I am working on the implementation of maximum flow algorithms and their applications for pgRouting during the GSoC 2016. This is my second report.
- What did you get done this week?
I implemented an additional wrapper using Boost and wrote some tests. I cleaned up/refactored some of the code, in particular the common library between all the implementations(the one that handles creating the graph and returning the results).
- What do you plan on doing next week?
As written in my application, next week I won’t be able to work as much due to finals at my university. However, I think I can manage to add the last implementation from Boost.
- Are you blocked on anything?
No, but I need to learn how to write the documentation more efficiently.
You can check the branch I’m working on here:
https://github.com/Illedran/pgrouting/tree/gsoc-flow
Best regards,
Andrea Nardelli
