I'm not a C++ programmer, but from what I have read on the boost list, it seems that the path to writing generic templates is to write the code first in regular C++ so it works and then refactor it to be more generic. So step 1 is to do as you proposed.
Also since this project is to implement a "time dependent dijkstra algorithm" in pgRouting, the generic templates seems to be out of scope. It would be fine to do if you had the time and skill, but I think your approach makes sense, use the tools that make your job easier and allow you to achieve success.
As initially discussed, I was trying to reuse the boost's dijkstra code
to write the core time dependent dijkstra algorithm.
Since Boost makes extensive use of generic programming, and I have no
prior experience with such deep generic programming concepts, I was
wondering if we really need all these features that boost provides.
Another option would be to write the time-dependent dijkstra on our own.
This will be a light-weight code without extensive use of generic
programming like boost.
So, i was thinking of using following:
*1. *Boost::AdjecencyList - for storing graph.
*2. *Std::Map - for storing distanceMap, predecessorMap.
*3. *For weightMap:
typedef struct weight_map_element
pair<int,double> edge;
double travel_time;
weight_map_element_t;
class weight_map
vector<weight_map_element_t> weight_map_set;
public:
void insert(weight_map_element_t element);
double get_travel_time(int edge_id, double start_time);
*4. *std::priority_queue for the priority queue that will be used for
dijkstra search.
Will this be sufficient for our implementation? If yes, I will come up
with the detailed internal function prototypes soon.
On Wed, May 18, 2011 at 8:09 PM, Stephen Woodbridge
<woodbri@swoodbridge.com <mailto:woodbri@swoodbridge.com>> wrote:
On 5/18/2011 8:08 AM, Jay Mahadeokar wrote:
I think what we need is a function on following lines:
Given a query_start_time, it should query the TimeDepCosts
table, and
return the set of entries which have their start_time within
query_start_time + delta. This delta might be x hours, depending
on the
upper bound of the expected journey time.
We need following things handled in our model:
If query_start_time is 11PM Sunday and delta is 10 hours, we
will need
to query entries with start time between 11PM Sunday and 9AM
Monday. So,
basically the function needs to be periodic in terms of
time_of_day and
day_of_week.
As Steve suggested, we can maintain conventions for day_of_week
like:
-3 - holidays
-2 - weekend days
-1 - week days
0 - all days
1-7 Mon - Sun.
If we just assume entries for -3,-2,-1,0 and ignore each entry
for Sun -
Sat, that would reduce the space required assuming that the
entries for
weekdays is same. If times for different weekdays is different
then we
would have separate entries for each day.
So, the query should properly examine the query_day_of_week and
select
the proper entries. Ex: For above query, if it is sunday, then after
12AM, next entries will be queried with time_of_day as -1, but
if it was
Saturday, next entries will be queried with time_of_day as -2.
We can have a boolean parameter like *isHoliday* in query
itself, which
will tell if a given day (may be weekday) is holiday or not.Then
again
the query will have to be modified accordingly (query for -3).
This will
take care of query for local holiday etc and we do not have to worry
about calenders. The user will have to worry about that.. ![:slight_smile: :slight_smile:](/images/emoji/twitter/slight_smile.png?v=12)
This (isHoliday) might work for a single day, but will not work if
the query crosses into the next day(s). Holidays are an input
convenience to describe recurring events. So say we have a
convenient way to input that data and store it into tables as we
have described, then the query for costs would need to decide is a
given day is a holiday or not and then select the correct entries to
return based on that. For ease of implementation, we could just
start with a stub function the returns false and later implement a
table lookup based on the date or day of year that determines if
isHoliday=t/f for any given start_time+offset.
Then when querying schedules, for example, we would select holiday
schedules if they exist and its a holiday otherwise search the
regular tables.
There can be time_from and time_to entries as well. But, if we
just have
entries like:
day_of_week: -1, time_of_day: 00:01, 55mph
day_of_week: -1, time_of_day: 07:00, 30mph
day_of_week: -1, time_of_day: 10:01, 55mph
day_of_week: -1, time_of_day: 16:31, 30mph
we can assume that the entry with time_of_day 00:01 is valid upto
07:00. And if query_start_time is 02:00 and delta is 10 hours,
we can
query entries which have time_of_day < query_start_time + delta
(taking
care of change of day).
Is this assumption reasonable?
This sounds reasonable if the response is in units of time (offset)
from query_start_time. Assuming we use a resolution of seconds, then
the response would be in seconds from start time.
*weightMap Abstraction*
I think the design would be more modular if we keep the weightMap
independent of the underlying time conventions. Since as Daniel
pointed
out, this algorithm can also be used for non-road networks.
So, whatever the underlying time conventions, we can assume that
in the
end the query should return pairs like:
< <edgeId, offset_time> , travel_time/speed >
We will assume that query_start_time is 0, i.e we offset every
thing by
query_start_time.
The offset_time will be as follows:
As in above example,
If start_tme is 02:00 and day_of_week is -1, and delta as 10 hours.
Then, edge entries for edgeId 1 will be:
< <1, 05:00 > , 30 mph>
< <1, 08:01 > , 55 mph>
< <1, 14:31 > , 30 mph>
Basically, the offset_time will abstract out any internal details of
weekdays, change of days etc and it will just contain the offset
from
start_time.
