitioning) or target node .Step 4: On hitting a boundary node
it isor we extend the graph with the new grid and continue
with the routing;}
stop;
*4. Project plan*
schedule is as follows:Before 17th June : Get familiar with the development environment
of pgRouting and test some demos.week 1-2: Discuss and Define the various data structures and data
table that will be required.Prepare theOverall implementation architecture.
tree.week 5-8 -Start coding for on demand graph generation and routing
using Dijkstra. In between Prepare mid-termreport.
documentation.*
5. Future ideas / How can your idea be expanded? *It can be integrated with other shortest path algorithms like
astar etc. which pgrouitng provides.For time dependentshortest path computation, it will greatly reduce the updating cost
as we will be updating the cost of only those edgesthat are contained in the grid cells that are loaded.
the partitioning approach.Overall we canexpand this approach to various other algorithms.
*Explain how your SoC task would benefit the OSGeo member project and
more generally the OSGeo Foundation as a whole:*The proposed idea will significantly improve the performance of
shortest path finding algorithms.This will have apositive effect on the user base of pgRouting. For various software
paltforms or applications that are using this library ,the response time will significantly improve.
*I generally use ubuntu ( 12.04) for all my academic purposes and windows
7 for entertainment only. I am familiar with Fedora also.C++ is the language that i use most ( programming purposes). For
matlab.I have no experience with hardware. The only experience that i had with
networking was during my computer network course.*
Please provide details of previous GIS experience:*I am a part of "Lab for Spatial Informatics" which is the only lab in
developed by our lab.(LSI viewer)*Please provide details of any previous involvement with GIS programming
and other software programming:*I am very much familiar with Gdal/OGR as i used it extensively while
implementing an outsourced project of HoneywellTechnology . I have played a lot with ESRI shape files.
*Please tell us why you are interested in GIS and open source software:*
that is in our college based on my interest in this area.open source platforms provide an opportunity to learn . The best part is
and there are people who will always be there to help you if you are stuck.*
software project you have selected:*It will be huge learning experience since i have been using platforms
like Qgis , Gdal ,PostGis etc which come under OsgeoI chose pgrouting because the algorithms that they have implemented are
about how these were implemented on a much larger scale.*Please tell us why you are interested in your specific coding project:*
computation cost and response time is both reduced.*Would your application contribute to your ongoing studies/degree? If
so, how?*I am pursuing my Masters and my topic is closely related to my proposal
. If the results are impressive , i might get a publication in this area.*Please explain how you intend to continue being an active member of
your project and/or OSGeo AFTER the summer is over:*I was always interested in open source programming but never knew where
community forum and will always try to improve things.*Do you understand this is a serious commitment, equivalent to a
full-time paid summer internship or summer job?*Yes, I understand that this is a serious commitment and will try to give
my best and work in a professional manner.*Do you have any known time conflicts during the official coding period?
(June 17 to Sept. 27)*No .
<woodbri@swoodbridge.com <mailto:woodbri@swoodbridge.com>> wrote:On 4/24/2013 2:34 PM, Mukul priya wrote:
at it.
it yet as I just applied as a mentor.Thanks,
-Steve
_________________________________________________
pgrouting-dev@lists.osgeo.org <mailto:pgrouting-dev@lists.osgeo.org>
http://lists.osgeo.org/__mailman/listinfo/pgrouting-dev
<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>_______________________________________________
Thanks Steve ,I am familar with astar ,It uses a heuristic to guide itself to the destination, there was huge focus on it in our game theory course.
Although do point out the advantages it has in real life road network and its importance to my proposal.
On Thu, Apr 25, 2013 at 7:43 AM, Stephen Woodbridge <woodbri@swoodbridge.com> wrote:
Hi Mukul,
http://theory.stanford.edu/~amitp/GameProgramming/AStarComparison.htmlDo you see why? and specifically why it matter for this project?
-Steve
**Name:Mukul Priya
*Country:*India
EngineeringEmail:mukul2047@gmail.com mailto:[mukul2047@gmail.com](mailto:mukul2047@gmail.com)
for pgRouting.Describe your idea
1. IntroductionpgRouting has been working towards providing routing
2. Background
efficient. Presently they don’t use any partitioningapproach so it will prove to be a good addition to their support for
shortest past algorithms.3. The idea
node.cell grid_cell_number; \ the grid in which the
node lies.geometry;
CREATE TABLE edge {
int id ;
Int node_a;
cost.}
with the routing;}
stop;
4. Project plan
documentation.
