Hi everyone,
What did you get done this week?
This week, I created
pgr_dijkstraTRSP.hpp
file which will hold the main logic of thedijkstraTRSP
. In certain scenarios, the result returned by dijkstra may not contain restriction. I had also implemented the logic to determine whether the result returned bydijkstra
contains a turn restriction.- Details can be found in [1]
- Set of pull requests can be found in [2]
What am I going to achieve for next week?
I’ll be implementing the functionality to convert a given graph into its corresponding Line graph in the coming week.
Details of possible sub tasks can be found in [3]
Is there any blocking issue?
Currently, I am not blocked on anything.
- The wiki page can be found in [4]
- The repository can be found in [5]
[1] https://github.com/pgRouting/pgrouting/wiki/GSoC-2017-Rewrite-TRSP/#first-evaluation-period
[2] https://github.com/pgRouting/pgrouting/wiki/GSoC-2017-Rewrite-TRSP/#log-of-pull-requests
[4] https://github.com/pgRouting/pgrouting/wiki/GSoC-2017-Rewrite-TRSP
[5] https://github.com/pgRouting/pgrouting/tree/gsoc/rewritetrsp
Best of luck everyone for the next week.
Vidhan Jain