I suggested seconds above, but if someone is modeling events in say
glacier flow, geological times or the big bang, they might need
other units of time. I would say that because we are talking about
time based schedules and need to deal with days, hours minutes we
should probably not worry about these other timeframes as the solver
will be offset based it will work with any units and then only the
wrappers for extracting the costs from the schedules would need to
change to deal with other timeframes. So lets not get hung up on
this, I think this is a sound plan.
-Steve
This will greatly simplify the core time dependent dijkstra
implementation.
Thoughts?
On Wed, May 18, 2011 at 10:46 AM, Stephen Woodbridge
<mailto:woodbri@swoodbridge.com>>> wrote:
Hi Daniel,
These are good points.
I agree that turn restrictions should be thought about but only
implemented if there is time. I think we should take the
discussion
of turn restriction into a separate thread. I'm interested
in what
you think is a limitation that can't be modeled in Dijkstra
or A*.
Regarding the time modeling, my point was just that we
needed more
thought there and a richer model developed. The crontab
model is a
good idea. I'm not opposed to modeling monthly or yearly
events, but
they rarely exist other than holidays which I tried to
capture. I
suppose you could model something like the Boston Marathon
and model
all the road closures and restrictions, but it seems to be a
lot of
work for a one day event, but I can see city government's
deploying
the resources to model something like this.
Regarding timezones: Times need to be entered with zones for
models
that cross zones but all the data should be converted to UTC
internally so it runs in a consistent time model. Timezones
are for
input and output, but the solver should be ignorant of them,
in my
opinion.
I have carried my GPS from the Eastern to central time zone,
and it
knew the local time when I powered it up. So my guess is that it
would auto correct when crossing the time zone.
-Steve
On 5/17/2011 10:42 PM, Daniel Kastl wrote:
Hi Jay and Steve,
This looks really nice, but let me give some comments
regarding
how to
model time, because this is really tricky in my opinion.
Especially when
thinking about an abstract network that isn't a road
network.
Would it be possible to support turn restrictions in
the static
Dijkstra also? I'm thinking just use all the same
structures but
ignore the the time components to keep things
simple. So if
the the
turn restrictions table is present we use it, otherwise
assume no
restrictions. If doing static shortest path with turn
restrictions
then ignore the time components otherwise we use
them. And
it is up
to the user to make sure the turn restriction table
is valid
for the
analysis being requested.
Currently in pgRouting Dijkstra and A* don't support turn
restrictions
modelling. What I actually like on Shooting Star is, that it
routes from
edge to edge instead of node to node. So it allows to model
relations
between edges rather than nodes, which I think is more
close to how
humans would think of this.
Dijkstra can only visit one node one times (as Shooting star
only visits
an edge once). Well, there can be turn restriction cases
where a
node is
passed twice and which can't be done correctly with
Dijkstra as
far as I
know.
In the beginning I wouldn't think about the turn
restrictions
too much.
Let's take it as an extra when we see we still have
enough time.
Of course if you have a good idea to implement it all at
once
with only
little extra work, then that's fine.
For time definitions in your tables I think you need
to probably
define some common structure for handling a time entry.
Another problem might be time zones. Plain day field + time
field might
not be able to allow driving from one time zone to
another (or just
think about a flight network). I never went from one
timezone to
another
by car or train, but Steve and Anton, you might have this
experience.
How does car navigation software handle this when you
cross the
timezone
border? ![:wink: :wink:](/images/emoji/twitter/wink.png?v=12)
So taking "timestamp with timezone" for those fields
might be a good
idea to be able to support such a functionality.
For example time_from and time_to might need to be
defined as a
structure that includes day_of_week. day_of week
might take
values like:
-3 - holidays
-2 - weekend days
-1 - week days
0 - all days
1..7 - Sun,...,Sat
I think the problem here is how to model recurring time
dependent costs,
right?
If you think about weekdays, then you can't for example
model
monthly or
yearly events.
I'm not really sure this is useful information here, but
I once saw
about how the "iCal" format models recurring calendar
events:
http://ext.ensible.com/deploy/dev/examples/calendar/recurrence-widget.html
Maybe we can learn something from there. The example
needed to be
extended with some duration probably. But looking about
calendar
formats
might be a good idea to model holidays etc.
Or another (stupid) example would be cron job syntax.
Something
I always
need to google for as I can't remember it ![:wink: :wink:](/images/emoji/twitter/wink.png?v=12)
All this time dependent stuff, events and schedules is
also an
issue in
Darp solver.
And it probably is important also for the multi-modal
routing,
so if we
can find some clever way how to model this and can share
it between
algorihtms, that would be great.
Daniel
Georepublic UG & Georepublic Japan
eMail: daniel.kastl@georepublic.de
<mailto:daniel.kastl@georepublic.de>
<mailto:daniel.kastl@georepublic.de>>
<mailto:daniel.kastl@georepublic.de>>>
Web: http://georepublic.de/>
pgrouting-dev mailing list
pgrouting-dev@lists.osgeo.org
<mailto:pgrouting-dev@lists.osgeo.org>
<mailto:pgrouting-dev@lists.osgeo.org>>
http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
-Jay Mahadeokar
pgrouting-dev@lists.osgeo.org <mailto:pgrouting-dev@lists.osgeo.org>
-Jay Mahadeokar