- Future ideas / How can your idea be expanded? *
more generally the OSGeo Foundation as a whole:The proposed idea will significantly improve the performance of
developed by our lab.(LSI viewer)Please provide details of any previous involvement with GIS programming
and other software programming:I am very much familiar with Gdal/OGR as i used it extensively while
about how these were implemented on a much larger scale.Please tell us why you are interested in your specific coding project:
computation cost and response time is both reduced.Would your application contribute to your ongoing studies/degree? If
so, how?I am pursuing my Masters and my topic is closely related to my proposal
. If the results are impressive , i might get a publication in this area.Please explain how you intend to continue being an active member of
your project and/or OSGeo AFTER the summer is over:I was always interested in open source programming but never knew where
community forum and will always try to improve things.Do you understand this is a serious commitment, equivalent to a
full-time paid summer internship or summer job?Yes, I understand that this is a serious commitment and will try to give
my best and work in a professional manner.Do you have any known time conflicts during the official coding period?
(June 17 to Sept. 27)No .
<woodbri@swoodbridge.com mailto:[woodbri@swoodbridge.com](mailto:woodbri@swoodbridge.com)> wrote:
at it.
-Steve
pgrouting-dev@lists.osgeo.org mailto:[pgrouting-dev@lists.osgeo.org](mailto:pgrouting-dev@lists.osgeo.org)
course.Although do point out the advantages it has in real life road network
How much of the network do you have to explore using each algorithm?
How does this impact the number of grids you have to load?
How does this impact your proposal?
-Steve
<woodbri@swoodbridge.com <mailto:woodbri@swoodbridge.com>> wrote:Hi Mukul,
replaced with astar.Are you familiar with how these are different?
http://theory.stanford.edu/~__amitp/GameProgramming/__AStarComparison.html
<http://theory.stanford.edu/~amitp/GameProgramming/AStarComparison.html>Do you see why? and specifically why it matter for this project?
-Steve
*Country:*India
Science And
<mailto:mukul2047@gmail.com>*Phone*:+91 9885991061
assembly
like
partitioning
shortest
graph
Shortest Path
*2. Background*
support for
the graph
same track
very large ,
support for
start
number of
allot the
they are
they can
first flag
to the
tables
for each
which the
node lies.geometry;
CREATE TABLE edge {
int id ;
Int node_a;
and return
cost.}
edge table
that grid.Step3 : Check for boundary nodes ( this is done while we are
continue if
continue
with the routing;}
stop;
*4. Project plan*
tentative
environment
and data
using quad
routing
documentation.*
like
updating cost
implemented using
project and
performance of
software
windows
,Java and
had with
lab in
with and
programming
while
software:*I was very impressed with google earth when it was launched way
back in
me when
informatics
part is
interested in
are stuck.*
platforms
implemented are
project:*Implementing routing algorithms for real world networks is
actually very
that the
studies/degree? If
proposal
knew where
to take a
can be
working for
to the
to give
period?
<mailto:woodbri@swoodbridge.__com
<mailto:woodbri@swoodbridge.com>>> wrote:On 4/24/2013 2:34 PM, Mukul priya wrote:
have a look
at it.
here also. I
visibility to
-Steve
___________________________________________________
<mailto:pgrouting-dev@lists.__osgeo.org
<mailto:pgrouting-dev@lists.osgeo.org>>
http://lists.osgeo.org/____mailman/listinfo/pgrouting-dev
<http://lists.osgeo.org/__mailman/listinfo/pgrouting-dev>
<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>\_\_>_________________________________________________
<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>_________________________________________________
This will be reduced significantly while using Astar as we will have a fair bit of idea about the direction towards which we should proceed.
Once we have an idea about the direction towards which we should proceed , only those grids will be loaded. This will result in loading of less number of grids.
The basic motivation behind the proposal is to make shortest path computation faster. Number of database querry will be reduced as we will be fetching lesser number of grids. This will have a positive effect on computation time.
On Thu, Apr 25, 2013 at 7:07 PM, Stephen Woodbridge <woodbri@swoodbridge.com> wrote:
and its importance to my proposal.How much of the network do you have to explore using each algorithm?
How does this impact your proposal?-Steve
Hi Mukul,
<http://theory.stanford.edu/%7Eamitp/GameProgramming/AStarComparison.html>Do you see why? and specifically why it matter for this project?
