Hi everyone,
1.
What did you get done this week?
I generated the initial code for pgr_dijkstraTRSP using the template
pgr_dijkstra code. I also learnt about the testing mechanism used in
pgRouting. I learnt to use pgtap to create unit tests and also implemented
pgtap tests for the pgr_dijkstraTRSP function.
- Details can be found in [1]
- Set of pull requests can be found in [2]
2.
What am I going to achieve for next week?
I hope to complete the design of the restrictions table and implement
the C code that reads and executes the queries from Postgresql.
Details of possible sub tasks can be found in [3]
3.
Is there any blocking issue?
I am currently blocked on designing the restrictions table since that
needs to be as generic as possible.
- The wiki page can be found in [4]
- The repository can be found in [5]
[1]
https://github.com/pgRouting/pgrouting/wiki/GSoC-2017-Rewrite-TRSP/#first-evaluation-period
[2]
https://github.com/pgRouting/pgrouting/wiki/GSoC-2017-Rewrite-TRSP/#project
[4] https://github.com/pgRouting/pgrouting/wiki/GSoC-2017-Rewrite-TRSP
[5] https://github.com/pgRouting/pgrouting/tree/gsoc/rewritetrsp
Best Regards,
Vidhan Jain
