On 12/22/2014 8:06 PM, yobiSource wrote:
is there any progress in memory management? [1]
I create 5000 times a distance matrix (pgr_kdijkstra) with ~300 points
and run oom. (>20 GB)
I avoid that by just split the data and open multiple connections (one
after another) but it is a bit complicated.
[1]
https://github.com/pgRouting/pgrouting/issues?q=is%3Aissue+is%3Aopen+memory
Hi yobi,
I can appreciate how frustrating issues are like this. They are for the developers also. Maybe you should open a ticket for this issue and decribe what you are doing in some detail. Ideally getting a small database dump and a query that reproduces problem would be very helpful.
While there are other commands that have memory issues, they are most likely not related to your OOM issue. Information you should post in the ticket includes:
OS: Windows, Linux
Hardware: 32/64 bit, Memory, amount of swapfile space
How many shared_buffers in your postgresql.conf file?
How many edges in your graph?
select count(*) from edge_table;
edge and node ids:
select min(source) as smin, max(source) as smaxm, min(target) as tmin, max(target) as tmax, min(gid) as gmin, max(gid) as gmax
from edge_table;
What is your query that is running out on memory?
Describe the steps to reproduce the problem.
Then you can refer to the ticket number when asking about the issue and all the data is in one place.
As far as progress, we have been tied up on other projects because we get very little funding for pgrouting, but with some more detailed information we might be able to help you work around the issue.
Also you might want to look at the tools in github branch develop in src/common/sql/pgrouting_conversion_tools.sql which has a lot of tools for building distance matrices.
Also src/kdijkstra/src/k_targets_sp.c which has some new stuff that is not in the tagged 2.0.0 release.
-Steve