-Steve
**Name:Mukul Priya
*Country:*India
Science And
<mailto:mukul2047@gmail.com mailto:[mukul2047@gmail.com](mailto:mukul2047@gmail.com)>
assembly
like
partitioning
shortest
graph
Shortest Path
2. Background
support for
the graph
same track
very large ,
support for
start
number of
allot the
they are
they can
first flag
to the
tables
id Node_id \ unique
for each
which the
node lies.geometry;
CREATE TABLE edge {
int id ;
Int node_a;
and return
cost.}
edge table
continue if
continue
with the routing;}
stop;
4. Project plan
tentative
environment
and data
using quad
routing
documentation.
like
updating cost
implemented using
project and
performance of
software
windows
,Java and
had with
lab in
with and
programming
while
software:I was very impressed with google earth when it was launched way
back in
me when
informatics
part is
interested in
are stuck.
platforms
implemented are
project:Implementing routing algorithms for real world networks is
actually very
that the
studies/degree? If
proposal
knew where
to take a
can be
working for
to the
to give
period?
<woodbri@swoodbridge.com mailto:[woodbri@swoodbridge.com](mailto:woodbri@swoodbridge.com)<mailto:woodbri@swoodbridge.__com
have a look
at it.
here also. I
visibility to
-Steve
mailto:[pgrouting-dev@lists.osgeo.org](mailto:pgrouting-dev@lists.osgeo.org)<mailto:pgrouting-dev@lists.osgeo.org
mailto:[pgrouting-dev@lists.osgeo.org](mailto:pgrouting-dev@lists.osgeo.org)>
<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>>
fair bit of idea about the direction towards which we should proceed.How does this impact the number of grids you have to load?
number of grids.How does this impact your proposal?
computation time.
Right, so in your proposal, you want to be clear that the benefit will be achieved using astar or another algorithm with a heuristic and not dijkstra. I understand that "shortest path" is a generic reference to all of these algorithms, but the only ones that will benefit from this approach will be ones with a heuristic that allow us to explore only a subset the overall bounding box of edges that we might otherwise use as input. So it is best to be clear on these points.
-Steve
<woodbri@swoodbridge.com <mailto:woodbri@swoodbridge.com>> wrote:On 4/25/2013 12:26 AM, Mukul priya wrote:
game theory
network
<mailto:woodbri@swoodbridge.com>>> wrote:Hi Mukul,
http://theory.stanford.edu/~____amitp/GameProgramming/____AStarComparison.html
<http://theory.stanford.edu/~__amitp/GameProgramming/__AStarComparison.html><http://theory.stanford.edu/%\_\_7Eamitp/GameProgramming/\_\_AStarComparison\.html
<http://theory.stanford.edu/~amitp/GameProgramming/AStarComparison.html>>Do you see why? and specifically why it matter for this
project?-Steve
*Country:*India
B.Tech + Masters in
computer
Science And
<mailto:mukul2047@gmail.com> <mailto:mukul2047@gmail.com
<mailto:mukul2047@gmail.com>>
<mailto:mukul2047@gmail.com>>>*Phone*:+91 9885991061
graph
assembly
routing
algorithm
like
partitioning
of routing
when the
shortest
incremental
graph
Shortest Path
*2. Background*
support for
observe that
the graph
on the
same track
can be
very large ,
lot more
support for
Say , we
start
if the
number of
squares and
allot the
be addressed
the grid
they are
edges as
they can
idea is to
first flag
grid cell
appended
to the
database
tables
quickly using a
the quad tree
table for the
id Node_id \\
unique
for each
grid in
which the
node lies.geometry;
CREATE TABLE edge {
int id ;
Int node_a;
traversal cost
and return
cost.}
edges form
edge table
number.Step 2: Increment the graph by fetching all the items
related to
we are
loaded and
continue if
grid and
continue
with the routing;}
stop;
*4. Project plan*
project. The
tentative
environment
structures
and data
architecture.week 3-4- Discuss and Implement network
partitioning
using quad
generation and
routing
report and
documentation.*
algorithms
like
updating cost
implemented using
project and
performance of
various
software
purposes and
windows
purposes). For
,python
,Java and
that i
had with
the only
lab in
familiar
with and
Quantum ,
platform that was
with GIS
programming
extensively
while
source
launched way
back in
introduced to
me when
informatics
The best
part is
interested in
you if you
are stuck.*
OSGeo and the
using
platforms
implemented are
get an insight
coding
actually very
approaches so
that the
studies/degree? If
related to my
proposal
publication in
active member of
never
knew where
like me
to take a
ideas like
querries) which
can be
working for
contributing
to the
equivalent to a
will try
to give
official coding
period?
