Daniel, et al,
I have integrated the KDijkstra code into branch kdijkstra-merge. It has test cases so you can see how it works. Please look it over and if anyone has comments shout.
I will be merging this branch into sew-devel-2_0 probably tomorrow sometime.
It seems to be working nicely as far as I can tell. There is no doc for it yet other than the test files.
-Steve
On Sun, May 26, 2013 at 2:20 PM, Stephen Woodbridge <woodbri@swoodbridge.com
wrote:
Daniel, et al,
has comments shout.
sometime.
Thanks, Steve,
I will add the documentation, when it's merged.
Daniel
Georepublic UG & Georepublic Japan
eMail: daniel.kastl@georepublic.de
Web: http://georepublic.de
Daniel,
I have merged KDijkstra into the release. I added a skeleton doc/index.rst page but it needs some examples and you might want to reformat it.
-Steve
<woodbri@swoodbridge.com <mailto:woodbri@swoodbridge.com>> wrote:
Daniel, et al,
sometime.
Thanks, Steve,
Daniel
eMail: daniel.kastl@georepublic.de <mailto:daniel.kastl@georepublic.de>
Web: http://georepublic.de/>
pgrouting-dev mailing list
pgrouting-dev@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
On Sun, May 26, 2013 at 11:50 PM, Stephen Woodbridge <
woodbri@swoodbridge.com> wrote:
Daniel,
Thanks, Steve!
Except the examples all is there already.
Just one thing about the camel case names: shouldn't it be "pgr_kDijkstra"
with capital "D"?
Because we also have bdDijkstra.
Daniel
Daniel,
reformat it.
Thanks, Steve!
Yeah, I cloned the pgr_dijkstra doc and edited that to give you are start since I already knew how the functions worked.
"pgr_kDijkstra" with capital "D"?
This is fine with me. Since postgresql is case insensitive, it is probably most important in the doc for consistency, but the SQL wrappers can be changed as well.
-Steve
Daniel
