I made some comments on your proposal. Can you make another version of the proposal based on the given feedback?
Use a separate google doc for the second version and keep the first one as it is, so that it would be easy to compare both the versions.
I am extremely sorry as I did changes on same version. I didn’t read mailing lists, I started making changes as soon as I get mail. I reopen the comments so you can see what I made changes and shift pgTap of pgr_prim() and make part of phase 1. From next time I’ll remember to read mailing list first.
Thanks for your valuable feedback.
I think Google Docs has a useful “History” functionality, that allows to show changes between versions.
You can assign names to certain version and set the filter to show only named versions, which makes it easy to compare.
