Hello All,
This is my week 3 report (May 28 - June 3).
What did you get done this week? I uses connected component for disconnected graph to get minimum spanning tree of all sub-graph. I added the functionality of choosing root vertex. Create test and documentation of pgr_prim.
Detailed can be found here [1] and PR can be found here [2].
What do you plan on doing next week?
- Create pgTAP of pgr_prim function and if time permit then start with kruskal algorithm.
Are you blocked on anything?
No, at the moment I’m not blocked.
The wiki page can be found in [3]
The repository can be found in [4]
[1] https://github.com/pgRouting/pgrouting/wiki/GSoC-2018-MST-and-Mincut#week-3
[2] https://github.com/pgRouting/pgrouting/pull/1038
[3] https://github.com/pgRouting/pgrouting/wiki/GSoC-2018-MST-and-Mincut
[4] https://github.com/pgRouting/pgrouting/tree/gsoc/mincut
Aditya Pratap Singh
