Hi list,
Let's decide what to do wit the current SVN version. I differs from
last 1.03 release and I think it is better to make one more before we
start code cleaning and possible integration to PostGIS.
What do you think?
Anton.
Hi list,
What do you think?
Anton.
Hi Anton,
My opinion is that current trunk version has been “tested” now for a very long time.
And always when someone asked, we recommended to use SVN trunk (it was also used for recent LiveDVD versions).
So even if we don’t have some criteria defined for testing (yet), I think it should be fine to make the current version on SVN a new release and then move the repository to Git.
Daniel
2010/11/4 Anton Patrushev <anton.patrushev@georepublic.de>
Hi list,
Let’s decide what to do wit the current SVN version. I differs from
start code cleaning and possible integration to PostGIS.What do you think?
Anton.
pgrouting-dev mailing list
pgrouting-dev@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
+1 on this. We keep the older versions around so people have the option of which version they can use. So this should not be a problem.
-Steve
On 11/3/2010 10:29 PM, Daniel Kastl wrote:
Hi Anton,
My opinion is that current trunk version has been "tested" now for a
very long time.
also used for recent LiveDVD versions).So even if we don't have some criteria defined for testing (yet), I
and then move the repository to Git.Daniel
<mailto:anton.patrushev@georepublic.de>>Hi list,
Anton.
pgrouting-dev@lists.osgeo.org <mailto:pgrouting-dev@lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/pgrouting-dev_______________________________________________