<mailto:woodbri@swoodbridge.__com <mailto:woodbri@swoodbridge.com>>
<mailto:woodbri@swoodbridge.>____com<mailto:woodbri@swoodbridge.__com
<mailto:woodbri@swoodbridge.com>>>> wrote:On 4/24/2013 2:34 PM, Mukul priya wrote:
system. Do
have a look
at it.
of it
here also. I
visibility to
-Steve
_____________________________________________________pgrouting-dev mailing list
<mailto:pgrouting-dev@lists.>____osgeo.org <http://osgeo.org>
<mailto:pgrouting-dev@lists.osgeo.org>>>
http://lists.osgeo.org/______mailman/listinfo/pgrouting-dev
<http://lists.osgeo.org/____mailman/listinfo/pgrouting-dev><http://lists.osgeo.org/____mailman/listinfo/pgrouting-dev
<http://lists.osgeo.org/__mailman/listinfo/pgrouting-dev>\_\_><http://lists.osgeo.org/____mailman/listinfo/pgrouting-dev
<http://lists.osgeo.org/__mailman/listinfo/pgrouting-dev><http://lists.osgeo.org/__mailman/listinfo/pgrouting-dev
<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>\_\_>\_\_>___________________________________________________
<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>\_\_>___________________________________________________
Thanks Steve will add a few lines to my proposal explaining the reason behind opting Astar.
Mukul
On Thu, Apr 25, 2013 at 8:55 PM, Stephen Woodbridge <woodbri@swoodbridge.com> wrote:
computation time.Right, so in your proposal, you want to be clear that the benefit will be achieved using astar or another algorithm with a heuristic and not dijkstra. I understand that “shortest path” is a generic reference to all of these algorithms, but the only ones that will benefit from this approach will be ones with a heuristic that allow us to explore only a subset the overall bounding box of edges that we might otherwise use as input. So it is best to be clear on these points.
-Steve
game theory
network
mailto:[woodbri@swoodbridge.com](mailto:woodbri@swoodbridge.com)>> wrote:Hi Mukul,
<http://theory.stanford.edu/%7E__amitp/GameProgramming/__AStarComparison.html><http://theory.stanford.edu/%__7Eamitp/GameProgramming/__AStarComparison.html
<http://theory.stanford.edu/%7Eamitp/GameProgramming/AStarComparison.html>>
project?-Steve
**Name:Mukul Priya
*Country:*India
B.Tech + Masters in
computer
Science And
mailto:[mukul2047@gmail.com](mailto:mukul2047@gmail.com) <mailto:mukul2047@gmail.com
mailto:[mukul2047@gmail.com](mailto:mukul2047@gmail.com)>>Phone:+91 9885991061
graph
assembly
routing
algorithm
like
partitioning
of routing
when the
shortest
incremental
graph
Shortest Path
2. Background
support for
observe that
the graph
on the
same track
can be
very large ,
lot more
support for
Say , we
start
if the
number of
squares and
allot the
be addressed
the grid
they are
edges as
they can
idea is to
first flag
grid cell
appended
to the
database
tables
quickly using a
the quad tree
table for the
id Node_id \
unique
for each
grid in
which the
node lies.geometry;
CREATE TABLE edge {
int id ;
Int node_a;
traversal cost
and return
cost.}
edges form
edge table
related to
we are
loaded and
continue if
grid and
continue
with the routing;}
stop;
4. Project plan
project. The
tentative
environment
structures
and data
partitioning
using quad
generation and
routing
report and
documentation.
algorithms
like
updating cost
implemented using
project and
performance of
various
software
purposes and
windows
purposes). For
,python
,Java and
that i
had with
the only
lab in
familiar
with and
Quantum ,
platform that was
with GIS
programming
extensively
while
source
launched way
back in
introduced to
me when
informatics
The best
part is
interested in
you if you
are stuck.
OSGeo and the
using
platforms
implemented are
get an insight
coding
actually very
approaches so
that the
studies/degree? If
related to my
proposal
publication in
active member of
never
knew where
like me
to take a
ideas like
querries) which
can be
working for
contributing
to the
equivalent to a
will try
to give
official coding
period?
<mailto:woodbri@swoodbridge.__com mailto:[woodbri@swoodbridge.com](mailto:woodbri@swoodbridge.com)><mailto:woodbri@swoodbridge.
mailto:[woodbri@swoodbridge](mailto:woodbri@swoodbridge).____com<mailto:woodbri@swoodbridge.__com
mailto:[woodbri@swoodbridge.com](mailto:woodbri@swoodbridge.com)>>> wrote:On 4/24/2013 2:34 PM, Mukul priya wrote:
system. Do
have a look
at it.
of it
here also. I
visibility to
-Steve
mailto:[pgrouting-dev@lists.osgeo.org](mailto:pgrouting-dev@lists.osgeo.org)><mailto:pgrouting-dev@lists.
mailto:[pgrouting-dev@lists](mailto:pgrouting-dev@lists).____osgeo.org <http://osgeo.org>
mailto:[pgrouting-dev@lists.osgeo.org](mailto:pgrouting-dev@lists.osgeo.org)>>
<http://lists.osgeo.org/__mailman/listinfo/pgrouting-dev>__><http://lists.osgeo.org/____mailman/listinfo/pgrouting-dev
<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>>>
<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>__>
Hi steve , i have edited my proposal based on our previous discussion ( added some lines about Astar) .meanwhile do suggest if there is scope of some improvement .
