Hello Everyone,
My Wiki [1]
My Forked Repository [2]
This is my report for Coding Period Week 2 (June 8th - June 14th).
- What did I get done this week?
- Started coding on my boost planar Graph function
pgr_boyerMyrvoldin the branch named him in my forked repository. Completed with coding of the function. - Modified and added all the required files for the implementation of my function.
- Details can be found in [3]
- The merged pull request can be found in [4]
- What do I plan on doing next week?
- Currently the data returned after the query is displayed incorrectly at the respective columns. I will be fixing this bug.
- The pgTAP tests of
pgr_boyerMyrvoldare remaining. So, in the coming week, I plan to add all the pgTAP tests - Server no crash test for null parameters, parameters type check, inner query tests, and the unit tests - one vertex, one edge, two edges, cycle with 3 edges, etc after the above bug is removed. - I will also be working on the documentation of this function.
- Am I blocked on anything?
- Currently the data returned after the query is displayed incorrectly at the respective columns. One of the columns is showing garbage values. I am trying to fix this bug.
- Apart from this I don’t have any blocking issues.
Himanshu Raj
Links:
[1] WIKI
[2] Forked Repository
[3] https://github.com/pgRouting/pgrouting/wiki/GSoC-2020-Implementation-of-Edge-Contraction-Technique-in-pgRouting#week-2-june-8th—june-15th-1
[4] Merged Pull Request
