Hi Pieter,
Here is my last build that runs on the following:
test1=# select version();
version
PostgreSQL 9.2.1 on i686-w64-mingw32, compiled by i686-w64-mingw32-gcc.exe (GCC) 4.5.4 20111030 (prerelease) [svn/rev.180676 - mingw-w64/oz], 32-bit
(1 row)
test1=# select postgis_full_version();
NOTICE: Function postgis_topology_scripts_installed() not found. Is topology su
pport enabled and topology.sql installed?
postgis
_full_version
POSTGIS="2.0.1 r9979" GEOS="3.4.0dev-CAPI-1.8.0 r3716" PROJ="Rel. 4.8.0, 6 March 2012" GDAL="GDAL 1.9.2, released 2012/10/08" LIBXML="2.7.8" LIBJSON="UNKNOWN"
RASTER
(1 row)
http://imaptools.com:8080/dl/pgrouting-1.0.7DEV-pg92.zip
Installed on my system as:
$ cat install_manifest.txt
c:/ming32/projects/pgx32/pg92w32/lib/POSTGR~1/librouting.dll.a
c:/ming32/projects/pgx32/pg92w32/share/POSTGR~1/extension/pgrouting--1.0.7.sql
c:/ming32/projects/pgx32/pg92w32/share/POSTGR~1/extension/pgrouting.control
c:/ming32/projects/pgx32/pg92w32/lib/POSTGR~1/librouting_tsp.dll.a
c:/ming32/projects/pgx32/pg92w32/lib/POSTGR~1/librouting_dd.dll.a
createdb test1
psql -c "create extension postgis" test1
psql -c "create extension pgrouting" test1
I probably can not help you much with install issues, but let us know if you get it working. There are a few (10) tests already in the source tree and a perl script that runs them tools/test-runner.pl which should be run from the top level.
If you find bugs, I would be happy to get additional tests in a pull request.
-Steve
On 4/6/2013 3:16 AM, Pieter du Plooy wrote:
Thanx Steve
Do you perhaps have prebuilt binaries? (64 and 32 bit)?
I will build during this week, just need to get my DEV machine up and running.
On Sat, Apr 6, 2013 at 2:38 AM, Stephen Woodbridge <woodbri@swoodbridge.com <mailto:woodbri@swoodbridge.com>> wrote:
I built this based on the postgis mingw32 and ming64 build
environments. But if you pull my branch there is a tools directory
at the top level that has some scripts (more as doc then a
runnable script) called:
makedependanciesw64.sh - how to build the dependencies
makepgroutingw32.sh - how to build under ming32
makepgroutingw64.sh - how to build under ming64
I say to look at these as docs not as scripts because they have a
lot of assumptions about directory structures and such.
There are also a couple of patch files in the tools directory
also. With my latest checking you do not need to build the GAUL
dependency anymore.
-Steve
On 4/5/2013 1:09 AM, Pieter du Plooy wrote:
Steve
Is the windows build instructions the same as what I did last
year for the build that I made? (mingw?)
Pieter
On Fri, Apr 5, 2013 at 3:35 AM, Stephen Woodbridge
Hi All,
I have just checked in code into sew-devel-2_0 branch that
eliminates the GAUL dependency and replaces the TSP solver
with a simple C routine. I rewrote the TSP lib code to use
the existing GAUL API and to use the postgresql memory
management and added two test cases. I have build and tested
on Win32-pg92 and Linux-pg84 with no problems.
Daniel - Thanks for the feedback on TSP, I will look at it
and see what I can do with your suggestions.
The current code assumes a loop, ie: the start is also the
end point. Other than that is should work as before.
-Steve
pgrouting-dev mailing list
pgrouting-dev@lists.osgeo.org
<mailto:pgrouting-dev@lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
pgrouting-dev@lists.osgeo.org <mailto:pgrouting-dev@lists.osgeo.org>
