Hi Guys,
The last two weeks of GSoC are rapidly approaching as you are aware.
Your priority at this point so to make sure your code can be called from SQL and return its results to SQL. This should be your priority to insure that this works ASAP, then you can go back to fine tuning your algorithm.
Mukul, your code should be in pretty good shape but you should check and verify that nothing has broken.
Mani, I know you are working on this. Ask questions if you get stuck, time is short.
-Steve
I will prioritize the SQL querry and some documentation for now and then come back to improvization.
ยทยทยท
On Tue, Aug 5, 2014 at 7:01 PM, Stephen Woodbridge <woodbri@swoodbridge.com> wrote:
Hi Guys,
-Steve