Thanks
Mukul
Mukul
-Steve
game theory
network
project?-Steve
**Name:Mukul Priya
*Country:*India
B.Tech + Masters in
computer
Science And
graph
assembly
routing
algorithm
like
partitioning
of routing
when the
shortest
incremental
graph
Shortest Path
2. Background
support for
observe that
the graph
on the
same track
can be
very large ,
lot more
support for
Say , we
start
if the
number of
squares and
allot the
be addressed
the grid
they are
edges as
they can
idea is to
first flag
grid cell
appended
to the
database
tables
quickly using a
the quad tree
table for the
id Node_id \
unique
for each
grid in
which the
node lies.geometry;
CREATE TABLE edge {
int id ;
Int node_a;
traversal cost
and return
cost.}
edges form
edge table
related to
we are
loaded and
continue if
grid and
continue
with the routing;}
stop;
4. Project plan
project. The
tentative
environment
structures
and data
partitioning
using quad
generation and
routing
report and
documentation.
algorithms
like
updating cost
implemented using
project and
performance of
various
software
purposes and
windows
purposes). For
,python
,Java and
that i
had with
the only
lab in
familiar
with and
Quantum ,
platform that was
with GIS
programming
extensively
while
source
launched way
back in
introduced to
me when
informatics
The best
part is
interested in
you if you
are stuck.
OSGeo and the
using
platforms
implemented are
get an insight
coding
actually very
approaches so
that the
studies/degree? If
related to my
proposal
publication in
active member of
never
knew where
like me
to take a
ideas like
querries) which
can be
working for
contributing
to the
equivalent to a
will try
to give
official coding
period?
system. Do
have a look
at it.
of it
here also. I
visibility to
-Steve
Hi Mukul,
I think your proposal looks good. Daniel may have some additional comment. At this point if you have time, you might want to start with getting a github account, forking the pgrouting project, making sure you can build the existing project and install it under pg 9.2.
Regarding the Astar algorithm, you might want to look at implementing your own algorithm unless you want to try and work with the existing Boost code as this might be easier in the long run. Either way some research now, might help you with your planning later. This would allow you to work out all the basics of working in our environment and give you a head start. In the past the most successful and less stressed projects have been those that took an interest early on as these details can be frustrating and time consuming. This is totally at you option because the proposal has not been accepted yet.
Thank you putting together an interesting proposal that would add value to the project.
-Steve
some improvement .Thanks
Mukul
<mailto:mukul2047@gmail.com>> wrote:Thanks Steve will add a few lines to my proposal explaining the
reason behind opting Astar.Mukul
<woodbri@swoodbridge.com <mailto:woodbri@swoodbridge.com>> wrote:On 4/25/2013 11:06 AM, Mukul priya wrote:
algorithm?This will be reduced significantly while using Astar as we
will have a
should proceed
loading of less
path
reduced as we will
positive effect on
it is best to be clear on these points.-Steve
<mailto:woodbri@swoodbridge.com>>> wrote:On 4/25/2013 12:26 AM, Mukul priya wrote:
heuristic to guide
it in our
game theory
life road
network
each algorithm?
