Yeh it passes all tests on 64-bit
So I guess just need to figure out what to do with the line part.
#ifdef __MINGW64__
#define ELOG_H
#include <winsock2.h>
#endif
-----Original Message-----
[mailto:pgrouting-dev-bounces@lists.osgeo.org] On Behalf Of Paragon
Corporation
Sent: Monday, April 08, 2013 4:01 AM
To: 'pgRouting developers mailing list'
Subject: Re: [pgrouting-dev] Issue with compiling 64-bit under mingw64
Okay got it to compile
1) I had a dirty tree so restarted from scratch and then I started to get
the error you got even without the -DWITH_TSP=ON
2) For 64-bit I guess we can't have this line
#ifdef __MINGW64__
#define ELOG_H
#endif
I took that out and then it compiled okay -- so maybe you should only check
for the 32-bit case there (I forget what the flag is)
I still need to run the regression, but its now generating the tsp dll for
64-bit with
cmake -G "MSYS Makefiles" -DWITH_DD=ON ..
make && make install
Regina
Corporation
Sent: Monday, April 08, 2013 3:16 AM
Okay just checked my ming32 and I was wrong,
It still builds the librouting_tsp.dll without the -DWITH_TSP=ON
If I take it out of my ming64, then no attempt at building the tsp dll seems
to be done, but it compiles the others.
I wonder if the issue is that a 32-bit lib is sneaking in somewhere. That's
the occupational hazard of using 32-bit tools to build a 64-bit library.
When it comes across a 32-bit with a name it thinks it needs, things get
very confusing.
Regina
Corporation
Sent: Monday, April 08, 2013 2:53 AM
Not off hand. I can look again and rebuild. When I pulled that was the
latest without jumping into 4.6 GCC. With 4.6 GCC I had major issues with
dealing with C++ code (particularly Geos) with it randomly crashing so
avoided it like the plague.
I thought both my ming32 and ming64 are running the same prerelease versions
though
My ming64 compiles fine by taking out the
-DWITH_TSP=ON
But then it doesn't regress because the create extension seems to load tsp
functions.
I'll have to double-check my ming32, but as I recall if I take out the
-DWITH_TSP it also fails the tests because its missing the tsp dll.
Regina
[mailto:pgrouting-dev-bounces@lists.osgeo.org] On Behalf Of Stephen
Woodbridge
Sent: Sunday, April 07, 2013 8:51 PM
To: pgrouting-dev@lists.osgeo.org
Regina,
I just noticed that:
woodbri@imaptools /C/ming64/projects/pgrouting/build/src/tsp/src
$ gcc --version
gcc.exe (GCC) 4.5.4 20111030 (prerelease) [svn/rev.180676 - mingw-w64/oz]
Copyright (C) 2010 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
our version of the gcc is a prerelease, do you know if there is a new
version that might be better? I looked at the sourceforge but it has a mess
of versions and I think it better is we stay in sync with one another.
-Steve
On 4/7/2013 8:19 PM, Stephen Woodbridge wrote:
Ok, I just got back and I have the same problem on 64bit now that I
have a system to check it on.
-DWITH_TSP=ON should not be included any more. I may have forgotten
to take it out of makepgroutingw64.sh
After looking at the compile error on 64 bit for 6 hours, I'm either
totally missing something obvious or this is looking like GNU compiler
bug.
