Hi All,
I have cleared most of the bugs related to 2.0, were down to about 10 or so. But I have a few problems that need C++ and/or Boost expertise. For Boost we can get good support from the Boost list, but I am not a C++ programmer. I can make minor tweaks of C-ish types of things but that's about it.
Issues I need some help with at least these two:
#87 apsp_warshall needs to use float8 weights not integer
https://github.com/pgRouting/pgrouting/issues/87
#32 database crashes when a large number was entered as target id
https://github.com/pgRouting/pgrouting/issues/32
Please let me know if you can help with one or both of these.
-Steve
On 5/14/2013 9:40 PM, Stephen Woodbridge wrote:
Hi All,
about it.
I posted #32 to the boost list and got back a very detailed response which I have added to the ticket. It looks like there is a lot of room for improvement in the way we use boost and these changes could be applied to all of our boost wrapper functions to make the code faster and more robust.
I'm going to see if I can make some changes, but I'll really shooting in the dark with c++, so I could use some help on this.
-Steve
-Steve
pgrouting-dev mailing list
pgrouting-dev@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
