Hi Pulkit,
First it would be a good idea to get on the pgrouting-dev list:
pgrouting-dev mailing list
pgrouting-dev@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
Then you can look at:
https://github.com/pgRouting/pgrouting/wiki/Developer---Getting-Started
and the other links here:
http://pgrouting.org/ -- look at the user docs and the new workshop
There are a bunch of people on the list that can help
-Steve
On 1/30/2014 3:54 AM, Pulkit Agarwal wrote:
Hi Steve,
I went through the all the three Readme and things are no quite clear to
me. What I think we have to install
* postgresql-server-dev-9.2
* libpq-dev
* libpqxx3-dev
* libcurl4-gnutls-dev
* libjson0-dev.
I followed the link to install.
https://gist.github.com/chen206/4030441I mean just by installing the above mentioned packages will we be able
to set up the project.
As I am new to postgresql and pgrouter please guide me with all the
basics of installing the project on my laptop.Thanks,
PulkitOn Wed, Jan 29, 2014 at 10:45 AM, Stephen Woodbridge
<woodbri@swoodbridge.com <mailto:woodbri@swoodbridge.com>> wrote:Hi Pulkit,
You might also be interested in looking at
https://github.com/woodbri/__osrm-tools
<https://github.com/woodbri/osrm-tools>This is a tool the extracts pgRouting data into a format that can be
loaded into Project-OSRM (the high performance routing engine for OSM)And a postgresql extension that allows you to access OSRM from
inside the database.I have combine these to to allow you to select a number of points on
a map and then compute a distance matrix using the osrm-tools and
optimizing the order of the points use pgRouting TSP function. then
passing the results back to the web application to display them.The osrm-tools can also be used to compute distance matrices needed
for the VRP solution.I think picking another VRP problem or enhancing the current one to
add more functionality might be a good project.Another interesting project might be to build an asymmetric TSP
solver. Our current solver uses simulated annealing but it assumes a
symmetric matrix.Daniel might have some additional ideas about additional VRP
solutions that we might need.If you have time, jump in and start working on a small project that
might interest you or we can point out a bug that might need fixing.
In the past students that jumped in early and started working
learned a lot of the basics so when they got selected for GSoC, they
had more time to focus on doing something fun stuff rather than
learning the basics of how to deal with coding in the postgresql
server environment.Thanks,
-SteveOn 1/28/2014 3:13 PM, Pulkit Agarwal wrote:
Hi Steve,
I went through the project ideas and what i have come up with is the
projects aim at developing routing software with large data
which forces
it to go toward AI algorithms in collaboration with osm. Let me
inform
what exactly i did i the project i mentioned in my first mail.
It was a
cross platform offline routing software specific to our college
campus(
hence named campus mapping software) which used osm and the
functionalities were implemented over it.So I understand most of the
basics of doing these functionalities. Also Tabu search and other
heuristic based based algorithms are covered in our Artificial
Intelligence course, so i am familiarized with these also.Overall I think if the projects will be on similar areas i will
do well
and live upto the project expectation .Looking forward to work
with this
organization.Thanks,
-Pulkit.On Wed, Jan 29, 2014 at 12:59 AM, Stephen Woodbridge
<mailto:woodbri@swoodbridge.__com
<mailto:woodbri@swoodbridge.com>>> wrote:On 1/28/2014 2:09 PM, Alex Mandel wrote:
On 01/28/2014 11:04 AM, Pulkit Agarwal wrote:
Hello,
I'm new to OSGeo and would like to contribute.
I read the various prerequisites in terms of
knowledge of
different
platforms of the organization. And i have basic idea of
almost all the
platforms mentioned. In-fact i worked on an
academic project
involving Open
street maps.At the moment, I don't have a
particular area in
mind but I'm
excited to work in various interesting topics. So
how should
I start?I'm also looking up to GSOC 2014 and perhaps do a
project
for OSGeo. Where
should I get the latest news regarding it like the
list of
projects,
mentors etc.?Regards,
Pulkit AgarwalWelcome,
We haven't started a 2014 GSOC page yet on the
wiki.osgeo.org <http://wiki.osgeo.org>
<http://wiki.osgeo.org> but there
is a mailing list:
http://lists.osgeo.org/____mailman/listinfo/soc
<http://lists.osgeo.org/__mailman/listinfo/soc><http://lists.osgeo.org/__mailman/listinfo/soc
<http://lists.osgeo.org/mailman/listinfo/soc>>Hi Pulkit,
You can also check in with any of the projects that
interest you and
I think you will find that most can give you some idea of
potential
GSoC Ideas for their projects.For example pgRouting has:
https://github.com/pgRouting/____pgrouting/wiki/GSoC-Ideas
<https://github.com/pgRouting/__pgrouting/wiki/GSoC-Ideas><https://github.com/pgRouting/__pgrouting/wiki/GSoC-Ideas
<https://github.com/pgRouting/pgrouting/wiki/GSoC-Ideas>>Our experience through the years that students the pick
projects
that they are interested in or passionate about tend to
learn more
and have more fun working on them and are the most successful.You are not constrained to pick an existing idea. If you
have some
ideas bounce them off the project lists and work with them
to fine
tune your ideas or come up with other ideas.There is nothing better than working on a project that
excites you.Best Regards,
-Steve
___________________________________________________
Discuss mailing list
Discuss@lists.osgeo.org <mailto:Discuss@lists.osgeo.org>
<mailto:Discuss@lists.osgeo.__org <mailto:Discuss@lists.osgeo.org>>
http://lists.osgeo.org/____mailman/listinfo/discuss
<http://lists.osgeo.org/__mailman/listinfo/discuss>
<http://lists.osgeo.org/mailman/listinfo/discuss>>
