I am working on the implementation of maximum flow algorithms and their applications for pgRouting during the GSoC 2016. This is my eigth report.
- What did you get done this week?
This week I started studying the algorithm in the paper I linked last week. It is quite complicated and requires knowledge of a lot of other algorithms (it is made up of different sub-algorithms with better complexities it can fall back to). I started prototyping these in Python.
For the rest of the week I implemented a way for the edge_disjoint_paths function to actually return the paths and not just their number.
- What do you plan on doing next week?
Next week I plan to do several things:
- Continue studying additional max_flow implementations.
- Finish up all the possible signatures for the new edge_disjoint_paths function.
- While working this week, I realized that there are a lot of small things I can add and improve through the codebase, in regards to both functionality and efficiency.
- Are you blocked on anything?
No.
You can check the branch I’m working on here:
https://github.com/Illedran/pgrouting/tree/gsoc-flow
Best regards,
Andrea Nardelli