<mailto:woodbri@swoodbridge.com>>>> wrote:Hi Mukul,
out discussion. One
dijkstra should be
http://theory.stanford.edu/~______amitp/GameProgramming/______AStarComparison.html
<http://theory.stanford.edu/~____amitp/GameProgramming/____AStarComparison.html><http://theory.stanford.edu/%\_\_7E\_\_amitp/GameProgramming/\_\_\_\_AStarComparison\.html
<http://theory.stanford.edu/~__amitp/GameProgramming/__AStarComparison.html>><http://theory.stanford.edu/%\_\_\_\_7Eamitp/GameProgramming/\_\_\_\_AStarComparison\.html
<http://theory.stanford.edu/%\_\_7Eamitp/GameProgramming/\_\_AStarComparison\.html><http://theory.stanford.edu/%\_\_7Eamitp/GameProgramming/\_\_AStarComparison\.html
<http://theory.stanford.edu/~amitp/GameProgramming/AStarComparison.html>>>Do you see why? and specifically why it matter
for this
project?-Steve
*Country:*India
Institute Of InformationTechnology-Hyderabad ,
B.Tech +
Masters in
computer
Science And
<mailto:mukul2047@gmail.com>> <mailto:mukul2047@gmail.com
<mailto:mukul2047@gmail.com>>>>*Phone*:+91 9885991061
demand increment
graph
assembly
towards providing
routing
shortest path
algorithm
like
consuming. Network
partitioning
time efficiency
of routing
approach and
when the
shortest
on demand
incremental
graph
implementing a
Shortest Path
approach.*2. Background*
where pgRouting has
support for
we can
observe that
the graph
will also be
on the
same track
destination
can be
very large ,
too it will be
lot more
addition to their
support for
idea .*
tree approach.
Say , we
start
in a square .
if the
number of
into four
squares and
allot the
they all will
be addressed
number based on
the grid
they are
edges as
they can
cells.the
idea is to
first flag
crosses/intersects.*
identify the
grid cell
that will get
appended
to the
have appropriate
database
tables
edges
quickly using a
the above are :we will first partition the whole
graph using
the quad tree
database
table for the
id Node_id
unique
for each
\\ the
grid in
which the
node lies.geometry;
CREATE TABLE edge {
int id ;
Int node_a;
int node_b; \\ the
connecting nodes// we can have other parameters like
traversal cost
and return
cost.}
fetch the
edges form
edge table
number very easily.In short the summary of the whole idea is :
related Grid cell
all the items
related to
is done while
we are
grid is
loaded and
continue if
with the new
grid and
continue
with the routing;}
stop;
*4. Project plan*
implement the
project. The
tentative
environment
various data
structures
and data
network
partitioning
using quad
demand graph
generation and
routing
Draft Final
report and
documentation.*
shortest path
algorithms
like
greatly reduce the
updating cost
that are loaded.In route nearest neigbour querries
can also be
implemented using
other algorithms.*Explain how your SoC task would benefit
the OSGeo member
project and
improve the
performance of
pgRouting. For
various
software
improve.*
academic
purposes and
windows
programming
purposes). For
have used C++
,python
,Java and
only experience
that i
had with
course.*
the only
lab in
learning. I am
familiar
with and
platforms like
Quantum ,
rendering
platform that was
involvement
with GIS
programming
i used it
extensively
while
shape files.*Please tell us why you are interested in
GIS and open
source
when it was
launched way
back in
Openjump were
introduced to
me when
Lab for spatial
informatics
The best
part is
that you are
interested in
there to help
you if you
are stuck.*
working for
OSGeo and the
i have been
using
platforms
that they have
implemented are
great if i
get an insight
your specific
coding
world networks is
actually very
with good
approaches so
that the
ongoing
studies/degree? If
closely
related to my
proposal
get a
publication in
being an
active member of
programming but
never
knew where
for beginners
like me
to take a
i have other
ideas like
querries) which
can be
intentions like
working for
Grass.I will be
contributing
to the
commitment,
equivalent to a
commitment and
will try
to give
during the
official coding
period?
Woodbridge
<mailto:woodbri@swoodbridge>.
<mailto:woodbri@swoodbridge>.>______com<mailto:woodbri@swoodbridge.
<mailto:woodbri@swoodbridge.com>>>>> wrote:On 4/24/2013 2:34 PM, Mukul priya wrote:
Melange Gsoc
system. Do
have a look
at it.
or the text
of it
here also. I
I may not have
visibility to
-Steve_______________________________________________________
<mailto:pgrouting-dev@lists>.
<mailto:pgrouting-dev@lists>.>______osgeo.org
<http://osgeo.org> <http://osgeo.org>
<mailto:pgrouting-dev@lists.osgeo.org>>>>
http://lists.osgeo.org/________mailman/listinfo/pgrouting-dev <http://lists.osgeo.org/______mailman/listinfo/pgrouting-dev><http://lists.osgeo.org/______mailman/listinfo/pgrouting-dev
<http://lists.osgeo.org/____mailman/listinfo/pgrouting-dev>\_\_><http://lists.osgeo.org/______mailman/listinfo/pgrouting-dev
<http://lists.osgeo.org/__mailman/listinfo/pgrouting-dev>\_\_>\_\_><http://lists.osgeo.org/______mailman/listinfo/pgrouting-dev
<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>\_\_>\_\_>\_\_>_____________________________________________________
<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>\_\_>\_\_>_____________________________________________________
Thanks Steve . i will go through the steps that you have mentioned once i am free from all my academic commitments by the end of this month ( in 2-3 days at max).
