I am working on the implementation of maximum flow algorithms and their applications for pgRouting during the GSoC 2016. This is my tenth report.
- What did you get done this week?
This week I did the code improvements I mentioned last week. All of the functions now have an additional return value that represents the ID of the original edge in the graph. This meant I had to refactor docs and tests.
For the remainder of the week, a lot of work went into making sure the project builds correctly on Travis and Appveyor, with the tests included.
- What do you plan on doing next week?
Next week I am going to be on holiday, so I will not be able to work.
- Are you blocked on anything?
No.
You can check the branch I’m working on here:
https://github.com/Illedran/pgrouting/tree/gsoc-flow
Best regards,
Andrea Nardelli