If you run the tools/makepgroutingw64.sh and then after it bombs:
cd build
make VERBOSE=1
and this will should you something like:
Scanning dependencies of target routing_tsp [ 66%] Building C object
src/tsp/src/CMakeFiles/routing_tsp.dir/tsp.c.obj
[ 73%] Building C object
src/tsp/src/CMakeFiles/routing_tsp.dir/tsplib.c.obj
c:/ming64/projects/pgrouting/src/tsp/src/tsplib.c: In function
'findEulerianPath':
c:/ming64/projects/pgrouting/src/tsp/src/tsplib.c:183:14: error: 'ERROR'
undeclared (first use in this function)
c:/ming64/projects/pgrouting/src/tsp/src/tsplib.c:183:14: note: each
undeclared identifier is reported only once for each function it
appears in
'find_tsp_solution':
c:/ming64/projects/pgrouting/src/tsp/src/tsplib.c:446:18: error: 'FATAL'
make[2]: *** [src/tsp/src/CMakeFiles/routing_tsp.dir/tsplib.c.obj]
Error 1
make[1]: *** [src/tsp/src/CMakeFiles/routing_tsp.dir/all] Error 2
make: *** [all] Error 2
woodbri@imaptools /c/ming64/projects/pgrouting $ cd build
woodbri@imaptools /c/ming64/projects/pgrouting/build
$ make VERBOSE=1
/C/ming64/msys/bin/cmake.exe -H/C/ming64/projects/pgrouting
-B/C/ming64/projects/pgrouting/build --check-build-system
CMakeFiles/Makefile.cmake 0 /C/ming64/msys/bin/cmake.exe -E
cmake_progress_start /C/ming64/projects/pgrouting/build/CMakeFiles
/C/ming64/projects/pgrouting/build/CMakeFiles/progress.marks
make -f CMakeFiles/Makefile2 all
make[1]: Entering directory `/c/ming64/projects/pgrouting/build'
make -f src/shooting_star/src/CMakeFiles/shooting_star.dir/build.make
src/shooting_star/src/CMakeFiles/shooting_star.dir/depend
make[2]: Entering directory `/c/ming64/projects/pgrouting/build'
/C/ming64/msys/bin/cmake.exe -E cmake_depends "MSYS Makefiles"
/C/ming64/projects/pgrouting/src/shooting_star/src
/C/ming64/projects/pgrouting/build/src/shooting_star/src
/C/ming64/projects/pgrouting/build/src/shooting_star/src/CMakeFiles/sh
ooting_star.dir/DependInfo.cmake
--color=
make[2]: Leaving directory `/c/ming64/projects/pgrouting/build'
make[2]: Nothing to be done for
`src/shooting_star/src/CMakeFiles/shooting_star.dir/build'.
/C/ming64/msys/bin/cmake.exe -E cmake_progress_report
/C/ming64/projects/pgrouting/build/CMakeFiles 11 12 [ 13%] Built
target shooting_star make -f
src/trsp/src/CMakeFiles/trsp.dir/build.make
src/trsp/src/CMakeFiles/trsp.dir/depend
/C/ming64/projects/pgrouting /C/ming64/projects/pgrouting/src/trsp/src
/C/ming64/projects/pgrouting/build/src/trsp/src
/C/ming64/projects/pgrouting/build/src/trsp/src/CMakeFiles/trsp.dir/De
pendInfo.cmake
--color=
make -f src/trsp/src/CMakeFiles/trsp.dir/build.make
make[2]: Nothing to be done for `src/trsp/src/CMakeFiles/trsp.dir/build'.
/C/ming64/projects/pgrouting/build/CMakeFiles 13 14 15 [ 33%] Built
target trsp make -f src/astar/src/CMakeFiles/astar.dir/build.make
src/astar/src/CMakeFiles/astar.dir/depend
/C/ming64/projects/pgrouting/src/astar/src
/C/ming64/projects/pgrouting/build/src/astar/src
/C/ming64/projects/pgrouting/build/src/astar/src/CMakeFiles/astar.dir/
DependInfo.cmake
--color=
`src/astar/src/CMakeFiles/astar.dir/build'.
/C/ming64/projects/pgrouting/build/CMakeFiles 1 2 [ 46%] Built target
astar make -f src/dijkstra/src/CMakeFiles/dijkstra.dir/build.make
src/dijkstra/src/CMakeFiles/dijkstra.dir/depend
/C/ming64/projects/pgrouting/src/dijkstra/src
/C/ming64/projects/pgrouting/build/src/dijkstra/src
/C/ming64/projects/pgrouting/build/src/dijkstra/src/CMakeFiles/dijkstr
a.dir/DependInfo.cmake
--color=
`src/dijkstra/src/CMakeFiles/dijkstra.dir/build'.