-Mukul
On Sat, Apr 27, 2013 at 6:59 PM, Stephen Woodbridge <woodbri@swoodbridge.com> wrote:
Hi Mukul,
-Steve
Mukul
will have a
should proceed
loading of less
path
reduced as we will
positive effect on
mailto:[woodbri@swoodbridge.com](mailto:woodbri@swoodbridge.com)>> wrote:On 4/25/2013 12:26 AM, Mukul priya wrote:
heuristic to guide
it in our
game theory
life road
network
each algorithm?
mailto:[woodbri@swoodbridge.com](mailto:woodbri@swoodbridge.com)>>> wrote:Hi Mukul,
out discussion. One
dijkstra should be
<http://theory.stanford.edu/%7E____amitp/GameProgramming/____AStarComparison.html><http://theory.stanford.edu/%__7E__amitp/GameProgramming/____AStarComparison.html
<http://theory.stanford.edu/%7E__amitp/GameProgramming/__AStarComparison.html>><http://theory.stanford.edu/%____7Eamitp/GameProgramming/____AStarComparison.html
<http://theory.stanford.edu/%__7Eamitp/GameProgramming/__AStarComparison.html><http://theory.stanford.edu/%__7Eamitp/GameProgramming/__AStarComparison.html
<http://theory.stanford.edu/%7Eamitp/GameProgramming/AStarComparison.html>>>Do you see why? and specifically why it matter
for this
project?-Steve
**Name:Mukul Priya
*Country:*India
B.Tech +
Masters in
computer
Science And
mailto:[mukul2047@gmail.com](mailto:mukul2047@gmail.com)> <mailto:mukul2047@gmail.com
mailto:[mukul2047@gmail.com](mailto:mukul2047@gmail.com)>>>Phone:+91 9885991061
demand increment
graph
assembly
towards providing
routing
shortest path
algorithm
like
consuming. Network
partitioning
time efficiency
of routing
approach and
when the
shortest
on demand
incremental
graph
implementing a
Shortest Path
approach.2. Background
where pgRouting has
support for
we can
observe that
the graph
will also be
on the
same track
destination
can be
very large ,
too it will be
lot more
addition to their
support for
idea .
tree approach.
Say , we
start
in a square .
if the
number of
into four
squares and
allot the
they all will
be addressed
number based on
the grid
they are
edges as
they can
cells.the
idea is to
first flag
crosses/intersects.
identify the
grid cell
that will get
appended
to the
have appropriate
database
tables
edges
quickly using a
graph using
the quad tree
database
table for the
id Node_id
unique
for each
\ the
grid in
which the
node lies.geometry;
CREATE TABLE edge {
int id ;
Int node_a;
int node_b; \ the
traversal cost
and return
cost.}
fetch the
edges form
edge table
related Grid cell
all the items
related to
is done while
we are
grid is
loaded and
continue if
with the new
grid and
continue
with the routing;}
stop;
4. Project plan
implement the
project. The
tentative
environment
various data
structures
and data
network
partitioning
using quad
demand graph
generation and
routing
Draft Final
report and
documentation.
shortest path
algorithms
like
greatly reduce the
updating cost
can also be
implemented using
other algorithms.Explain how your SoC task would benefit
the OSGeo member
project and
improve the
performance of
pgRouting. For
various
software
improve.
academic
purposes and
windows
programming
purposes). For
have used C++
,python
,Java and
only experience
that i
had with
course.
experience:*I am a part of “Lab for Spatial
the only
lab in
learning. I am
familiar
with and
platforms like
Quantum ,
rendering
platform that was
involvement
with GIS
programming
i used it
extensively
while
shape files.Please tell us why you are interested in
GIS and open
source
when it was
launched way
back in
Openjump were
introduced to
me when
Lab for spatial
informatics
The best
part is
that you are
interested in
there to help
you if you
are stuck.
working for
OSGeo and the
i have been
using
platforms
that they have
implemented are
great if i
get an insight
your specific
coding
world networks is
actually very
with good
approaches so
that the
ongoing
studies/degree? If
closely
related to my
proposal
get a
publication in
being an
active member of
programming but
never
knew where
for beginners
like me
to take a
i have other
ideas like
querries) which
can be
intentions like
working for
Grass.I will be
contributing
to the
commitment,
equivalent to a
commitment and
will try
to give
during the
official coding
period?
