I've had a couple of requests to be able to only test one algorithm when someone if make changes to only one area.
RUNNING: test-runner.pl -h
Usage: test-runner.pl -pgver vpg -pgisver vpgis -psql /path/to/psql
-pgver vpg - postgresql version
-pgport port - postgresql port to use (default: 5432)
-pgisver vpgis - postgis version
-pgrver vpgr - pgrouting version
-psql /path/to/psql - optional path to psql
-v - verbose messages for debuging(enter twice for more)
-clean - dropdb pgr_test__db__test
-ignorenotice - ignore NOTICE statements when reporting failures
-alg 'dir' - directory to select which algorithm subdirs to test
-h - help
Example:
tools/test-runner.pl -alg tsp
tools/test-runner.pl -alg common
Will only run the 'tsp' or 'common' tests. The dir is the directory under 'src/' that you want to limit your test to. This tends to be much faster than running all the tests.
Just pushed this change to github in the develop branch.
-Steve