/C/ming64/projects/pgrouting/build/CMakeFiles 3 4 [ 60%] Built target
dijkstra make -f CMakeFiles/routing.dir/build.make
CMakeFiles/routing.dir/depend
/C/ming64/projects/pgrouting/build /C/ming64/projects/pgrouting/build
/C/ming64/projects/pgrouting/build/CMakeFiles/routing.dir/DependInfo.c
make
--color=
make -f CMakeFiles/routing.dir/build.make CMakeFiles/routing.dir/build
make[2]: Nothing to be done for `CMakeFiles/routing.dir/build'.
[ 60%] Built target routing
make -f src/tsp/src/CMakeFiles/routing_tsp.dir/build.make
src/tsp/src/CMakeFiles/routing_tsp.dir/depend
/C/ming64/projects/pgrouting /C/ming64/projects/pgrouting/src/tsp/src
/C/ming64/projects/pgrouting/build/src/tsp/src/CMakeFiles/routing_tsp.
--color=
/C/ming64/projects/pgrouting/build/CMakeFiles 10 [ 66%] Building C
object src/tsp/src/CMakeFiles/routing_tsp.dir/tsplib.c.obj
cd /C/ming64/projects/pgrouting/build/src/tsp/src &&
/c/ming64/mingw64/bin/gcc.exe -Drouting_tsp_EXPORTS -O2 -g
-frounding-math @CMakeFiles/routing_tsp.dir/includes_C.rsp -o
CMakeFiles/routing_tsp.dir/tsplib.c.obj -c
/C/ming64/projects/pgrouting/src/tsp/src/tsplib.c
'findEulerianPath':
appears in
Error 1
make[1]: Leaving directory `/c/ming64/projects/pgrouting/build'
So if I look at the commands that are getting executed you will notice
above on the gcc.exe there is:
This appears to be a way to include command line options from a file.
So I just copied the options from the file to the commandline in the
next
command:
$ cd /C/ming64/projects/pgrouting/build/src/tsp/src
$ /c/ming64/mingw64/bin/gcc.exe -Drouting_tsp_EXPORTS -O2 -g
-frounding-math
-Ic:/ming64/projects/pgx64/pg92/include/postgresql/server
-IC:/ming64/projects/pgrouting/src/astar/src
-IC:/ming64/projects/pgrouting/src/dijkstra/src
-IC:/ming64/projects/pgrouting/src/shooting_star/src
-IC:/ming64/projects/pgrouting/src/tsp/src
-IC:/ming64/projects/pgrouting/src/driving_distance/src
-IC:/ming64/projects/pgrouting/src/trsp/src
-Ic:/ming64/msys/local/include/boost-1_46_1
-Ic:/ming64/projects/pgx64/pg92/include/postgresql/server/port/win32 -o
'findEulerianPath':
appears in
And tried to convert the "C:" to "/c" in this command:
-frounding-math
-I/c/ming64/projects/pgx64/pg92/include/postgresql/server
-I/c/ming64/projects/pgrouting/src/astar/src
-I/c/ming64/projects/pgrouting/src/dijkstra/src
-I/c/ming64/projects/pgrouting/src/shooting_star/src
-I/c/ming64/projects/pgrouting/src/tsp/src
-I/c/ming64/projects/pgrouting/src/driving_distance/src
-I/c/ming64/projects/pgrouting/src/trsp/src
-I/c/ming64/msys/local/include/boost-1_46_1
-I/c/ming64/projects/pgx64/pg92/include/postgresql/server/port/win32 -o
'findEulerianPath':
appears in
Lets check that the file exists, and it does. This file gets included
from postgres.h
$ /bin/find.exe /c/ming64/projects/pgx64/pg92/ -name postgres.h -print
/c/ming64/projects/pgx64/pg92/include/postgresql/server/postgres.h
$ /bin/find.exe /c/ming64/projects/pgx64/pg92/ -name elog.h -print
/c/ming64/projects/pgx64/pg92/include/postgresql/server/utils/elog.h
So I'm left with:
1. it works on 32 bit
2. the -Idirectory is included in the gcc 3. the include files exist
in the correct places 4. gcc does not appear to be loading them, but I
do not know why
Anyone run into this problem before?
Anyone have any ideas?
-Steve
pgrouting-dev mailing list
http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
