On Sun, Jul 10, 2016 at 9:42 AM, Daniel Kastl <daniel@georepublic.de> wrote:
This is my own memo how to build pgRouting with documentation, and how to publish it to GH-Pages and Transifex:
https://gist.github.com/dkastl/5617030
Vicky did the documentation updates in the past months, so I’m not sure all dependencies and commands are still 100% the same with newer versions of Ubuntu for example.
But I just run this part and it worked for me: https://gist.github.com/dkastl/5617030#file-build_pgrouting-sh-L9-L13heers
At least “html” worked for me. It seems PDF generation has errors.
Daniel
pgrouting-dev mailing list
pgrouting-dev@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
On Sun, Jul 10, 2016 at 11:16 PM, Worth Lutz <wal3@mindspring.com> wrote:
I tried all that and do not see where the updated documentation ends up.
After doing the build, pointing to:
~/pgrouting/build/doc/html/index.html
does not seem to work for me. I’m obviously missing something.
Worth Lutz
On 7/9/2016 10:06 AM, Daniel Kastl wrote:
Sorry, should be “cmake” of course.
… auto correction…
On Jul 9, 2016 11:05 PM, “Daniel Kastl” <daniel@georepublic.de> wrote:
The documentation is compiled with cake using a special compile flag, see https://github.com/pgrouting/pgrouting/tree/develop#compilation
We probably need to make this easier to find in the documentation ![:wink: :wink:](https://discourse.osgeo.org/images/emoji/twitter/wink.png?v=12)
Daniel
On Jul 9, 2016 9:15 PM, “Worth Lutz” <wal3@mindspring.com> wrote:
I have been side tracked a bit but have been reading the documentation extensively over the past week. I have had some success working with my data and will be rereading the docs to make sure my understanding is correct. I’ll then commit the corrections and additions I’m working on.
How do I run the docs locally. I am familiar with Sphinx but have not found the place to
make html
I see a make.bat file but that is for Windows. I normally work on Ubuntu and have a Makefile in the directory as well as make.bat. Is development normally done on Windows? And thus the Makefile removed when make.bat was edited?
Thanks for your help.
Worth Lutz
On 7/8/2016 11:18 PM, Vicky Vergara wrote:
I merged code and more documentation to develop.
Here is a helpful link for keeping up to date the branches:
http://docs.pgrouting.org/doxy/2.3-dev-develop/index.html#up_to_date
[pgrouting-dev@lists.osgeo.org](mailto:pgrouting-dev@lists.osgeo.org)
[http://lists.osgeo.org/mailman/listinfo/pgrouting-dev](http://lists.osgeo.org/mailman/listinfo/pgrouting-dev)
Georepublic UG & Georepublic Japan
eMail: daniel.kastl@georepublic.de
Web: http://georepublic.info
On Wed, Jun 22, 2016 at 7:57 PM, Vicky Vergara <vicky@georepublic.de> wrote:
Thanks
Georepublic UG (haftungsbeschränkt)
Salzmannstraße 44,
81739 München, Germany
Vicky Vergara
Operations Research
eMail: vicky@[georepublic.de](http://georepublic.de)
Web: [https://georepublic.info](https://georepublic.info)
Tel: +49 (089) 4161 7698-1
Fax: +49 (089) 4161 7698-9
Commercial register: Amtsgericht München, HRB 181428
CEO: Daniel Kastl
On Wed, Jun 22, 2016 at 2:10 PM, Worth Lutz <wal3@mindspring.com> wrote:
Vicky,
My github is at:
https://github.com/worthlutz/pgrouting/
The branch I’ll be using is doc-improvements branched off develop.
I’ll let you know when I push some changes.
Worth Lutz
On 06/22/2016 02:06 PM, Vicky Vergara wrote:
Tell when you make the branch
so I can pinpoint where to find the docuemtnation
Salzmannstraße 44,
Vicky Vergara
Operations Research
CEO: Daniel Kastl
On Wed, Jun 22, 2016 at 12:58 PM, Worth Lutz <wal3@mindspring.com> wrote:
Thanks Vicky. I’ll let you know what I find.
Worth Lutz
On 6/22/2016 1:53 PM, Vicky Vergara wrote:
Hello Worth Lutz.
The documentation changes you made them to master or to develop?
Right now develop documentation has changed, not in everything put it has lots of changes.
http://docs.pgrouting.org/dev/en/doc/index.html
It is better for us to work on the develop branch which has the 2.3 documentation.
Its changing a lot. so to have the current contents of develop in your for:
git checkout develop
git fetch upstream
git merge upstream/develop
git push
then in the github site you will be able to see that it contains the current contents of develop.
Then you can branch to a working directory
git checkout -b ‘improve/documentation’
then do a
git push
and give me the link to the branch in your repository so that if I make changes to develop’s documentation, I can make a pull request to your branch with the changes I made.
Work on the documentation, and make pull requests to develop.
thanks.
Vicky from the pgRouting team
Salzmannstraße 44,
Vicky Vergara
Operations Research
CEO: Daniel Kastl
On Wed, Jun 22, 2016 at 12:10 PM, Worth Lutz <wal3@mindspring.com> wrote:
If I want to work on some errors/typos in the documentation, how do I do that?
I’ve got a fork and want to create a pull request.
Which branch should I be working on?
As I’m starting a new routing project, I’m reading (and rereading) the documentation a lot and think I should fix what I find.
Worth Lutz
Salzmannstraße 44,
Vicky Vergara
Operations Research
CEO: Daniel Kastl
Salzmannstraße 44,
Vicky Vergara
Operations Research
CEO: Daniel Kastl