Woodbridge
mailto:[woodbri@swoodbridge.com](mailto:woodbri@swoodbridge.com)>><mailto:woodbri@swoodbridge
mailto:[woodbri@swoodbridge](mailto:woodbri@swoodbridge).>______com<mailto:woodbri@swoodbridge.
mailto:[woodbri@swoodbridge.com](mailto:woodbri@swoodbridge.com)>>>> wrote:On 4/24/2013 2:34 PM, Mukul priya wrote:
Melange Gsoc
system. Do
have a look
at it.
or the text
of it
here also. I
I may not have
visibility to
-Steve
mailto:[pgrouting-dev@lists.osgeo.org](mailto:pgrouting-dev@lists.osgeo.org)>><mailto:pgrouting-dev@lists
mailto:[pgrouting-dev@lists](mailto:pgrouting-dev@lists).>______osgeo.org
<http://osgeo.org> <http://osgeo.org><mailto:pgrouting-dev@lists.
mailto:[pgrouting-dev@lists.osgeo.org](mailto:pgrouting-dev@lists.osgeo.org)>>>http://lists.osgeo.org/________mailman/listinfo/pgrouting-dev <http://lists.osgeo.org/______mailman/listinfo/pgrouting-dev>
<http://lists.osgeo.org/____mailman/listinfo/pgrouting-dev>__><http://lists.osgeo.org/______mailman/listinfo/pgrouting-dev
<http://lists.osgeo.org/__mailman/listinfo/pgrouting-dev>>>
<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>>>__>
Hi steve ,
I have forked the pgrouting project and cloned it to my local machine. My git username is “mukulpriya”. i will get through the installation process and post doubts in case i get stuck somewhere.
regards,
mukul
-Mukul
Hi Mukul,
-Steve
Mukul
will have a
should proceed
loading of less
path
reduced as we will
positive effect on
heuristic to guide
it in our
game theory
life road
network
each algorithm?
out discussion. One
dijkstra should be
for this
project?-Steve
**Name:Mukul Priya
*Country:*India
B.Tech +
Masters in
computer
Science And
demand increment
graph
assembly
towards providing
routing
shortest path
algorithm
like
consuming. Network
partitioning
time efficiency
of routing
approach and
when the
shortest
on demand
incremental
graph
implementing a
Shortest Path
where pgRouting has
support for
we can
observe that
the graph
will also be
on the
same track
destination
can be
very large ,
too it will be
lot more
addition to their
support for
idea .
tree approach.
Say , we
start
in a square .
if the
number of
into four
squares and
allot the
they all will
be addressed
number based on
the grid
they are
edges as
they can
cells.the
idea is to
first flag
crosses/intersects.
identify the
grid cell
that will get
appended
to the
have appropriate
database
tables
edges
quickly using a
graph using
the quad tree
database
table for the
id Node_id
unique
for each
\ the
grid in
which the
node lies.geometry;
CREATE TABLE edge {
int id ;
Int node_a;
int node_b; \ the
traversal cost
and return
cost.}
fetch the
edges form
edge table
related Grid cell
all the items
related to
is done while
we are
grid is
loaded and
continue if
with the new
grid and
continue
with the routing;}
stop;
4. Project plan
implement the
project. The
tentative
environment
various data
structures
and data
network
partitioning
using quad
demand graph
generation and
routing
Draft Final
report and
documentation.
shortest path
algorithms
like
greatly reduce the
updating cost
can also be
implemented using
the OSGeo member
project and
improve the
performance of
pgRouting. For
various
software
improve.
academic
purposes and
windows
programming
purposes). For
have used C++
,python
,Java and
only experience
that i
had with
course.
the only
lab in
learning. I am
familiar
with and
platforms like
Quantum ,
rendering
platform that was
involvement
with GIS
programming
i used it
extensively
while
GIS and open
source
when it was
launched way
back in
Openjump were
introduced to
me when
Lab for spatial
informatics
The best
part is
that you are
interested in
there to help
you if you
are stuck.
working for
OSGeo and the
i have been
using
platforms
that they have
implemented are
great if i
get an insight
your specific
coding
world networks is
actually very
with good
approaches so
that the
ongoing
studies/degree? If
closely
related to my
proposal
get a
publication in
being an
active member of
programming but
never
knew where
for beginners
like me
to take a
i have other
ideas like
querries) which
can be
intentions like
working for
Grass.I will be
contributing
to the
commitment,
equivalent to a
commitment and
will try
to give
during the
official coding
period?
Woodbridge
Melange Gsoc
system. Do
have a look
at it.
or the text
of it
here also. I
I may not have
visibility to
-Steve
