In the documentation for compilation, several of the library version are listed as TBD-- any guesses/recommendations (known versions that work) for those libraries? What does a typical (in Steve's case) debian build look like library-wise?
I wrote TBD, because I have to figure out first what would be the minimum required version.
But trying to find this out is not so much fun
There is currently only CMake that requires a rather new version.
The rest doesn’t seem to be a problem. So I’m not sure I want to spend much time in trying to compile with ancient library versions.
So far I had no version issues (except CMake) with dependencies and I have created packages for Ubuntu 12.04, 12.10 and 13.04
This is the Debian control file to create the packages, which lists the required libraries: https://github.com/pgRouting/pgrouting-build/blob/master/debian/control
In the documentation for compilation, several of the library version are listed as TBD-- any guesses/recommendations (known versions that work) for those libraries? What does a typical (in Steve’s case) debian build look like library-wise?
Perfect. Thank you. I've had trouble on Ubuntu, but none on Debian. I'm hoping to get a moment to breath so I can document versions, etc.. On Ubuntu 12.04, everything compiles fine with the libraries I'm using (except sphinx-- don't know why) but TSP and topology builds fail.
Hopefully in the next few weeks, things will let up enough for me to document and ticket if necessary.
Best,
Steve
On 06/27/2013 10:27 PM, Daniel Kastl wrote:
Hi Stephen,
The rest doesn't seem to be a problem. So I'm not sure I want to spend much time in trying to compile with ancient library versions.
Daniel
On Fri, Jun 28, 2013 at 11:07 AM, Stephen Mather <stephen@smathermather.com <mailto:stephen@smathermather.com>> wrote:
Best,
Steve
pgrouting-dev mailing list
pgrouting-dev@lists.osgeo.org <mailto:pgrouting-dev@lists.osgeo.org> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
Georepublic UG & Georepublic Japan
eMail: daniel.kastl@georepublic.de <mailto:daniel.kastl@georepublic.de>
Web: http://georepublic.de/>
On Fri, Jun 28, 2013 at 12:02 PM, Stephen Woodbridge <
I prefer Ubuntu, but knew that Steve was a Debian guy, so figured it'd work there if anywhere. I'll give the script a spin tomorrow-- it looks like neither topology building nor TSP is working for me on Debian either.
Best,
Steve
On 06/27/2013 11:21 PM, Daniel Kastl wrote:
On Fri, Jun 28, 2013 at 12:02 PM, Stephen Woodbridge <woodbri@swoodbridge.com <mailto:woodbri@swoodbridge.com>> wrote:
version are
that work)
debian build
and platform info with bugs so we can get a better handle on what's what.
-Steve
Best,
Steve
version are
that work)
debian build
